AMD Ryzen Threadripper to Include Asetek Retention Kit in Retail Package
Raevenlord
3,755 (1.24/day)
Portugal
System Name The Ryzening
Processor AMD Ryzen 9 5900X
It seems that previous rumors of AMD bundling a water cooling solution with their premium HEDT Threadripper line of CPUs both were and weren't quite close to the mark. It appears that no, there won't be a liquid cooling solution shipped with the high-performance, high core-count processors after all - as a quick look at the leaked Threadripper retail packaging might convey due to the laws of physics and size constraints.
Even so, it seems AMD will be shipping a solution for water cooling of sorts... By including an Asetek-compatible retention kit with their retail packages of Threadripper. Asetek's designs are shipped under the company's own brand, as well as in a number of recognized, high-quality brands, such as NZXT's Kraken series, EVGA's CLC Series, and some of Corsair's coolers (such as the H100iV2 and the H115i coolers.) Though with Threadripper's IHS's giant size, it is likely that most water cooling solutions currently on the market won't have a sufficiently-sized base plate to cover the entire IHS area. Effects of this on cooling performance remain to be seen, though it probably won't improve temps.
2,074 (0.47/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
Actually, this is a decent compromise, because most people wouldn't want to use a 1 single 120mm rad for this beast anyway; this let's you choose from a large variety of AIO coolers.
Deleted member 172152
True. Besides, i'm an aircooling fan and since I'm only building my pc in september, I'm hoping noctua will have released that HUGE tr4/sp3 nh-d15 derivative!
11,878 (2.21/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Im starting to think monoblocks are the best way going forward because the size of these cpus is just ,wow , same with intels new Hedt or is it Uedt i dunno.
OneMoar
There is Always Moar
8,795 (1.65/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
there is nothing high-quality about asetek AIO's
avoid like the plague
18,584 (2.70/day)
System Name AlderLake
989 (0.18/day)
Michigan
System Name Daves
Processor AMD Ryzen 3900x
Case Phanteks P600S
Audio Device(s) N/A
Power Supply Corsair RM 750
Mouse EVGA
Keyboard Corsair Strafe
This!
OneMoar
8,795 (1.65/day)
Rochester area
yall are forgetting that AIO's come with mounting brackets
Why is this news ?
next up intel ships new i9 with retention bracket for stock cooler
2,074 (0.47/day)
Jacksonhole Florida
Why is this news ?
Because I'm guessing that none of them come with a Threadripper compatible bracket yet? This removes a possible snag in early builds. I'll bet even the major custom loop companies EGWB, Aquacomputer, Swiftech, etc. are struggling to catch up with this lack on this brand new platform, with it's huge footprint.
OneMoar
8,795 (1.65/day)
Rochester area
brackets are usually available at no or minimal charge with the release of a new socket thats always been the case for custom cooling
703 (0.14/day)
Pensacola, FL, USA, Earth
1. "Usually" but not always.
2. Like with the Corsair AM4 bracket kits, a bajillion people ordered the kit for free when they were first coming out. Took some people *weeks* or longer to get them. Some people ended up having to wait to finish their system.
For those reasons and I am sure others as well, it's nice that they are putting on in the box.
989 (0.18/day)
Michigan
System Name Daves
Case Phanteks P600S
Audio Device(s) N/A
Mouse EVGA
This!
350 (0.06/day)
NYC
Processor Intel Core i7 8700K
Motherboard ROG STRIX Z370-G GAMING AC
Cooling Corsair H115i Pro RGB
Memory G.Skill Trident Z RGB 16GB DDR4 3200Mhz
Video Card(s) Gigabyte GTX 1070 G1
Storage Samsung 970 Evo 500GB
Display(s) Dell S2417DG 165Hz
Case NZXT H400i
Power Supply Corsair AX760
Mouse Razer Deathadder Chroma
Keyboard Cooler Master - Masterkeys Pro L RGB
Software Windows 10 Pro 64Bit
Who's concerned about the bracket for aio's for threadripper? I doubt any aio has a big enough cooling plate anyway. Useless tool.
10 (0.00/day)
This isn't true AT ALL. AMD has officially stated that cooling blocks for Threadripper don't need to, and in nearly all cases WON'T cover the Threadripper package's entire IHS (go check out the Asetek block on the Alienware's new Threadripper model; which is the exclusive/flagship TR pre-built, at least for a while). As there are only 2 dies underneath the IHS, instead of 4 like in EPYC, you only need to cover the central part of the IHS with the cooling block to properly cool Threadripper. The only reason the IHS is so big is because the package was designed to house a total of 4-dies, not 2.
2,074 (0.47/day)
Jacksonhole Florida
The pictures of the Alienware Threadripper model show a round block/pump, possibly Asetek, but it looks a bit larger than most, by a few mm, since it covers most of the large bracket. The contact plate may be standard sized, it's not shown from that side. http://cdn.wccftech.com/wp-content/...n-Threadripper-and-Intel-Core-X_2-740x494.jpg
10 (0.00/day)
My point still stands though, it's brought in notably from the corners of the chip package making it impossible for it to cover the entire IHS. This is probably a TR4 exclusive cooler as well, and thus larger in cooling block size then is probably needed, considering how small the 2 dies are in comparison to the size of the IHS/chip package. Covering up as much of that extra IHS space as you can, as you see here (though even here they don't go for a massive, full coverage block) I'm sure helps, but it's not necessary; AMD wouldn't be including a bracket if these commonly available AIO coolers weren't going to work. As long as the cooling block/plate covers the central portion of the IHS and the 2 Zeppelin dies underneath, it'll be fine (assuming it can cool a 180W chip that is, of course).
2,388 (0.63/day)
Shenandoah Valley, Virginia USA
System Name Home Brewed
Processor i9-7900X and i7-8700K
Motherboard ASUS ROG Rampage VI Extreme & ASUS Prime Z-370 A
Cooling Corsair 280mm AIO & Thermaltake Water 3.0
Memory 64GB DDR4-3000 GSKill RipJaws-V & 32GB DDR4-3466 GEIL Potenza
Video Card(s) 2X-GTX-1080 SLI & 2 GTX-1070Ti 8GB G1 Gaming in SLI
Storage Both have 2TB HDDs for storage, 480GB SSDs for OS, and 240GB SSDs for Steam Games
Display(s) ACER 28" B286HK 4K & Samsung 32" 1080P
Case NZXT Source 540 & Rosewill Rise Chassis
Power Supply Corsair RM1000 & Corsair RM850
Mouse Generic
Keyboard Razer Blackwidow Tournament & Corsair K90
Software Win-10 Professional
Benchmark Scores yes
When ThreadRipper is ready to ship, we'll see plenty of coolers for sale that will cool it. I'll probably wait for reviews and buy the cooler first.
I also have to sell some of the systems that I have now, just to afford ThreadRipper.
3,807 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
That will make it easier to cool so its not a disadvantage in that regard.
OneMoar
8,795 (1.65/day)
Rochester area
here is the deal: the reason amd said what they said about ryzen IHS only partially needing to be covered is because if they didn't say that every single cooler manufacturer would need to re-tool to make a cooler to fit the monstrosity and they would sell no chips
the stop gap solution was for AMD to say "this is fine" and sacrifice a huge chuck of cooling performance to get chips out the door
its also the reason why it doesn't come with any box cooler. A AIR cooler could't do the job well enough with the given surface area most have even the crappiest AIo has a contact patch 20% larger then the biggest air cooler
4,542 (0.91/day)
Most people will be using AIOs from A**tek anyways so its nice to see mounting kit bundled with the box itself. Nice job by AMD.
432 (0.09/day)
Technically all current AIOs should do the trick at least short term before "designed for TR4" become available. Large IHS plate means nothing. Cores are tightly packed in the middle and in general cooling plate is not required to cover IHS entirely when we talk even most basic liquid cooling (especially with cores being soldered not taped with piece double sided tape :p, yeah Chipzilla you cheap-o-corp).
Don't have Asestek AIOs but its nice addition on AMD part. I hoping for even most basic aircooler with the CPU, just for the sake of testing the chip after it arrives. After that I'll slap waterblocks and won't look back. :)
2,388 (0.63/day)
Mouse Generic
Check this out.
Installation is designed to be as problem free as possible. Goodby bent pins,............
2,074 (0.47/day)
Jacksonhole Florida
2,388 (0.63/day)
Mouse Generic
Imagine all four of these running at one time,......
Yeah, I can dig it!
