Antec Introduces P7 Window & P7 Silent Mid-Tower Cases
889 (0.34/day)
Antec Inc., a leading provider of high-performance computer components and accessories for the gaming, PC upgrade and Do-It-Yourself market, presents the latest mid towers: the Antec P7 Window and P7 Silent. With these cases, Antec expands its award-winning Performance Series of feature-rich cases which offer plenty of space for graphics cards with a length of up to 390 mm and effective ventilation, making them particularly suitable for gamers. In addition, the stylish chassis offer enough space for drives and a 360 mm radiator. A special eye-catcher for the P7 Window is the side panel made of acrylic glass as well as the green or red accent strips at the front of the case.
The P7 Silent features sound dampening material (0.6 mm SGCC + Plastic) to block noise. The front panel with brushed metallic effect can be disassembled independently, for a neat and simple building experience. Thanks to the relocatable and removable 3.5" HDD cage, users can configure the system the way they want, with the ability to relocate or remove the hard drive cage within the P7. The cases come with additional 3 PCI-E Slot covers in tool box. The cases are now commercially available from 48,90€ (suggested retail price including VAT).
The powerhouse measures 445x 210 x 470 mm (DxWxH) and is compatible with ATX, micro-ATX and mini-ITX motherboards. The P7 offers superb cooling performance. The side ventilation slots on the front in the look of brushed aluminum also serve as a dust filter. There is enough room behind for three 120 mm or two 140 mm fans. In addition, P7 Window come with one pre-installed fan in rear while P7 Silent comes with two pre-installed fans (1 in front & 1 in rear). A pull-out dust filter is still on the bottom of the case. The I / O panel houses 2 USB 3.0 ports as well as audio ports and the mandatory power and reset switches. Under its cover there is space for an optional power supply with a length of 200 mm.
Fx
1,332 (0.23/day)
Portland, OR
Processor Ryzen 2600x
Cooling Noctua
Video Card(s) EVGA 980ti FTW
Case Fractal Design Define R5
Mouse Mionix Castor
Keyboard Deck Hassium Pro
The P7 Silent Mid Tower looks decent, but I wouldn't buy it over a Fractal Define.
6,263 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
h
o
h
u
m
m
m
Ruru
S.T.A.R.S.
12,979 (2.96/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
Storage 3.3TB of SSDs / several small SSDs
VR HMD Oculus Rift CV1
Acrylic window would be great, but it doesn't have that 5.25" slot what that non-windowed has. I'd need that for my Asus ROG OC Panel.
14,170 (3.81/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Too lazy to give them different model numbers despite the different fascias and side panels?
How far the mighty have fallen.
