AMD Ryzen 5 7400F De-Lid Reveals Thermal Paste Instead of STIM
47,480 (7.49/day)
Priced at the equivalent of $116, the China-exclusive Ryzen 5 7400F is a 6-core/12-thread processor powered by the older "Zen 4" microarchitecture, but which is based on the "Raphael" MCM, giving it a comprehensive PCIe Gen 5 I/O (as opposed to designing such a chip based on the "Phoenix Point" monolithic silicon with its PCIe Gen 4 I/O). The chip benefits from the full 32 MB on-die L3 cache being enabled on the "Zen 4" CCD, besides the full 1 MB per core L2 cache, and that I/O, but misses out on the iGPU. At its price, the 7400F is attracting a segment of value-conscious gamers.
To bring this chip at its price point, AMD had to cut costs somewhere, and Chinese PC enthusiast "Melon Master" soon found out where. On de-lidding (removing IHS) of the Ryzen 5 7400F, it was found that the chip does not use a soldered TIM like the other Ryzen 7000 series "Raphael" processors, instead using more cost-effective thermal paste, as is common in entry-level chips from both AMD and Intel. Harukaze5719 comments that this could be the reason the chip has a fairly noticeable Cinebench R23 performance delta against the Ryzen 5 7500F that's globally available, and has STIM, but is priced at $145. The 7400F and 7500F share the same base frequency of 3.70 GHz, but while the former boosts up to 4.70 GHz, the latter goes all the way up to 5.00 GHz.
14,298 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
So delidded versions should clock as high or higher if the cooling is adequate?
Ruru
S.T.A.R.S.
13,325 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Could be that 7500Fs are better binned chips. Just my pure guess though.
6,046 (0.83/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
It's a 100-buck CPU, not using solder is perfectly acceptable.
I miss the old days when we never needed IHS's on CPU and had direct die cooling.
I don't miss cracked dies due to overtorque.
2,083 (0.46/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Cooling Noctua NH-D15S
Display(s) EIZO CX240
Mouse Logitech G500S
Keyboard Keychron Q6
It's not acceptable, we all learned from the fiasco when Intel used paste on their 4th Gen CPU's.
Frick
Fishfaced Nincompoop
19,815 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
3,578 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
Only happened to overclocked SKUs like 4670K and 4770K and their younger siblings, 4690K and 4790K. These were by no mean 100-dollar chips. Even in today's money. i3s had perfectly reasonable temperatures.
I don't like it but only the overclockers suffered from this decision.
Ruru
S.T.A.R.S.
13,325 (3.00/day)
Jyväskylä, Finland
They used TIM from 3rd to 8th gen CPUs. 9th gen had soldered IHS only in K SKUs, I don't know about the later ones.
3,578 (4.98/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Storage Yes.
1,789 (0.33/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
The Ryzen 8000G APUs are also on conventional TIM. I'm considering deliding mine since it does run hot asf.
777 (3.98/day)
I doubt many consumers will be aware of that fact. Soldered vs cheap toothpaste between die and headspreader. (TIM)
I'm not sure if AMD does itself a good service when they sell such garbage. Regardless if 100€ or not, this is garbage. Make it easier for the consumer to change the TIM - or sell a proper product
477 (0.11/day)
Like it would have matered. Those people don't change even the regular paste. Only sales will show if it's garbage.
Ruru
S.T.A.R.S.
13,325 (3.00/day)
Jyväskylä, Finland
Yeah, and so far this is a China exclusive. Wouldn't be surprised if this would be an OEM-only CPU IF this is released in the West. I'm pretty sure that a typical prebuilt user doesn't even know what thermal paste is.
85 (0.13/day)
And it sucked on all of them.
Data point for you... My old Kaby Lake 7700k, I tested before and after replacing the TIM under the lid w/ liquid metal. 20 degC difference under full load. Way too significant to just laugh off.
Ruru
S.T.A.R.S.
13,325 (3.00/day)
Jyväskylä, Finland
Had about the same difference with 7700K. After delid, OC'd stably to 5.2GHz (AVX -2 offset).
