AMD to Build Next-Gen I/O Dies on Samsung 4nm, Not TSMC N4P
47,498 (7.49/day)
Back in January, we covered a report about AMD designing its next-generation "Zen 6" CCDs on a 3 nm-class node by TSMC, and developing a new line of server and client I/O dies (cIOD and sIOD). The I/O die is a crucial piece of silicon that contains all the uncore components of the processor, including the memory controllers, the PCIe root complex, and Infinity Fabric interconnects to the CCDs and multi-socket connections. Back then it was reported that these new-generation I/O dies were being designed on the 4 nm silicon fabrication process, which was interpreted as being AMD's favorite 4 nm-class node, the TSMC N4P, on which the company builds everything from its current "Strix Point" mobile processors to the "Zen 5" CCDs. It turns out that AMD has other plans, and is exploring a 4 nm-class node by Samsung.
This node is very likely the Samsung 4LPP, also known as the SF4, which has been in mass-production since 2022. The table below shows how the SF4 compares with TSMC N4P and Intel 4, where it is shown striking a balance between the two. We have also added values for the TSMC N5 node from which the N4P is derived from, and you can see that the SF4 offers comparable transistor density to the N5, and is a significant improvement in transistor density over the TSMC N6, which AMD uses for its current generation of sIOD and cIOD. The new 4 nm node will allow AMD to reduce the TDP of the I/O die, implement a new power management solution, and more importantly, the need for a new I/O die is driven by the need for updated memory controllers that support higher DDR5 speeds and compatibility with new kinds of DIMMs, such as CUDIMMs, RDIMMs with RCDs, etc.
290 (0.16/day)
The SRAM cell size and interconnect pitch are both similar to TSMC's N6. Those are significant factors for density. But it's the speed/power profile that will really be the telling in the end, and that is not listed.
dgianstefani
TPU Proofreader
5,284 (2.03/day)
Swansea, Wales
Benchmark Scores Legendary
AMD and skimping on IO die. Name a better duo.
848 (0.14/day)
System Name HTPC whhaaaat?
Processor 2600k @ 4500mhz
Cooling Noctua NH-C14
Memory Gskill Ripjaw 2x4gb
Display(s) Vizio P 65'' 4k tv
Case Lian Li pc-c50b
Audio Device(s) Denon 3311
Power Supply Corsair 620HX
Makes sense to me...All they really need is 7200mhz support given that's the capability of decent cheap ram these days. Raise voltage/tighten timings iyw.
I think if people can max out Cas32/34 with something like this they'll be plenty happy.
FWIW, 7200mhz would already essentially negate the purpose of X3D of 8-core chips, more-or-less, which is likely why AMD is moving to 12-core CCDs.
Like-wise, the newer memory controller *should* essentially increase PPC on the normal architecture quite a bit, which is something a new generation needs and this generation didn't really have.
  • Like
Reactions: N/A
35 (0.01/day)
Norway
System Name ExcaliBuR
Processor Ryzen 7 7800X3D
Motherboard Asus ROG STRIX X670E-I Gaming
Cooling Lian Li GA II LCD 280MM
Memory G.Skill Trident Z5 Neo 32GB x 2 6000C30
Video Card(s) Sapphire Radeon 7900 XTX Pulse!
Storage 2x4TB Samsung 990 Pro
Display(s) Samsung G8 OLED 34"
Case Ssupd Meshliciuos
Audio Device(s) Edifier SPIRIT STAX S3
Power Supply Corsair SF750
Mouse SteelSeries Aerox 3 Wireless
Keyboard Steelseries Apex Pro TKL Wireless
VR HMD HP Reverb G2
Software W11
Does Samsung have any notable good remarks in that area?
1,104 (0.98/day)
So no npu on the io die for zen6, and I’m kinda getting the feeling zen 6 won’t be am5 if bih this and 12 core ccd are true.
3,504 (0.84/day)
Athens, Greece
I wonder how many wafers at TSMC AMD is saving with this move, so they can build more GPUs and CPUs with those TSMC wafers that they have available.
Also they will start gaining experience on Samsung's nodes, meaning, later they could transition some of their chips on Samsung's fabs. The next UDNA series could have low end GPUs on Samsung nodes and mid - hopefully - high end GPUs on TSMC nodes. A 130W low end GPU made by Samsung instead of a 110W low end GPU made by TSMC, wouldn't be a dissaster, for example. It will mean more waffers for those mid-high end GPUs made by TSMC. Considering TSMC is also increasing prices, this migth be necessary.
848 (0.14/day)
Here's a good one: fixed function and analog logic gates and their inability to benefit greatly from process density scaling.
The improvement from 7->5nm is still there (at TSMC).
I've gotta believe they'll go from supporting 6000->7200mhz(+), and even if Samsung is only 20% that's fine. Realistically it would be what, ~6200/6300->~7600mhz?
Even if they only can guarantee CL30/6400 or CL32/6800 that would still be okay. The lack of guaranteed CL30/6400 really hurts them the most, imho.
DGMW, I'd love to see 8000mhz(+) support, maybe a 4x ratio instead of 3x, and even CUDIMMs, and hope we do.
I just wonder if they really want that given they make a ton of money selling V-cache parts and the higher memory scales the less attractive they will look.
But again, 12 cores instead of 8...so idk. We'll have to see what they do wrt inherent cache structure as well as v-cache (amount) to see what really makes the most sense and what their plan is going to be.
This is a fair point. While TSMC gets the press, there will reach a point where inevitably Samsung (heck, even Rapidus) will have decent 2nm output and likely quality.
Never hurts to prepare. I'm not saying they'll be better, I'm not saying they'll have the same volume...but you're right to say it's good to be prepared to have the option.
Getting familiar with how their SDK/nodes work is not a bad idea, even if starting with something small/more-simple such as like this.
7,689 (1.78/day)
And yet do you have numbers to prove "how much" just for the I/O die? You're forgetting this will free up AMD to have more CPU/GPU actually being fabbed at better nodes!
534 (0.35/day)
Processor Ryzen 5 7600X
Motherboard ASRock B650M PG Riptide
Memory DDR5 6000Mhz CL28 32GB
Video Card(s) Nvidia Geforce RTX 3070 Palit GamingPro OC
Storage Corsair MP600 Force Series Gen.4 1TB
TSMC 6nm is not used for any existing hardware anymore, the last produced hardware is part of RX7000 and Intel's Alchemist, but both are no longer manufactured
848 (0.14/day)
I do not, yet I don't think it's unfair to assume it still scales some in capability and/or density if SRAM is scaling. The real slowdown didn't hit until 3nm.
I don't get the analogy of not using TSMC N4P so it frees up N3E/N2 space. :p
I hear ya, tho. I'm not judging. Like I said; I think they need an improvement over what they have, but also don't need anything super drastic, so Samsung is okay if it gives at least some tangible improvement.
If we get a 4x IF 1:1 ratio (so essentially 8000mhz support) that would be cool. And while I want and think we will get ~7200-7600mhz support, even 6400-6800mhz support would be an upgrade.
As I've said, it's been pretty clear AMD has been dragging their feet on the MC to accentuate v-cache parts. Whatever they do to nix that limitation on non v-cache chips is good.
I'm hoping, given the switch to 12-core CCDs, the memory limitation instances of 6-8 cores is all but eliminated so they can shift the bottleneck to v-cache instead feeding 50% more cores.
This would help PPC of Zen 6 look much better than Zen 4->Zen 5, even if essentially just shifting current v-cache improvement into an arch upgrade, which I would argue is something they need to finally do.
7,689 (1.78/day)
The next client/desktop chips aren't going to be on 2/3 nm from TSMC. So in theory AMD could make a lot more desktop/notebook chips than they currently do. Or they would just make more TR/EPYC's as well :D
Still used for zen4 last I checked & quite a few notebook chips as well.
Don't go just by enthusiast forums, as long as AMD makes them smaller nodes will be relevant & when they move someone else will fill in their place who doesn't need $20k bleeding edge wafers!
1,153 (0.77/day)
System Name Dust Collector Mower 50
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case MATREXX 50
Power Supply SF450
RTX 5070 is only 118, closer to N6 instead of ~~144. But N6 IO Die ~~ 27mm2 ~3400M/122mm2 , TSMC numbers are for 50% logic, 30% SRAM, and 20% analog circuits.
Samsung 2nm monolithic for desktop or not buying. 122+70 single die. what's the problem.
14,397 (6.47/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
A new, more efficient IO die has been long overdue.
848 (0.14/day)
They aren't? News to me.
Last I heard Zen 6 was planned to be N3E and Zen 6c was N2/N3E depending on market. I don't think this has changed? :confused:
Thanks for the refresher on the IOD density...I'll have to figure out exactly what that translates to for analog (vs other processes) when I have time.
Are you curious about density of 5070? I figure it's bc it's aimed to clocked higher (by relaxing density). I've been trying to explain that to people...prolly a special child...and likely a design test for clocks on 3nm.
Less units; higher clock; same POS 4070ti under a new configuration (but similar die size). Lipstick on a pig, I do 'reckon. Will it fool the cattle? :p
FWIW, N48 is also kinda that. I would not be surprised if either and/or both of them are more-or-less ported to 128-bit/192-bit 3nm designs, and/or if both of them started as 3nm before it got delayed.
FWIW, I've also been arguing for a while that if Samsung can get their 2nm (not early 2nm which is actually like N3P, but actual 2nm) yields up that AMD should seriously consider them. On that we agree.
Granted, my reason for that is if they go to chiplets for gfx, they could essentially make everything at Samsung (bc everything would be under ~100mm2)...shouldn't be hard to yield...but that's a different topic.
1,104 (0.98/day)
Might want to add some extra words
534 (0.35/day)
The TSMC's 6nm is not used widely anymore so shifting to Samsung for the IO die won't help with the production of any new or even existing products. Zen 4 and Zen 5 are using 6nm for the IO die, but this is not the bottleneck because the lines are free from the most last gen hardware already and especially by the time when they finally shift something to Samsung. Maybe the RAM and VRAM can be shifted to 6nm, but the price for both is low enough even now, the problem is the greed for big >80% margins and making the manufacturing of RAM cheeper won't help for the price or the increase of the capacity for different products - RAM sticks, VRAM on the GPUs, etc.
Maybe it will save some 5nm TSMC for the next gen IO die, but then the 5nm will not be widely used so same story as freeing 6nm.
It is only financial move and I doubt we will see lower price for the next gen hardware, maybe we won't see price increase, but the shift to Samsung for the IO die will hurt the performance of the memory controller and the power consumption for sure
7,689 (1.78/day)
Well you're missing the entire zen 3.5 notebook lineup, the old ones & the rebrands ~
They're still being made & sold even now.
Those would probably be EPYC's only, the zen 5(c?) based EPYC are on better nodes as well. We'll need to wait till the actual chips come out though so who knows maybe AMD will surprise us?
848 (0.14/day)
Those would probably be EPYC's only, the zen 5 based EPYC are on better nodes as well. We'll need to wait till the actual chips come out though so who knows maybe AMD will surprise us?
Right, 2nm for Epyc. N3E for everything else. The same way Turin is 3nm and everything else was 4nm this gen.
The reason I figure there has to be also Zen 6c on N3E (and not just 2nm Epyc) is because I doubt the PS6 SOC will be 2nm. Unless they use the Turin design, which they might, that has to be available elsewhere.
Because that's how these things work. AMD kinda slaps their existing designs together to make SOCs. So whatever they plan for N3E, that's what Sony can/will use. Makes sense it would be available in laptop.
I really doubt Sony would use a full-blood Zen 6 when a 'C' design makes a lot more sense for their use-case. That's why the ? is if it's like Turin or rather a 6c on N3.
7,689 (1.78/day)
Anything competing with Apple, QC or Intel for TSMC's best wafers will have to have obscene margins so only EPYC or at best the next *Halo chips, pitted against Apple's Mx lineup.
848 (0.14/day)
But that's the whole thing...3nm isn't TSMCs best wafers. N2 is/are. Everyone will start using 3nm once Apple transitions (end of this year to early next). That's literally how it works.
For instance, the M5 just started MP on N3P. We can expect this same thing to occur next year but on N2. This is when mass production for everything else (Zen6/UDNA/prolly Rubin) will occur on N3E.
But yes, as far as 2nm goes...I agree. Has to only be something like Turin where margins are astronomical for the reasons you stated. This is why 2nm Samsung might make sense for future consumer products.
It will be interesting to see how Samsung yields go, performance is, and how quickly they are able to improve 2nm vs N3P. That's how/why Samsung *could* be a potential choice for future consumer CPU/GPUs.
