And the CPU socket is toasted
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
i thought it was the PSU. Turns out it was the motherboard. Plugged the CPU into a friend's MoBo ans it boots just fine. I have no idea how the hell this could have happened. Rig was working perfectly and all of a sudden it just decided to crap out. I have been super careful during swap out to 6950X. I am just sitting here scratching my head.
On close examination pins seems to be fine. I don't know WTH was wrong. It was stuck in a bootup loop. On and off and on and off for over 20 minutes
Toothless
Tech, Games, and TPU!
9,720 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Pop goes the hardware
5,717 (0.93/day)
OneMoar
There is Always Moar
8,802 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
doesn't need to be the socket could be a bad vrm bad cap bad trace a issue with one the bga's a dozen other things dead board is dead
1,181 (0.17/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
43,281 (6.74/day)
That sabertooth x99 is cheap compared to some x99 boards...
Pretty interesting how the sabertooth went from a truly tough product (990FX R2.0 ) to a cheap product (X99).
At op did you breadboard it?
5,717 (0.93/day)
OK I unplugged the two additional 8+4 plug to mobo and it WILL boot up. But no signal. CPU fan wont spin
BTW thanks for the awesome help guys. I knew i could count on you guys.
OneMoar
8,802 (1.63/day)
Rochester area
one of the vrm stages bought it then
5,717 (0.93/day)
Both VRM unplugged. Boot no signal. Either VRM plugged, boot looping.
VRM shot? Time to get the good old RMA then.
OneMoar
8,802 (1.63/day)
Rochester area
fried like tofu and Doritos
43,281 (6.74/day)
Id say so
5,717 (0.93/day)
Well everything is out now. Hope ASUS RMA won't be too much of a hassle.
johnspack
Here For Good!
6,048 (0.96/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
I was gonna say, how much for the cpu, but guess you're gonna rebuild....
5,717 (0.93/day)
Damn you thought i was gonna sell everything just now? lol
I hope my old cat doesn't get any funny ideas about knocking stuff to the ground then.
5,717 (0.93/day)
I am trying to think of any other possible cause. If CPU is toasted it should not even boot. I just don't understand when unplugging VRM can lead to booting up but no display signal
OneMoar
8,802 (1.63/day)
Rochester area
no power to the peg slots would be a good start
13,559 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Sockets don't just go bad. Generally, they have to be physically abused and that is pretty hard to do once the CPU is properly mounted.
Any component on the motherboard, however can fail. In fact, all electronics age and WILL fail eventually, if given a chance.
If your motherboard is still under warranty, you don't want to do anything to it that would void that warranty. You might try one stick of RAM at a time just to see what happens. Since the CPU works on another system, I would attempt to reset the BIOS/CMOS settings. If no luck there, RMA it.
5,717 (0.93/day)
Tried all of that. Did not work. Scary part was on friends machine we didn't see if it would enter BIOS. We just did a quick on and off to see if it lights up. I sincerely hope the CPU is not dead. Now I need to ask him to spare me his machine for one more day.
FML
OK a quick recap of event:
I was trying to install Windows 10 onto the new NVMe SSD. Installed fine. Booted up fine. Then after I installed the drivers and thought to reinstall softwares the machine crashed. Then this refuse to boot problem started.
Waited overnight, eventually it will allow me to boot up again. Run good for about half a day and then dead again. This time it refuse to boot up.
Fast forward a week. Got the replacment PSU. Hooked up. Stuck in boot loop. If I unplug the VRM 8+4 plug it will stay on buy no signal display over monitor.
This board does not have a Q-CODE and the TUF detective requires an Andriod. RMA filed with ASUS.
Before the attempted Windows 10 Reinstallation everything was perfect. Honestly I have no freaking idea what went wrong.
4,994 (0.70/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
Ugh, problems like this are the worst, hopefully smooth sailing once you get the new board. Nice pile of parts btw! ;)
2,724 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
Cursed OS that win10 ;)
I hope the CPU is live mate and with a RMA you will be up and running soon :toast:
BTW, pretty weird series of events you faced there. From the looks of it, mobo is the cause as most already implied.
5,717 (0.93/day)
One small detail. During both of the crash the problem happened right around when I installed the Intel Chipset driver. Now looking back I should have installed the 10.1.1.xx version which is for consumer version. I installed 10.1.2.xx, which is supposed only for server version. Could this be causing all the problem?
Already got RMA lined up and ready to go ATM. Will the board to ASUS and hope for the best.
1,700 (0.27/day)
No i dont think so, that would only be loaded once you are in the OS. If you are having a hard time booting, it's not software related.
501 (0.15/day)
Skopje, Macedonia
System Name The Tesseract Cube
Processor AMD Ryzen 5 3600
Motherboard MSI X570A-PRO
Cooling DeepCool Maelstrom 240mm, 2 X DeepCool TF120S (radiator fans), 4 X DeepCool RF120 (case fans)
Memory 2 x 16gb Kingston HyperX 3200mhz
Video Card(s) Sapphire Radeon RX 6800 Nitro + 16GB
Storage Corsair MP400 G3 1TB, Western Digital Caviar Blue 1TB
Display(s) MSI MAG241C Full HD, 144hz FreeSync
Case DeepCool Matrexx 55
Audio Device(s) MB Integrated, Sound Blaster Play 3 (Headset)
Power Supply Corsair CX650M Modular 80+ Bronze
Mouse Corsair Dark Core Pro Wirless RGB
Keyboard MSI GK30 Mecha-Membrane
Benchmark Scores CPUZ: Single Thread - 510 Multi Thread - 4.050 Cinebench R20: CPU - 3 500 score
Could be a BIOS coruption from that driver you installed?
Just a wild guess.
Take out that NVME, use a spare sata drive with Windows on it, reset the BIOS (take out battery) and try to boot.
Could be NVME failled or BIOS coruption.
That is all i can think of.
P.S: Forgive me for not following whole thread but i read your initial problem and first thing that poped in to my head, i wrote.
Boot looping tells me 2 things:
Bad boot device
BIOS coruption
Jayz2Cents had a simmilar problem, check out his video.
5,717 (0.93/day)
Thx for the input Filip, the board has already gone out to RMA. Just mailed it. Frankly i'd rather drive over there since their service center is only 3 hrs drive from where I live.
Now you mentioned it. Should i also get a replacement for the 960Pro just in case it is faulty? Still within newegg's return for replacement period.
