Amd radeon rx 6700 xt 120°C normal?
Fischhead69
5 (0.01/day)
Hardware info:
Intel core i5 11400f Watercooled
16gb ddr4 ram
Asus tuf gaming rx 6700 xt oc
Asus rog strix b560-i gaming wifi
750 80+ gold power supply
1tb Nvme ssd
Thermaltake the tower 100 mini
all possible fans installed
While playing gpu hits about 80 degrees and hotspot about 120 degrees.
3,413 (2.51/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
absolutely not. something must be wrong with the card physically, maybe mounting pressure, bad thermal paste
edited for nor reading all the OP post
Count von Schwalbe
Nocturnus Moderatus
3,284 (2.78/day)
Knoxville, TN, USA
80 degrees is pretty hot for a cooler that beefy. Hotspot temps can be pretty variable, but 120C is hot enough to damage the card over time. Is the GPU still in warranty?
3,127 (2.36/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
There's something wrong with the card.
I have an Asus TUF Gaming GeForce RTX 3080 Ti 12G OC and the cooler worked very capably during the month before I slapped a full-length waterblock on the deshrouded PCB. In fact, I don't think the temperature with the TUF cooler even reached 70 °C even during a sustained load (gaming, Unigine benchmarks, whatever).
At least here in the USA, I believe the warranty on Asus graphics cards is three years which would still be valid on all Ampere and RDNA2 cards.
Fischhead69
5 (0.01/day)
I brought the graphics card about 1 month ago and still have warranty. Today I checked the Temps again and today it is rainy and not warm and the gpu hotspot hit 111 degrees and ambient temperature 81 degrees. I have a mini itx build but the gpu can get fresh air from the outside.
382 (0.25/day)
System Name Incomplete thing 1.0
Processor Ryzen 2600
Motherboard B450 Aorus Elite
Cooling Gelid Phantom Black
Memory HyperX Fury RGB 3200 CL16 16GB
Video Card(s) Gigabyte 2060 Gaming OC PRO
Storage Dual 1TB 970evo
Display(s) AOC G2U 1440p 144hz, HP e232
Case CM mb511 RGB
Audio Device(s) Reloop ADM-4
Power Supply Sharkoon WPM-600
Mouse G502 Hero
Keyboard Sharkoon SGK3 Blue
Software W10 Pro
Benchmark Scores 2-5% over stock scores
What are your idle temps (when not running any games), and what about the air temp in your room?
Also, try taking both the glass and mesh panels out, see if it improves.
18,584 (2.67/day)
System Name AlderLake
933 (0.51/day)
Case internal temperature is 80c? Can't be ambient or last problem op will have is GPU temperature!
Need case ventilation?
Fischhead69
5 (0.01/day)
I don’t now what my room temp is but I think it’s about 23 degrees. Now I removed the side panels and it didn’t really help for the hot spot, but the ambient temp dropped to 79 degrees. Normally when I use my pc for school the fans don’t spin and that means it’s under 55 degrees. When I play games like Minecraft or btd6 or R6 siege and some other not really graphic intense games the pc is barely hearable and not making lot of heat. In really graphic intense games like in games with ray tracing like shadow of the tomb raider with max settings or while benchmarking like now this happens.
2,259 (1.00/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
thats a very hot hotspot, is it not shutting down ? forgive me im up on your card.
18,584 (2.67/day)
226 (0.05/day)
System Name Mixed Bag of OC
Processor AMD Ryzen 5800X3D
Motherboard Maxsun MS-iCraft B550M WIFI
Cooling CPU+GPU on Water with 3 X 420 Rad´s
Memory 32GB Patriot Viper RGB @ 3800 Mhz CL14
Video Card(s) XFX Merc 310 RX 7900 XTX
Storage 2TB Kingston Fury + 2TB Samsung PCIe 4 NVME
Display(s) Philips 48OLED806
Case Selfmade Huuuuuge *Case* :)
Audio Device(s) ifi Zen DAC + Monoprice M1060C & Burmester Replica AMP + Selfmade Huuuuuge Speakers :)
Power Supply Seasonic PRIME TX-750
Mouse Kensington Slimblade (main device) + Razer Basilisk V3 (for FPS)
Keyboard Sharkoon PureWriter RGB, Kailh Blue switches
VR HMD None
Benchmark Scores do not matter, my PC is fast :)
No it doesn’t shut down it works completely normal
Hw monitor says gpu ambient temp so I wrote ambient temp
Could you please try the "radeon settings" "Metric" Tab and see what temps are displayed there. The GPU should have a shutdown Temp @ 118C so 120C shouldn't even be possible.
1,724 (1.08/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
Your GPU is overheating, it shouldn't be showing such high temperatures:
What is your case model and where is it placed physically? Do you keep it in a cabinet, or very near the wall?
7,649 (1.77/day)
Well first of all try something like GPUZ, hwinfo or AIDA64.
This application is pretty bad IMO ~
Fischhead69
5 (0.01/day)
I have a Thermaltake the tower 100 mini case and in the first photo you see where the pc is kept. It is in an open place next to my desk and my door. The air is coming from the mesh panels in photo 2 (in the right side there is a mesh too). There is also the power supply that is taking air from the mesh in the bottom you can see it in photo 3. The gpu has it own intake from the mesh panels in the left. The outtake is combined with a 120mm radiator and fan. The radiator config is pull
I use hw monitor to monitor the temps and the hot spot was 120 degrees. I use the performance bios
3,413 (2.51/day)
Mouse G502
what is that fan at the bottom doing if the PSU is getting air from the bottom? isn't it just throwing air against the back of the psu, solid metal?
that gpu against the glass doesn't help, i now it gets some air in the side, still, that case design seems far from ideal.
but even with all that temps should not be that high. You have to open the gpu and take a look inside.
7,649 (1.77/day)
It's Celsius from the screenshots, but that's clearly wrong. HWmonitor is pretty trash in that regard, consistently inaccurate in a lot of systems I've seen.
7,482 (4.97/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Don't use HWMonitor, it hasn't been updated in a long time and it doesn't work well with modern hardware.
I suggest using HWiNFO64 instead; but your case clearly cannot handle a high-TDP scenario and you should be conservative with your voltage/frequency curve.
1,724 (1.08/day)
My take is that the ambient case temperature is too high, resulting in elevated thermals overall. In other words, the heat which accumulates inside is not being extracted at an adequate rate. What is your case/motherboard temperature on the desktop? Is your GPU temp 56c at idle?
Second, your case has an exhaust fan at the back, which seems to be completely obstructed. In your current position the back of the case seems to be touching the shelf/wall.
Try testing with the case on your desk. Also, remove that pointless dust filter on the back fan :kookoo:
18,584 (2.67/day)
that pointless dust filter on the back fan.
It seems the manufacturer also had the idea for mounting the fans other way around for air intake?
1,724 (1.08/day)
This is the only intake fan. It sits on a perforated tray and is supposed to suck air in through the vents at the base of the case:
Just noticed, GPU temps seem normal at idle:
383 (0.23/day)
System Name Spaceheater
Processor Ryzen 9 5950X H2O
Motherboard asus x570-e ROG Strix
Cooling Triple radiator + vardar fans D5 for cpu and external MO-RA 420 NF-A20 1200 rpm dual D5 pump for GPU
Memory 4x8 GB G.Skill Trident Z Neo F4-3600C16Q-32GTZN
Video Card(s) Liquid devil 7900 XTX with PTM7950 + AMD 6900 XT in 2e machine
Storage 2x 980 pro 2tb 2x 860 EVO 1tb raid0 2x mx500 2 tb raid0 2x WD40EZRZ 4 tb raid0
Display(s) LG 38WN95C-W 3840x1600 144hz | 11,9 inch system info display
Case Lian Li PC-O11 Dynamic XL (ROG Certified) White
Audio Device(s) z5500 + steelseries Arctis Nova Pro wireless
Power Supply be quiet! Dark Power Pro 12 1200W
Mouse Logitech G502 X
Keyboard Keychron Q1
Software windows 11 23H2
No way that is normal that is freaking hot it should not get this hot, i would recommend also using hwinfo64 instead of outdated tool like hardware monitor, you probably getting a false readout, what does the amd control panel performance metrics read out it does not show a min max but it least should be accurate there.
3,413 (2.51/day)
Mouse G502
now i'm even more confused or my eyes are playing a trick on me, you want to intake from the bottom but have a fan turned down at the bottom?!
30 (0.02/day)
System Name Personal
Processor Intel i5-9600k@5.2GHz
Motherboard Z390 TUF Gaming Wi-Fi
Cooling Corsair H60 120mm
Memory Corsair (2x8GB) DDR4-3000
Video Card(s) Quadro P2200 (Work) + RX580 Nitro+ SE @1550MHz (Gaming)
Storage 2x 500GB Samsung SSD 750 Evo
Display(s) ThinkVision P32p-20
As suggested by numerous folks above, please use hwinfo64 and report back.
