AMD Ryzen 9 7950X Hits 7.25 GHz Under Extreme Cooling, 6.50 GHz All-Core
47,229 (7.55/day)
It's game on for clock-speed records, as some of the first ones are being set with the AMD Ryzen 9 7950X "Zen 4" processors. The first such feat is an absolute clock-speed record of 7.25 GHz (7247 MHz), set without disabling any cores. This is probably the highest clock achieved on a single core for "Zen 4," set using a multiplier value of 72.5x, and a scorching 1.506 V juice. The second feat is even more impressive, even though it's a lower-clock speed in absolute terms. The 7950X was overclocked to 6.50 GHz across all cores (that's all 16 of its cores). This was set using a core voltage of 1.465 V. In both feats, extreme cooling solutions such as liquid-nitrogen evaporators were used, and this only the first round of OC feats with these chips. Interesting times ahead for 7950X vs. i9-13900K overclocking and benchmark feats. The 6.50 GHz all-core OC in particular could pose a formidable challenge to the i9-13900K, which can sustain its maximum (5 GHz+) all-core OC clocks only on its 8 P-cores.
487 (0.60/day)
System Name Firestarter
Processor 7950X
Motherboard X670E Steel Legend
Cooling LF 2 420
Memory 4x16 G.Skill X5 6000@CL36
Video Card(s) RTX Gigabutt 4090 Gaming OC
Storage SSDS: OS: 2TB P41 Plat, 4TB SN850X, 1TB SN770. Raid 5 HDDS: 4x4TB WD Red Nas 2.0 HDDs, 1TB ext HDD.
Display(s) 42C3PUA, some dinky TN 10.1 inch display.
Case Fractal Torrent
Audio Device(s) PC38X
Power Supply GF3 TT Premium 850W
Mouse Razer Basilisk V3 Pro
Keyboard Steel Series Apex Pro
VR HMD Pimax Crystal with Index controllers
Haha, pc go brrrrrrrrrr, number go higher.
1,819 (0.63/day)
Clock speed advantage neutralized amongst both parties. It’s all about the IPC in the apps most important to you now.
1,749 (0.60/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
For some...for me, I will continue to support AMD even if Intel is 5%-10% faster as it's in the best interests of all consumers for AMD to get as close as possible to 50% marketshare to achieve a balance of power between them and Intel. AMD and Intel being at parity is what will result in the best possible situation for consumers, but If the day ever comes where AMD has a majority of the marketshare, then I will support Intel.
1,819 (0.63/day)
I agree. Same goes for the GPU market IMHO.
1,568 (0.66/day)
London, UK
7950x is the top bin silicon, so only good results, 7.2ghz at 1.50v is incredible even if is 1 core and cannot even run a benchmark.
460 (0.31/day)
Earth, Solar System, Milky Way Galaxy, Local Group
Processor AMD Ryzen 7 5700X
Motherboard Asus TUF Gaming B550M-Plus (Wi-Fi)
Cooling Thermalright PA120 SE; Arctic P12, F12
Memory Crucial BL8G32C16U4W.M8FE1 ×2
Video Card(s) Sapphire Nitro+ RX 6600 XT
Storage Kingston SKC3000D/2048G; Samsung MZVLB1T0HBLR-000L2; Seagate ST1000DM010-2EP102
Display(s) AOC 24G2W1G4
Case Sama MiCube
Audio Device(s) Somic G923
Power Supply EVGA 650 GD
Mouse Logitech G102
Keyboard Logitech K845 TTC Brown
Software Windows 10 Pro 1903, Dism++, CCleaner
Benchmark Scores CPU-Z 17.01.64: 3700X @ 4.6 GHz 1.3375 V scoring 557/6206; 760K @ 5 GHz 1.5 V scoring 292/964
Again this doesn't mean a lot. I'd still rather have more power efficiency.
232 (0.04/day)
System Name 3950X Workstation
Processor AMD Ryzen 9 3950X
Motherboard ASUS Crosshair VIII Impact
Cooling Cryorig C1 with Noctua NF-A12x15
Memory G.Skill F4-3600C16D-32GTZNC
Video Card(s) ASUS GTX 1650 LP OC
Storage 2 x Corsair MP510 1920GB M.2 SSD
Case Realan E-i7
Power Supply G-Unique 400W
Benchmark Scores https://smallformfactor.net/forum/threads/the-saga-of-the-little-gem-continues.12877/
I will support AMD until they reach 80-90% marketshare and observe what they do with it. We know that about Intel.
133 (0.16/day)
Processor i7-7700k @5ghz
Motherboard Asus strix Z270-F
Cooling EK AIO 240mm
Memory Hyper-X ( 16 GB - XMP )
Video Card(s) RTX 2080 super OC
Storage 512GB - WD(Nvme) + 1TB WD SDD
Display(s) Acer Nitro 165Hz OC
Case Deepcool Mesh 55
Audio Device(s) Razer Karken X
Power Supply Asus TUF gaming 650W brozen
Mouse Razer Mamba Wireless & Glorious Model D Wireless
Keyboard Cooler Master K70
Software Win 10
AMD is getting near in GHz to intel :) - Need to wait for 13th IPC gains nos. that is the only thing left to compare :)
