AMD Radeon RX 6000 Series RDNA2 Pictured Some More, Including a Smaller Twin Fan Variant
47,203 (7.56/day)
A new picture, and two new renders of the upcoming AMD Radeon RX 6000 series RDNA2 graphics cards were shown to the web by JayzTwoCents. These build on top of the official render and Fortnite 3D model reveal from Monday. The first picture shows a top angle shot of AMD's upcoming flagship card, with its dual-slot, triple fan cooling solution. You also get to see the new fan design that has webbed impellers, similar to the ASUS Axial-Tech fans, which direct all their airflow axially, onto the heatsink below. Besides red and black, there are silver bits on the metal cooler shroud, including bits of reflective chrome, and diamond-cut bores of the fan intakes.
Jayz also revealed a never-before-seen smaller reference design card from the RX 6000 series, which features a slightly shorter board design, and a dual-fan setup. He predicts that the larger triple-fan card could be released as a range-topping RX 6900 series, while the dual-fan card could launch in a different segment—6800 or 6700 series. AMD is expected to reveal the RX 6000 series RDNA2 graphics cards on October 28, 2020, but along the way we're sure to receive many more such reveals.
781 (0.32/day)
I can't unsee the very obvious cooler side profile that Radeon adopted from the Nvidia 2080 founders edition.
Hopefully Radeon at least improved it by making it easier to disassemble.
2,350 (0.46/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Let's see if they adopted the performance along with the looks.
1,744 (0.60/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
There's dozens of cards going back years that use similar styles
5,717 (0.94/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
RTG really lacks creativity. Copies RTX2000 series FE design.
Hmm, maybe next year we gonna see something like this from RTG
2,218 (0.32/day)
Toronto, Ontario
System Name The Expanse
Processor AMD Ryzen 7 5800X3D
Motherboard Asus Prime X570-Pro BIOS 5013 AM4 AGESA V2 PI 1.2.0.Ca.
Cooling Corsair H150i Pro
Video Card(s) XFX Radeon RX 7900 XTX Magnetic Air (24.10.1)
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
1,327 (0.37/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | QKZ x HBB
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Windows 10 Education 22H2 x64
On 2nd thought could've done without all those "R"s. Specially that giant center-piece on the two-fan model.
4,841 (1.53/day)
Processor Core i7-13700
Cooling Cooler Master RGB something
Memory Corsair DDR5-6000 small OC to 6200
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Software Windows 11 Professional v23H2
322 (0.16/day)
Bulgaria
Processor 6700K
Motherboard M8G
Cooling D15S
Memory 16GB 3k15
Video Card(s) 2070S
Storage 850 Pro
Display(s) U2410
Case Core X2
Audio Device(s) ALC1150
Mouse Razer
Keyboard Logitech
Software 22H2
People talking about AMD copying Nvidia cooler design, probably has never seen custom AIB coolers before. Heres a clue, the sides are open.
Nvidia shouldnt have abandon the RTX 2k looks, its still the best looking gpu shroud to date. They could refined it by removing the ugly bolts.
I dont like RTX 3k, it looks like BBQ grlll with lids that will pump hot air right into my cpu cooler.
4,841 (1.53/day)
Well half of the heated air is pushed out the back of the card. The rest is in the path of CPU air cooler.
1,752 (1.04/day)
I feel the RDNA2 heatsink fan look pretty generic, so not sure if this a copy of the FE cooler design though. Generally, the heatsink is also sourced from other companies/ OEM, so not sure if AMD is the one that design it this way.
From the design and placement of the fans, I feel most of the hot air will end up getting blown towards the CPU, rather than through the back of the card. We should get more clarity when the official reviews are out today.
2,350 (0.46/day)
System Name Miami
Yes you can argue prior art but the the timing says it's not that.
Edit: Srsly it's just lazy. Even I propably could cook up a cooler shroud that doesn't immediately draw comparison to a 2080ti.
2,012 (0.36/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
are ya all looking more+more in your glass side panel instead of your monitor?
if it performs well i don´t give a flying .........
Nkd
364 (0.06/day)
I see lot of people comparing it to nvidia design. The fin system is similar to VII, looks little bulkier also there are only few ways you can put Radeon on there. I mean you saw what happened with VII it blocked air actually. Now fans look nothing alike Founders edition and whats similar is how it surrounds the PCB. I honestly could care less as long as it works well and does the job.
Give me performance at great price and I will take this cooler anyday. Oh and I am buying 3080 first as well just in case RDNA sucks if it doesn't hopefully I will sell 3080 to miners at profit. looks like mining craze is about to hit again and Nvidia is counting on it with their shader heavy design. It almost feels like Nvidia did what amd had going first with GCN that was compute heavy now Ampere has all them cuda cores that will scale at mining and not gaming lol.
20 (0.00/day)
South Borneo
Processor 9900k, 3950x
Motherboard Z370 Strix, Max Hero
Cooling NZXT X72, TT M360 Plus
Memory Trident Z RGB 32g, Royal 32gb
Video Card(s) 2080Ti FE, 3080 Strix Gundam, 3090 Strix
Display(s) Dell S2716DG, 34" Ultrawide
Case Lian-Li O11DW, TT Core P3 White
Its better looks than rtx20 tho, the triple fan
Improve cooling design, lower temp & noise, better perf/price, & the most important thing it's RED xD
Seriously i think i want one, 5970fe & 6970 IceQ was my last flagship Radeon card
1,190 (0.27/day)
Processor AMD Ryzen 3700x
Cooling Deepcool LS520 SE
Video Card(s) RTX 3070 FE
Display(s) LG GL850
Case Dan A4 H2O
Power Supply Corsair SF600
Mouse MX master 3
Keyboard Master Key Mx
Software win 11 pro
Xfx did closed shroud before those two copycats
4,437 (1.44/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
I like the looks of the cards. It does look sharp.
5,820 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
As long as it's not a god damn blower, I don't care who cribbed it from who.
bug
13,741 (3.97/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
I love looking at leaked pictures almost as much as I love reading about Intel talking about yet another Lake/Cove.
373 (0.19/day)
System Name Cyberdyne Systems Core
Processor AMD Sceptre 9 3950x Quantum neural processor (384 nodes)
Motherboard Cyberdyne X1470
Cooling Cyberdyne Superconduct SC5600
Memory 128TB QRAM
Storage SK 16EB NVMe PCI-E 9.0 x8
Display(s) Multiple LG C9 3D Matrix OLED Cube
Software Skysoft Skynet
Doesn't look very pretty, waiting for Sapphire's cards.
Yeah. I want a Nitro+ one with the huge heatsink. My 580 runs cool and quiet and leaves lots of room to OC
7,762 (2.82/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Overall the design is growing on me - while I prefer more minimalist designs, this comes off as a suitably tasteful take on a semi-futuristic styling. For those saying this resembles RTX 20xx coolers - well, sure, in the way that any reasonably squared off axial fan design with top-facing branding would. That doesn't make it a copy or derivative, though, as the design is quite distinct (more rounded/more visual flow, very different detailing, far less industrial-looking), not to mention that the RTX 20xx FE coolers themselves strongly resemble some previous designs. Put it this way: this design would fit with an aesthetic somewhat along the lines of Mass Effect, while the RTX 20xx FE coolers are more along the lines of (the non-hacked together) parts of Deus Ex. Stricter looking, more straigth lines, more industrial, more squared off, visible screws, etc. Similar does not necessarily mean derivative.
Anyhow, if I get one of these it's getting a waterblock, so it's not like the design matters much to me.
58 (0.02/day)
System Name NEED MOAR POWER!!!/Old One/Offsite
Processor i9 13900K/i7 7820X/i9 9900K
Motherboard Asrock Z790 Taichi/MSI X299 Carbon Pro/Asus ROG Strix X370-G
Cooling NZXT Kraken Elite 360/CM ML240/EVGA CLC280
Memory 128GB DDR5-4800/32GB DDR4-3200/32GB DDR4-3200
Video Card(s) RTX2080Ti/Titan Xp/RTX3070
Storage Much.../Much.../Much...
Display(s) 32" 21:9 + 2x27"/32" 4K/3x 27" FHD
Case Lian Li o11 XL/Jonsbo D41 Screen/AP201
Audio Device(s) Onboard/Onboard/Onboard
Power Supply TT 1650w/Enermax 1350w/Enermax 1350w
Mouse Logitech G502X Plus/ MX Master 3S/G502
Keyboard Logitech G915/ MX Keys/Logitech G915
Software W11 Pro/W11 Pro/W11 Pro
Well... thats clearly a team rocket R on these cards
