AMD Phenom II X6 1090T - Upgrade AM4 / AM5 / Intel Advice - Keep the 1080ti.
Appsp2245
6 (6.00/day)
Hello everyone,
Situation:
My current system is old. Lack of SSE instructions is really takings its toll.
If time permits, I am used to playing games like diablo 4, POE etc. Lately, I was looking in trying Elden ring and titels such as marvel rivals, to name a few. But there are enough new ones that I could try. I developed severe pancolitis and hence my active lifestyle and work has come to a hold for now.
Upgrade & Budget
Hence I was looking to upgrade my system, for roughly 1200 (+/- 200) till a maximum of €1400.
Though, I need to be weary of my emotional state. So any advice is certainly welcome. Obviously, If I am able to spend less I will. I am aware of the upgrade path with AM 5. So I guess I will not be able to dodge that. I do want most of the components to be future proof.
Current Setup:
  • CPU: AMD Phenom II X6 1090T
  • GPU: 1080ti EVGA ftw 3 (I want to keep this for now)
  • SSD: No SSD,
  • PSU: 750W OCZ fatality1.
New Setup:
  • CPU:
  • RAM:
  • Motherboard:
  • CPU-cooler: AIO or peerless.
  • *GPU: 1080ti EVGA ftw 3 (I want to keep this for now)
  • SSD: Kingston NV3 2TB M.2 SSD (€120)
  • CASE: Fractal Design North XL Chalk White (€180)
  • PSU: Corsair RM1000x 2024 PSU (€160)
  • *HDD: 2 SATA discs.
* Keep from my old system.
So most of the advice will be centered around the CPU/Motherboard/Ram combo.
I know the GPU will bottleneck it heavily. Still, it should squeeze some more life out of the card.
Will an 7800x3d or even an 9800x3d be to much? 870X MSI tomahawk or the GA 870X Aurus elite Wifi are a few of the boards that I have been looking at.
Will an 650E suit me more? how relevant is the RAM-speed.
Anyhow any tips will certainly be welcome,
Thanks for your time.
12,045 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Buy 5600X3D setup on a cheaper board and 32GB of cheap RAM cause the X3Ds don't care about ram speed/latency as much and the GPU will be a bottleneck until you get into the 3080 series card.
3,741 (2.24/day)
System Name Mean machine
Processor 12900k
Motherboard MSI Unify X
Cooling Noctua U12A
Memory 7600c34
Video Card(s) 4090 Gamerock oc
Storage 980 pro 2tb
Display(s) Samsung crg90
Case Fractal Torent
Audio Device(s) Hifiman Arya / a30 - d30 pro stack
Power Supply Be quiet dark power pro 1200
Mouse Viper ultimate
Keyboard Blackwidow 65%
A 12400f + mobo + ram + 2tb nvme should land you around 400-420$. You can go for the 5600x instead, I just found the 12400f a bit cheaper on pcpartpicker. There is no point in spending more for a CPU if you are going to be using the 1080ti.
Your choice of case and PSU is excessive as well imo.
PCPartPicker Part List: https://pcpartpicker.com/list/nrkfLs
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor ($111.34 @ Newegg)
Motherboard: ASRock H670M Pro RS Micro ATX LGA1700 Motherboard ($89.99 @ Amazon)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($85.99 @ Amazon)
Storage: Kingston NV2 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($119.77 @ Amazon)
Total: $407.09
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2025-01-08 10:37 EST-0500
Appsp2245
6 (6.00/day)
Thanks alot for the reply's. I was hoping to keep the 1080ti, for a while longer. So I could get a better GPU later down the line.
Would that change anything in your recommendations.
Best regards,
75 (0.11/day)
System Name Desktop + SteamDeck OLED
Processor i7-10700K @ -0.130mV offset
Motherboard MSI MPG Z490 Gaming Edge WiFi
Cooling be quiet! Pure Loop 280mm
Memory Corsair Vengeance RGB Pro 32GB 3200MT/s CL16
Video Card(s) RTX 3080 Ti Founders Edition @ 1830MHz, 800mV
I like both of these options. But at least get some decent RAM for a 5600X3D. 3200MT/s CL16 is still very cheap and where you'd want to be.
Either of these CPUs would allow you to upgrade GPU in the future to something at least as fast as a 4070 too.
But oh man you're about to unlock way more performance out of the 1080 Ti, it makes sense that you're keeping it. I had a EVGA FTW3 as well and even with a i7-6700K it was an insane CPU bottleneck at 1080P
3,261 (4.76/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
Since you've never mentioned what your exact gaming goal is, in case your want is high refresh rate, I'd rather go for an all-rounded build with Ryzen 7 7700 or Ryzen 5 9600X (whatever is cheaper), literally any B650 motherboard that has enough expansion ports and reasonable VRM, and DDR5-5600 with CL no higher than 30. Going 6 GT/s is only welcome if the price difference is negligible. You can OC your sticks manually anyway. X3D chips are crazy expensive on AM5 and they don't beat 7700/9600X in games if we talk AM4 X3D chips. Yes, you technically can afford 7800X3D but is 10 to 30 % advantage really worth this spending?
I can also suggest going Ryzen 7500F if you're content with ~60...100 FPS range and your main idea is to get the best visuals possible.
Saved money should be invested in a better GPU. I know you're not gonna replace 1080 Ti in the foreseeable but having 2 to 3 benjies more really does help getting more FPS in general because even with 7700, you're gonna be GPU limited in most AAA games, unless you're gaming at 1080p with a 4080+ as your GPU.
Higher end Intel CPUs might be a PITA because of the scheduling issues (E-cores aren't exactly gaming friendly) in some games, lower end CPUs like 12400F are extremely good value but it's not really a longevity king. As an i5-12400F owner I'd only recommend stocking on it if money was a huge concern. It's enough for today but will fall flat on its face before the 2030. You can afford a stronger processor so go for it. 13600K, however, if obtained for a sweet price (people are burning those on aftermarket like crazy), might be a better choice than an AMD platform because even DDR4 is enough to unleash its potential and it beats AMD CPUs in productivity (no idea if you care tho).
FreedomEclipse
~Technological Technocrat~
24,268 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
The Corsair RM1000x is very overkill for a gaming setup. Pick a good 650-750w, An 850w if you really wish to splash the cash but there really isnt any reason to go any higher unless your machine is going completely balls to the wall 24/7 as a mining setup with multiple GPUs always pulling huge loads.
Youre not rich enough for a 5090 so money can be saved and allocated elsewhere in the build.
de.das.dude
Pro Indian Modder
9,136 (1.72/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
credit where credit is due, that x6 phenom lasted quite a lot!
I dont even remember my phenom X4 945.
OP are you sure you need high specs? because you were using a x6 phenom till now...
731 (0.30/day)
7700x/9700x/9600x are all solid options mixed with an affordable b650 board (b850/860 also trickling out now).
Quality gold rated PSU from reputable brands at 850w should be more than enough for most builds.
Investing in anything intel is the worst possible platform choice you can make if you wanna say drop in a zen6 cpu or even further zen6 refresh (what they with the 5900XT) and have some for of forwards compatibility.
If going am5, DD5 6000 with as tight of a CL as possible; there are some good 32gb expo kits at 30/32c.
Case is personal preference.
Cooler, you wont be the arctic III aios for value and performance. Thermalright coolers are the king of value and performance if you prefer air cooling. Unless youre going with high core count CPUs, going air will save you some cash and easily deal with 8 core parts including x3d variants if you go down that route.
Appsp2245
6 (6.00/day)
Thanks again everyone,
I game at 1080p, at 60hz refresh rate. Games I will be looking to try are POE 2, something like Elden ring, Baldurs gate 3 and possibly the Witcher 4 in the future.
But anything that looks appealing would be nice.
This streamer tested: the 1080ti with a 7950X3D (
◾️ CPU - AMD Ryzen 9 7950X3D (only 3D cores enabled, similar to 7800X3D)
◾️ Cooler - Deepcool LT720 AIO
◾️ Nvidia GeForce GTX 1080 Ti - Gigabyte Gaming
◾️ RAM - 32GB DDR5 6000MHz (2x16GB CL30)
◽️ OS - Windows 11 Pro
◽️ SSD - Kingston NV2 512GB
◽️ SSD 2 - Lexar PCIe 4.0 2TB (games installed here)
◾️ Motherboard - Asrock B650 PG Riptide Wifi
◾️ PSU - Corsair HX1200
◾️ Case - Phanteks P500A
The amount of games this person was able to play on reasonable settings looks decent enough for me.
So hence, my initial toughts regarding the AM5 and the somewhat future-proof setup. Especially with the new NVIDIA series and probably AMD cards arounds the corner.
Perhaps a good deal can be made in the near future.
But the 650BE or x870 and ram speeds//pci 5.0 lane seem to up the costs alot.
@FreedomEclipse was doubting between those, an 850W seems more reasonable.
That is indeed a good question to ask and a fair one.
Currently, I guess I don't. But many games simply will not run at all.
I know future-proofing is usually a waste of money. But something with an upgrade path seems reasonable.
3,741 (2.24/day)
Processor 12900k
Cooling Noctua U12A
Memory 7600c34
Storage 980 pro 2tb
Case Fractal Torent
Guy is running a 16 year old CPU, but the amd guy has to tell him he needs to buy amd. For upgradability. Cause obviously, he is really using it. With a 16 year old CPU.
Gosh...
1,580 (3.76/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Upgraded my kids 5600G to a 12400F and it games better. Handles high brick count cars in BrickRigs game (his favorite) where most of his complaints where stuttering and baggy with the AM4 system. That included a 2700X he had previous to that. He's using only 5200mt/s memory ddr5 on a B660-G rog board.
Grab a Z series board, the 12400F will overclock to 4.6ghz just on the stock cooler, should bring phenomenal performance gains over the Phenom rig. Pricing is good.
Just wanted to share that experience for insite.
Appsp2245
6 (6.00/day)
Gosh...
I have not used intel in a while. There was a decent deal on a 14700k that I saw on our website (similar) to ebay recently.
Look I appreciate all advice, I do not want to be narrow-minded.
Thanks regardless.
3,261 (4.76/day)
Russian Wild West
Yeah I would burn some cash on a 1440p144 display. That alone will improve your experience a lot. And it's not even that expensive.
2,190 (2.62/day)
Brazil
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
Agreed. I think it should be quite possible to fit in the budget alongside a B650 with a non-X 9600 (just announced!) or 7700 and some 16GB or 32GB of DDR5-5600 to 6000.
Appsp2245
6 (6.00/day)
The 9600 or 7700 seems like a well priced entry level. Would a b650E or 870x be to much as a mainboard? My experiences are mainly Gigabyte and the odd Asus.
Asrock seems to be well liked currently. Any recommendations as a mainboard?
731 (0.30/day)
Yea, the 7700, b650, and 32 gb kit of ddr5 6000 is gonna provide some serious value if you can find good deals on the 7700; deals look to be drying up here in the us though. For a while they were around $260-270, they’ve since shot back up to $300 in the US. 9600/9600X may be a better option if not pulling the trigger this second.
287 (0.19/day)
Toronto
System Name GraniteXT
Processor Ryzen 9950X
Motherboard ASRock B650M-HDV
Cooling 2x360mm custom loop
Memory 2x24GB Team Xtreem DDR5-8000 [M die]
Video Card(s) RTX 3090 FE underwater
Storage Intel P5800X 800GB + Samsung 980 Pro 2TB
Display(s) MSI 342C 34" OLED
Case O11D Evo RGB
Audio Device(s) DCA Aeon 2 w/ SMSL M200/SP200
Power Supply Superflower Leadex VII XG 1300W
Mouse Razer Basilisk V3
Keyboard Steelseries Apex Pro V2 TKL
I think you should plan on saving some money on the PSU, 750W should suffice. Get a 7600X3D deal from MC if you're around or there are other good AM5 bundles to be had from other websites. With the remaining cash, just get a 1440p monitor, those are pretty cheap now and will change your gaming experience significantly.
Sure you probably have to run most games at 1080p but atleast you have the option to increase resolution for titles that allow it.
North XL is also pretty pricey for a case, there are good <$100 cases available now like the lancool 206. But if you like it, go for it.
6,007 (1.25/day)
Hi! I'm from the Internet
System Name Agent Texas / Selene / Eve
Processor Ryzen7 5800x / Fx 8350 / Fx 8350
Motherboard Gigabyte B550 Aorus Elite Ax V2 / Gigabyte 990FXA-UD3 r4.0 / Msi 970a Krait
Cooling Msi Mag Core liquid / H100i / Cryo-pc Cooler
Memory 2 x32 GB Gskil Ripjaws v series / 4x 8gb G.Skill Snipers / 2x 8gb G.Skill Ripjaws
Video Card(s) Gigabyte Rx 6800xt / Msi RX580 / Gigabyte R9 290x
Storage 1tb M.2, 2tb wd / 500 gb ssd, 2x 2tb Wd Blacks/ 500 gb ssd, 1tb WD Black
Display(s) Dell Ultra Sharp 2408 WFp / Hp w2207 / Sanyo tv
Case Corsair 780t White / Raidmax Vampire / NZXT Phantom 240
Audio Device(s) Onboard Hd Audio / Onboard Hd Audio / Onboard Hd Audio
Power Supply Corsair Rm 850 watt / Corsair TX 850 watt / Corsair TX 750 watt
Mouse Logitech G502 Hero / Logitech G500s / Logitech wireless
Keyboard Corsair Strafe / Corsair k50 / Logitech wireless
Software Win 11 pro / Win 11 pro / Win 11 pro
Benchmark Scores What are benchmarks anyway?
Current Setup:
  • SSD: No SSD,
What Motherboard are you running currently?
1,025 (0.66/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
then the 1080Ti will become 1050Ti, MAGIC :D :D :D
get plain B650. Don't waste money on fancy "E" or 800-series.:rolleyes: Get some mid-priced MB, you won't need paying "X670 entry level price" for "high-end" B650, most features will be hyped-out marketing crap anyway.
2,190 (2.62/day)
Brazil
Not really, no. I could play at 1440p when I had a 1070. Not at the highest settings with the newest titles, it's true, but it was possible. A 1080Ti should do WAY better.
1,025 (0.66/day)
Memory 24 GB @ 3200
Mouse Logitech G604
me too. But, NOTE, 144 Hz;) for 60 Hz 2K it's ok but 144 will push all the sh out of it. 2080 Ti maybe will still do, but 1080 Ti is a dyno. It's sure ok for 1080p 144 Hz, but I very doubt for WQHD.144:rolleyes:
731 (0.30/day)
There are plenty of decent 1440p monitors at 144/165hz that support brand agnostic vrr, you don’t really need to slam fps at your refresh rate cap. Until op decides on a gpu upgrade 1080ti will be fine with tweaked settings at 1440p.
