AMD's Upcoming Zen 4 CPU Delidded by Overclocker
16,886 (2.34/day)
It appears that AMD's Zen 4 based CPUs are making their ways into the hands of overclockers and so far at least one has already been delidded. Although we only get to see the IHS itself, it's clearly very thick compared to what we've seen in the past, although it appears to be fairly straightforward to remove, if it wasn't for the fact that the two CCD's and the IOD are soldered to it. Unlike current CPUs, which have a solid seal, the Zen 4 CPUs appear to only have the IHS glued to the CPU packaging in a few spots.
Judging by the looks of the area where the CCDs and the IOD attach to the IHS, this looks like a destructive delidding, although it could just be leftovers from the soldering material. The IHS has clearly been coated with some materials for a good solder interface as well, but this is nothing new, as we've seen this on delidded, soldered CPUs in the past. The person who shared this picture should most likely not have done so and as such, we won't be posting a link to the source.
5,482 (0.97/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
man that is one chunky lookin ihs
1,627 (0.81/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
That IHS is like a thick copper base plate more than an IHS
2,818 (0.44/day)
US
Processor Intel Q9400
Motherboard asus p5q-pro
Cooling Ultra120
Memory 6GB ddr2
Video Card(s) NVS 290
Storage 3TB + 1.5TB
Display(s) Samsung F2380
Case Silverstone Fortress FT02B
Audio Device(s) Creative X-Fi
Power Supply 750W PC P&C
Software win 7 ultimate 64bit
5,434 (1.06/day)
The need to keep a certain Z height to keep compatibility with previous mounting systems suck.
I get it, its probably for the better good, but im not a fan of the result. At all.
8,164 (2.22/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I'm in favor of the leftovers, it looks like that is solder at the outer corners on the right and just a blob of it on the left.
1,216 (0.53/day)
Processor AMD Ryzen 9 5950X
Case Cooler Master Cosmos
Power Supply Corsair HX850i
Keyboard Cherry MX
Is it solder, or is it liquid metal? Looks more like liquid metal to me.
16,886 (2.34/day)
I checked with the person that posted the picture and the CPU is indeed alive.
3,086 (2.34/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
It's not just that the lid isn't sealed along the entire edge. On the contrary, it has eight large holes.
1,627 (0.81/day)
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
It look like liquid metal because they heated it up and delided it
16,886 (2.34/day)
Well, I was actually expecting AMD to seal the edge still, to prevent "gunk" to get in under the IHS, but that's obviously not the case.
I guess these won't be easy to clean properly if someone makes a thermal paste mess.
355 (0.19/day)
System Name Cyberdyne Systems Core
Processor AMD Sceptre 9 3950x Quantum neural processor (384 nodes)
Motherboard Cyberdyne X1470
Cooling Cyberdyne Superconduct SC5600
Memory 128TB QRAM
Storage SK 16EB NVMe PCI-E 9.0 x8
Display(s) Multiple LG C9 3D Matrix OLED Cube
Software Skysoft Skynet
That looks waaaaay too thick for an IHS.
10,975 (5.38/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 4 + 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
But it makes sense, imo. Unlike monolithic dies, small chiplets concentrate heat into a tiny, non-central spot, which isn't ideal for cooling. You'd rather want to dissipate that heat in order to use as much of your cooler's coldplate area as possible. Zen 2 and 3's problem has always been heat dissipation.
What I don't get is how overclockers manage to get their hands on these CPUs so soon.
I really hope this is just an engineering sample.
7,808 (3.90/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
It has to be a chungus to make up the height difference. The old PGA socket was 3-4mm taller than the new LGA socket and AMD are being the good guys and trying to maintain compatibility with all the existing coolers on the market, including the one you presumably already own and paid good money for.
Having an extra-chunky IHS will also add to the thermal mass and make it easier to air-cool. I'm guessing LN2 and high-end water chillers will suffer, but that's such a tiny niche market that custom-build their own retention bracket and probably delid their CPUs anyway.
16,886 (2.34/day)
Depends on where you work...
It's someone I know, but I don't want to post too many details.
Most likely, as AMD hasn't finished their QS chips as yet, from what I understand.
Would using conductive paste on this matter?
I guess we'll find out in due time.
7,808 (3.90/day)
Case Veddha T2
Mouse MX Anywhere 2
We'll have to see when reviews come out and compare a cooler on AM4 and AM5.
AM5 has slightly less IHS surface area and a raised PPT of 230W so the thermal interface will play a larger role in the cooling performance.
In saying that, I am guessing that thermal paste will still play a relatively minor and insignificant part of cooling, where Conductonaut vs generic goop will provide no more than a few degrees.
1,301 (0.24/day)
The Netherlands
System Name PC ||Zephyrus G14 2023
Processor Ryzen 9 5900x || R9 7940HS @ 55W
Motherboard MAG B550M MORTAR WIFI || default
Cooling 1x Corsair XR5 360mm Rad||
Memory 2x16GB HyperX 3600 @ 3800 || 32GB DDR5 @ 4800MTs
Video Card(s) MSI RTX 2080Ti Sea Hawk EK X || RTX 4060 OC
Storage Samsung 9801TB x2 + Striped Tiered Storage Space (2x 128Gb SSD + 2x 1TB HDD) || 1TB NVME
Display(s) Iiyama PL2770QS + Samsung U28E590, || 14' 2560x1600 165Hz IPS
Case SilverStone Alta G1M ||
Audio Device(s) Asus Xonar DX
Power Supply Cooler Master V850 SFX || 240W
Mouse ROG Pugio II
Software Win 11 64bit || Win 11 64bit
That chonky thick IHS potentially looks like a good candidate for housing a vapor chamber.
I wonder if it's possible to build an effective and structurally sound one within those physical constraints, but it seems like a cool (hehe geddit) idea at least.
3,005 (2.53/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
that chonky thick IHS potentially looks like a good candidate for housing a vapor chamber.
it would probably cost a bit more to produce but seems like a great idea
1,884 (0.43/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Cooling Noctua NH-D15S
Display(s) EIZO CX240
Case Lian-Li O11 Dynamic Evo XL
Audio Device(s) Creative Sound Blaster ZxR / AKG K601 Headphones
Mouse Logitech G500s
Keyboard Keychron Q6
Looks like LM disaster when it spills underneat, so many gaps ^^
11,878 (2.25/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
So chip details, one big IO and two long thin chiplets?! Or is the CCD now ultra long?!
1,884 (0.43/day)
Netherlands
I think it's simply a matter of the LGA mounting system not being able to be made flat enough and make the IHS protrude the retention plate. So they compensate it by making a thick IHS.
279 (0.06/day)
Processor Intel i7-12700K
Motherboard MSI PRO Z690-A WIFI
Memory Corsair Vengeance 4x16 GB (64GB) DDR4-3600 C18
Video Card(s) MSI GeForce RTX 3090 GAMING X TRIO 24G
Storage Samsung 980 Pro 1TB, SK hynix Platinum P41 2TB
Case Fractal Define C
Mouse Logitech G203
Software openSUSE Tumbleweed
Such thick IHS possibly mitigates bending issues, which have always existed to some extent on Intel anyway (just got worse with Alder Lake).
