AMD Ryzen 9 5950X WIFI - Blutooth MB suggestions
45 (0.03/day)
Just wondering if any of you could suggest any new motherboards for this processor without onboard video.
64 GB Min. RAM Preferably 128 GB Ram. Was hoping something new came out within the past year that wouldn't need a bios update and upgraded hardware.
132 (0.14/day)
USA
System Name Star Killer
Processor Intel 13700K
Motherboard ASUS RO STRIX Z790-H
Cooling Corsair 360mm H150 LCD Radiator
Memory 64GB Corsair Vengence DDR5 5600mhz
Video Card(s) MSI RTX 3080 12GB Gaming Trio
Storage 1TB Samsung 980 x 1 | 1TB Crucial Gen 4 SSD x 1 | 2TB Samsung 990 Pro x 1
Display(s) 32inch ASUS ROG STRIX 1440p 170hz WQHD x 1, 24inch ASUS 165hz 1080p x 1
Case Lian Li O11D White
Audio Device(s) Creative T100 Speakers , Razer Blackshark V2 Pro wireless
Power Supply EVGA 1000watt G6 Gold
Mouse Razer Viper V2 Wireless with dock
Keyboard ASUS ROG AZOTH
Software Windows 11 pro
This board would work well with that cpu, as far as power delivery and ram goes. Solid option for that price.
2,958 (2.63/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Display(s) LG 27UL850W (4K@60Hz IPS)
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.5 (with latest patches)
I have the ASUS ROG Strix B550-E -- a close relative of the B550-F model. It's currently hosting a Ryzen 5800X but has also hosted a 5900X at one time. WiFi and Bluetooth work fine. Both models will be fine for your 5950X.
The Zen 3 processors have been out for a while, any motherboard rolling off the manufacturing line will have a compatible BIOS.
45 (0.03/day)
Thanks for the reply's. I was hoping I could find a board without onboard video ports.
Any suggestions?
2,958 (2.63/day)
Any suggestions?
You will likely need to focus your search on high-end motherboards. Normal consumer boards will all have onboard video ports because the target audience will consider APUs as viable options.
My guess is that all of the B550 motherboards will have onboard video ports. You really need to focus on the top tier X570 boards.
Best of luck.
5,840 (2.96/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
What's the problem with onboard video ports? They won't do a thing unless you have a G cpu.
680 (0.11/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 3950X
Motherboard GIGABYTE X570S AERO G
Cooling Be Quiet Black Rock 4 Pro
Memory HyperX 128GB Fury 4×32GB 3200MHz HX432C16FB3K4/128
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 970PRO 500GB + Samsung 980PRO 2TB + Adata SX8200 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic PRIME GOLD 850W
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/4d8n02 https://www.techpowerup.com/gpuz/g46uc
What is the purpose of the build?
Also, since the "onboard" graphics is located in the CPU chip (if present) means the mainboard needs a port
That is why you see almost all the mainboards with useless DP and HDMI ports. (Except for a few) So you have to deal with this.
45 (0.03/day)
Building for a AMD Ryzen 9 5950X. No onboard video. No Video Ports needed on board. Wasted space. Not needed.
Purpose of build - Build and keep it for 10 years.
This is a good board, yes?
Also want a board to hold 3 GPU's. This would fit the profile - Yes?
680 (0.11/day)
Hungary / Budapest
System Name Kincsem
That one more or less fits the bill, but if you opting for such a long time would recommend find one with a 10Gbps LAN
So I might show this:
It has Tunderbolt 4 which is 2 times faster than the USB3.2×2 port the MSI got,
It also have a 4 times faster ethernet port which might be handy down the line.
But you have to tolerate the unwanted DP and HDMI ports, I would say it's a great trade off.
Also, consider exclusive the limitations of third PCIe ports, regardles what AM4 board you choose!
Do you already own the AMD R9 5950X?
dgianstefani
TPU Proofreader
4,683 (1.96/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Display(s) 32" 240 Hz 1440p Samsung G7, 31.5" 165 Hz 1440p LG NanoIPS Ultragear
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+ module, TOFU Redux Burgundy w/brass weight, Prismcaps White, Jellykey, lubed/modded
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
I would suggest one of the x570 refresh motherboards without chipset fans. EVGA Dark is good, the updated ROG HERO etc
If you haven't bought the 5950x yet, I would strongly recommend the i9-12900k instead, it's very close in MT performance but significantly faster in ST performance, has none of the USB issues of Ryzen, supports DDR5/PCIE 5.0 etc. Much better future proof board level features.
The 12900k is around 15-20% faster per core, but around 10% slower in ideal MT (all 32 threads used of the 5950x)
Z690 boards will also support raptor lake which will double the E cores from 8 to 16, so there's a potential drop in upgrade.
From someone with a 5950x tuned to the limit - the 12900k is better.
ST performance is always relevant, MT performance is sometimes relevant.
680 (0.11/day)
Hungary / Budapest
System Name Kincsem
45 (0.03/day)
Thanks For the link
So the limitations on running three GPU's on AMD A4 chipset is that they can only run in 8x speed?
And if you want the newest x16 speed GPU, you can only utilize ONE GPU? Did I read this correctly?
680 (0.11/day)
Hungary / Budapest
System Name Kincsem
Thanks For the link
This is also the same with the Z690 and other Intel chips, also:
Do not worry about that 8×PCIe(v4) is still provide more bandwidth than the current graphics cards are need.
I talking about the third slot, which might get disabled if you use the m.2 which are on the same switch.
This is why I mentioned the AMD Threadripper, if you need extreme connectivity.
The TRX40 have 72 lanes, over the regular 24. Now you understand why are those so "expensive"
45 (0.03/day)
Thank You for the help. I'm not too familiar with the modern architecture and terminology.
So based on the article you pointed me to and the diagram you just posted a link to, I am trying to understand that even the newest GPU card can still run at maximum potential using only the 4x speeds if I want to use 3 of them? How can I know if the 3rd slot will get disabled when using 2? I don't think I'm going to use Intel. Every Computer I built has been AMD, and their architecture has improved.
So far I am liking this board:
As I said I would like to 3 GPU's - all three of the newest design.
And I still want to be able to use M2_4 Storage.
Is that Possible with this board?
Expansion Slots
PCI Express 4.0 x16 3 x PCI Express 4.0 x16*
* Actual support may vary by CPU.
* PCI_E4 supports x8.
* PCI_E4, M2_3, M2_4 and SATA5~8 share the same bandwidth.
PCI Express x1 1 x PCI Express x1*
* The PCIe x1 slot and onboard Wi-Fi module share the same bandwidth, you can not use both of them simultaneously, and the default setting is the Wi-Fi module for the system. Please disable the Onboard Wi-Fi Module Control in BIOS if you want to use the PCIe x1 slot.
Storage Devices
SATA 6Gb/s 8 x SATA 6Gb/s
M.2 4 x M.2 slots (Key M):
Supports PCIe 4.0 / PCIe 3.0
PCIe 4.0 is available only on AMD Ryzen 5000 Series and 3000 Series desktop processors
Support SATA 6Gbps (For M2_1, M2_3 & M2_4)
M2_1 (From processor):
Supports 2280/22110 storage devices
M2_2 (From X570 chipset):
Supports 2260/2280 storage devices
M2_3 * (From X570 chipset):
M2_4 * (From X570 chipset):
SATA RAID 0/1/10
680 (0.11/day)
Hungary / Budapest
System Name Kincsem
@StOmPeR
I've checked the manual, it maybe available for the 3rd GPU with a PCIe 4× connection, but then you cannot use SATA5/ 6/ 7/ 8, no biggie there but you also need to forget M2_3
I can't tell if 4×PCIe v4 is enough for a modern GPU, my bet is NO, but you can open an other thread for that.
So if you really want 2+ GPUs to run, look into the TRX40 systems with the Threadrippers
Here is the MSI MEG X570S ACE MAX PCIe diagram:
45 (0.03/day)
A M2_4 Storage device is the newest upgraded version of SSD's correct?
If So.. then I could use a M2_4 with no problem as long as I only had one GPU?
680 (0.11/day)
Hungary / Budapest
System Name Kincsem
All of the m.2 are Gen4 PCIe 4× on the MSI MEG X570S ACE MAX, you can use the M2_1 and M2_2 with no restrictions regarding how many GPUs you use.
If you using the first two PCIe16× slots you shall be able use all 4 m.2 ports with full speed.
