- Jan 8, 2009
- 551 (0.10/day)
System Name | AMD RyZen PC |
Processor | AMD RyZen 5950x |
Motherboard | ASUS Crosshair VIII Hero 570x WIFI |
Cooling | Custom Loop |
Memory | 64GB G.Skill Trident Z DDR4 3200 MHz 14C x4 |
Video Card(s) | Evga 3080 TI |
Storage | Seagate 8TB + 3TB + 4TB + 2TB external + 512 Samsung 980 |
Display(s) | LG 4K 144Hz 27GN950-B |
Case | Thermaltake CA-1F8-00M1WN-02 Core X71 Tempered Glass Edition Black |
Audio Device(s) | XI-FI 8.1 |
Power Supply | EVGA 700W |
Mouse | Microsoft |
Keyboard | Microsoft |
Software | Windows 10 x64 Pro |
I recently purchased 5950x and I am a bit concerned about the temps I see and want to know if this is normal. I am not sure about the temps as I upgraded from 3700 which use to show 55 as Max temp at stress test.
CPUZ screenshot
Idel temp
Stress test running Prim95 which is 57c and wont go beyond no matter how many hours I run it.
Running CPUZ stress test
Problem is that when I run CPUZ stress test. it goes to 75C :O
I have a 360MM radiator and Hydro X series Pump and Commander pro with CPU block. I am very much worried looking at the temp. I am also running CPU voltage offset - 0.123500 to ensure Asus hero VIII WIFI is not pushing too much V to the CPU...
I would like to know if the temps are normal or I should RMA for this temp. I googled it and getting different opinions and I am not convinced.
If I set the CPU voltage offset - 0.08250 then when I do, Stress test or Prime, all core goes to 4.7 too 4.73gz and temp goes up by 1 to 2c up to 77c
CPUZ screenshot
Idel temp
