AMD Strix Point SoC "Zen 5" and "Zen 5c" CPU Cores Have 256-bit FPU Datapaths
46,821 (7.63/day)
AMD in its architecture deep-dive Q&A session with the press, confirmed that the "Zen 5" and "Zen 5c" cores on the "Strix Point" silicon only feature 256-bit wide FPU data-paths, unlike the "Zen 5" cores in the "Granite Ridge" Ryzen 9000 desktop processors. "The Zen 5c used in Strix has a 256-bit data-path, and so does the Zen 5 used inside of Strix," said Mike Clark, AMD corporate fellow and chief architecture of the "Zen" CPU cores. "So there's no delta as you move back and forth [thread migration between the Zen 5 and Zen 5c complexes] in vector throughput," he added.
It doesn't seem like AMD disabled a physically available feature, but rather, the company developed a variant of both the "Zen 5" and "Zen 5c" cores that physically lack the 512-bit data-paths. "And you get the area advantage to be able to scale out a little bit more," Clark continued. This suggests that the "Zen 5" and "Zen 5c" cores on "Strix Point" are physically smaller than the ones on the 4 nm "Eldora" 8-core CCD that is featured in "Granite Ridge" and some of the key models of the upcoming 5th Gen EPYC "Turin" server processors.
One of the star-attractions of the "Zen 5" microarchitecture is its floating-point unit, which supports AVX512 with a full 512-bit data path. In comparison, the previous-generation "Zen 4" handled AVX512 using a dual-pumped 256-bit FPU. The new 512-bit FPU, depending on the exact workload and other factors, is about 20-40% faster than "Zen 4" at 512-bit floating-point workloads, which is why "Zen 5" is expected to post significant gains in AI inferencing performance, as well as plow through benchmarks that use AVX512.
We're not sure how the lack of a 512-bit FP data-path affects performance of instructions relevant to AI acceleration, since "Strix Point" is mainly being designed for Microsoft Copilot+ ready AI PCs. It's possible that AVX512 and AVX-VNNI are being run on a dual-pumped 256-bit data-path similar to how it is done on "Zen 4." There could be some performance/Watt advantages to doing it this way, which could be relevant to mobile platforms.
613 (0.66/day)
That is going to be nasty in the future when there is no feature parity and software that runs fine on zen5 desktop that won’t be running on zen 5 laptop/mini/aio
481 (0.22/day)
There's no incompatibility here.
All Zen 5/5c cores support the exact same instructions. It's only the internal execution pipeline that's fully 512-bit wide on desktop/server variants and "2x256"-bit on mobile. With the latter being very close to what Zen 4/4c was doing I suppose.
613 (0.66/day)
Sure and in say 5 years or so, some very popular software is going to need the full 512 to fully function and the double pumped one isn't going to be enough.
I was seriously bummed out as a kid when my 486SX2 wouldn't play quake
481 (0.22/day)
486SX couldn't run Quake because it was a processor without a FPU, so it was unable to execute x87 instructions needed by the game.
In this situation all Zen 5 variants support the same instruction sets including AVX-512. From software perspective there is no difference between them other than execution speed.
3,028 (1.03/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
First, no developer making a mass-market app is going to develop a product with AVX 512 support and not have a fall back implementation. Not unless you are talking something very niche where the dev knows people who use their app all have newer hardware. There will still be a significant chunk of users without AVX 512 support in 5 years, devs won't just up an abandon them.
Second, people using CPUs with double pumped AVX 512 do in fact have AVX 512 support. They will be able to use the app unlike in your scenario where you could not play quake. Double pumped AVX512 is pretty performant on Zen 4 processors and I expect the same to apply to these mobile processors as well.
The mobile CPUs being double-pumped is a non-issue for compatibility.
238 (0.21/day)
Considering how AMD put in the Geekbench AES benchmark to calculate that IPC increase, this change will probably have a pretty signficant decrease if you were to calculate the IPC from the same benchmarks as AMD did.
W1zzard
Administrator
27,279 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
This won't be the case, to software there is no detectable difference, these are the exact same instructions. It's just that the 512-bit datapath runs faster than the other (not by a factor of 2)
1,882 (0.70/day)
Tanagra
System Name Budget Box
Processor Xeon E5-2667v2
Motherboard ASUS P9X79 Pro
Cooling Some cheap tower cooler, I dunno
Memory 32GB 1866-DDR3 ECC
Video Card(s) XFX RX 5600XT
Storage WD NVME 1GB
Display(s) ASUS Pro Art 27"
Case Antec P7 Neo
I think you're more likely to run into some app that won't run without an NPU, but even that should fall back to the GPU in a pinch. I can't imagine any popular software targeting specific hardware, especially something like AVX512, where desktop Intel processors since Adler Lake don't support that feature at all. It's coming back again, but talk about a setback if you're hoping for popular consumer adoption.
2,978 (2.29/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
The AVX512 units don't only perform FP operations but also integer and bitwise operations on vectors. I don't know enough to judge but those may have a bigger impact on games and other consumer workloads than FP operations if the performance is halved or significantly reduced. Integer math is used everywhere, FP math has a narrower range of usability.
218 (3.35/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-48 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Audio Device(s) Sound Blaster AE-7
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
Current benchmark results seem to point towards games and consumer workloads not making good use of such features anyway, outside a few exceptions. But the capability had to be there first. Capability one of the major makes is no longer (or not yet with AVX10) providing.
I think applications making really good use of AVX512 tends to be memory bandwidth bound, if not load/store bound, on current consumer hardware, anyway.
Back on topic, I wonder whether it had anything to do with more than power consumption and efficiency, and whether there would be a separate moniker for these reduced cores.
tabascosauz
7,904 (2.38/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Is there really that much significance in this difference of true AVX-512 capability vs. AVX-512 on 256-bit hardware? APU dies were born with and have never escaped the half L3 curse. We have already been expecting poorer CPU performance in all aspects from them every year since 2017, so this is just more of the same.
