AMR + ATITool = impossible ? :(
12k
13 (0.00/day)
Processor 3700+ SD @ 3.15ghz
Motherboard DFI nF4 Ultra-D
Cooling Waterchilling - DD TDX
Memory G.skill 1GBGH @ 277mhz 1.5-2-2-5
Video Card(s) x850XT 520/540 @ 726/660
Storage 2x 300GB Maxtor
Display(s) Samsung 913N
Case Lian Li PC65
Audio Device(s) Creative Audigy 2 ZS
Power Supply 650W Silverstone QUAD 12V
Software Alot ;)
Dear software guru's... Will one be able to clock the GFX's seperately when AMR comes ?? - I got a R480 (x850XT) at the moment but wanna get a R520 when its launched.. Will it be possible to do this with your GREAT overclocking tool ???
Best regards
12k
wazzledoozle
5,358 (0.71/day)
Seattle
Processor X2 3800+ @ 2.3 GHz
Motherboard DFI Lanparty SLI-DR
Cooling Zalman CNPS 9500 LED
Memory 2x1 Gb OCZ Plat. @ 3-3-2-8-1t 460 MHz
Video Card(s) HIS IceQ 4670 512Mb
Storage 640Gb & 160Gb western digital sata drives
Display(s) Hanns G 19" widescreen LCD w/ DVI 5ms
Case Thermaltake Soprano
Audio Device(s) Audigy 2 softmod@Audigy 4, Logitech X-530 5:1
Power Supply Coolermaster eXtreme Power Plus 500w
Software XP Pro
Well W1zzard was working on something so that you can select between a PCI graphics card and an AGP, so I dont see why you could unless ATI uses AMR to stop overclocking (Which isnt likely because there overdrive utility)
12k
13 (0.00/day)
Case Lian Li PC65
Software Alot ;)
Thats the spirit ;)
Sounds good indeed... Would really be a pitty not being able to overclock cause of using two different cards... 2x R520 is a bit too pricy I think ;)
And I hope R520+R480 in AMR can compete with the new 4x PCI-E for Nvidia + Intel board...
W1zzard
Administrator
28,488 (3.73/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
it's too early to say something definite for amr .. but i'm pretty confident there will be a way .. anybody got a test system? ;)
