[Case Gallery] Antec 900 watercooled 360mm
11 (0.00/day)
Kent,England
Processor q6600
Motherboard Asus P5Q deluxe
Cooling Thermaltake pump & res withe tripple rad (taken from kandalf case)
Memory 2MB OCZ Reaper 1066mhz
Video Card(s) ati x1950xt (Tempory) Will Be ATI4850 within weeks
Storage 36gb raptor, 500GB samsung HD502IJ
Case Antec900
Power Supply Hiper typeR 580w
Software Vista Ultimate 32bit
Specs:
ASUS P5K DELUXE
Q6600 @ 3.6 idle=35*c load=47*C
2MB OCZ REAPER 1066
TEMPORY GRAPHICS CARD (ATI X1950XT) SOON TO BE 4850
36GB RAPTOR
500GB SAMSUNG HD502IJ
THEMALTAKE WATERCOOLING KIT FROM KANDALF CASE TRIPPLE RAD WITH PUMP AND RES INTERGRATED
HIPER 580W TYPE R
PIONEER DVD
SKYTHE TEMP PANEL
Mods:
Watercooled with termaltake triple rad Scythe temp panel
got the matching antec oem fans for rad
and a uvCC
This was my first go at water cooling after a lot of research i finaly took the plunge into water. I found a thermaltake setup which had been removed from a kandalf case on ebay so i gave it a go. I decided to mount the rad ontop of the case by making a custom bracket as is the only place to fit the dam thing. it also takes advantage of the 200mm fan as well. As the antec case is too small to neatly fit in the pump iv had to have tht externaly which dosnt bother me at all. The computer is connected to my cinema setup, running a Benq projector, Mordaunt-short 5.1 with Denon AV. Also Tannoy studio monitors for Music.
11 (0.00/day)
Kent,England
Processor q6600
Case Antec900
Had to rebuild the Post as the pictures fowled up, but got to do some more cable tidying but bit of a nightmare in this case without cutting holes in it. The modular psu not helping either making it harder to work with id recomend the normal cable style if any1 was thinking of this case. yes the side panel mesh is missing due to the gpu rad getting in the way tht will change soon!
MKmods
Case Mod Guru
5,697 (0.94/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
nice job, I like the lighting and the cooling must be nice. I run Acceleros as well, excellent coolers.
Welcome to TPU
11 (0.00/day)
Kent,England
Processor q6600
Case Antec900
Welcome to TPU
yer they do a good job but need to update asap!!
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
I like the rad setup, & overall not to bad of a build.
cronydog
43 (0.01/day)
Hawaii
Pretty rad man, love the water cooling, Im to chicken to do it, I give props to anyone that uses water cooling.
2,228 (0.36/day)
Larisa, Greece
System Name StarCruiser Dark Knight v.2
Processor Intel® Core™ i5-3570K
Motherboard P8Z77-V LX
Cooling 1x custom W/C loop/ inflow:6x120 /outflow:4x120, 2x200
Memory Viper 3 Black Mamba (4x4GB)
Video Card(s) Powercolor LCS 5870
Storage 1X 128GB OCZ, 2 x 1.500 Gb Seagate
Display(s) Samsung 24" LC24F396
Case custom MDF case (I BUILT IT) check sig.....NOW
Power Supply Tagan 900 watt
Software Win 7 RC / Open office / Games
lights off great!
manage your cables a bit more and I believe u will get a better result!
love the custom rad set up! 7/10
11 (0.00/day)
Kent,England
Processor q6600
Case Antec900
cheers for the comments il takle that when i get the 4850 :)
2,228 (0.36/day)
Larisa, Greece
welcome to TPU!
