AMD Sapphire RX 580 show 0 clock Mhz and 0 memory Mhz
chenny2021
9 (0.01/day)
Hi all,
Here I have one problem with my GPU model Sapphire RX580.
the problem is that it sometimes blue screen after running a while.
and when restart the PC, the device manager shown error 43 that "windows has stop the device......"
and I opened GPU-Z, it show the GPU basic information, but the clock and memory shown as 0 for both.
the very strange thing is that a few days later, I turn on the PC with this GPU and it works fine, but not long.
about few hours, it went throungh the same problem again!
Sometimes it is even not able to restart.
I have tried to flash the BIOS with the original BIOS download from TechPowerUP.
and also tried to update the driver by latest version.
but all failed with same problem.
I am really need some help from here to see if can solve this problem.
Thanks in advance!
chenny2021
9 (0.01/day)
I have downloaded all Nitro+ RX580 BIOS from database, but it seems the P/N of each BIOS is different.
will it affect the dual BIOS?
current GPU Dual BIOS, left side silent mode is 113-1E366CU-S52 (1340Mhz), while the right side is 113-1E3660U-O51 (1411Mhz)
So the issue of this GPU is after running for some times, it just stopped and PC is hang and not functioning.
have to hard restart PC.
@eidairaman1 could you please give some guidance and advice? thanks in advance!
41,782 (6.60/day)
Give me time. Im eating supper
I need complete system specs of your system
You need to pull the heatsink, clean gpu die, get a pic of a ram chip and put fresh thrrmal paste on the card. Im verifying what ram is on your card
@chenny2021
chenny2021
9 (0.01/day)
@chenny2021
Thanks dude! Appreciated!
My PC spec is
CPU: Intel i5-4590
Ram: 8G+8G+4G = 20 Gb total
Harddisk: Hitachi HDS721010CLA630
Motherboard: Asrock B85iCafe4
attached is photo of the GPU memory chip.
Mussels
Freshwater Moderator
58,413 (7.97/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Oh my god what happened with that thermal paste??
4,930 (0.75/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
Yeah GPUs usually comes with the grey type that is more sticky, this looks almost like toothpaste :respect:
I hope who ever repasted the gpu didn't actually just use toothpaste on it.
7,762 (2.84/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
41,782 (6.60/day)
My PC spec is
CPU: Intel i5-4590
What make,model of power supply?
@chenny2021
41,782 (6.60/day)
PSW: seasonic SS-520GB 450Watts
Thanks
I will start looking
I would suggest cleaning the gpu die and heatsink, remove thermal paste and get some good paste from Arctic, Arctic Silver, Coolermaster, Gelid, Thermal Grizzly.
Do not flash anything yet.
1411/2000
FC Samsung (timings are exactly the same)
2019 08 12
Mussels
58,413 (7.97/day)
Oystralia
That looked like an entire tube of moisturiser, definitely clean that off with isopropyl alcohol and use a grain of rice sized blob of actual thermal paste
chenny2021
9 (0.01/day)
1411/2000
2019 08 12
Hi Sir,
Yes, I have cleaned up the thermopatse with new one.
But it is still having problem with the GPU.
Now there is error code 43 in my device manager with the display adapter also exclamation mark.
BTW, attached is the Validation code from GPU-Z for your reference.
Thanks
41,782 (6.60/day)
Was your card reading 0 0 on gpu-z?
Hi Sir,
Thanks
41,782 (6.60/day)
Yes, below is screenshot of the GPU-Z with 0 clock Mhz and 0 Memory Mhz.
First you need to watch this to prevent ms from installing drivers.
If you have any overclocking utilities outside of the adrenaline driver, reset them to stock and remove them.
Then Get Display Driver Uninstaller.
Run the Adrenaline Driver uninstall program, then run DDU. Once done, shut down totally, remove the gpu, clean contact pins and blow out dust from pcie slots.
Then reinsert gpu into slot firm and squared, make sure the board is not putting tension on the slot.
I will research bios
Verified bios
1411/2000
2018 07 19
2017 03 23
2017 03 20
1340
2017 03 23
Unverified bios
1411
Latest
2019 08 12
2018 07 19
Those are all compatible with your card, if none work, contact sapphire for help,
All are 1002 67DF 1DA2 E366
@chenny2021
chenny2021
9 (0.01/day)
Verified bios
1411/2000
2018 07 19
2017 03 23
2017 03 20
1340
2017 03 23
Unverified bios
1411
Latest
2019 08 12
2018 07 19
@chenny2021
Big thank you for your help and suggestion!
I will try them out and let you know the result.
Appreciated!
41,782 (6.60/day)
1,891 (1.47/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 6600XT 8GB / XFX RX 5700XT THICC III Ultra 8GB
Storage 1st : 1x SSD Samsung 980 Pro 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 980 Pro 1Tb
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Seasonic Focus 850 W / Seasonic Focus 850 W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
No luck on the bios, going to sent to repair shop.
Thanks for all the help from here!
Hello
After you receive back the video card please inform us how it went.
Cheers
