[Case Gallery] antec nine hundred v2
20 (0.00/day)
System Name Eskwy
Processor 4790k @ 4.4Ghz
Motherboard Asus Hero VII
Cooling Stock cooler for the moment
Memory 8GB Kingston HyperX Genesis 2133Mhz
Video Card(s) Gtx 1070 strix oc
Storage 2x Western Digital 1 To -1x Samung Evo 840 256GB - 1x OCZ Vertex 4 128GB
Display(s) ASUS VG248QE 144hz
Case Antec Twelve Hundred
Power Supply Corsair HX 620W
Specs:
i7 860 @ 4.2ghz, Asus P7P55D-Pro, 8GB 2133Mhz Kingston HyperX Genesis, Diamond 5870 1Gb 900/1300Mhz, 1.5TB HDD, Corsair 620Watt, Cpu Heatsink Zalman CNPS 10x Extreme. 3DMark06 25,386pts,OS Windows 7 Ultimate 64
3,603 (0.67/day)
Oregon, USA
System Name GLaDOS
Processor AMD FX-9590 X8 4.7GHz
Motherboard ASUS Sabertooth 990FX
Cooling Corsair H80i v2
Memory Corsair Vengeance 24GB (2x8GB, 2x4GB) DDR3 1600 MHz
Video Card(s) ASUS ROG-STRIX-RX580-O8G-GAMINGOC
Storage WD Blue 3D NAND 1TB Internal PC SSD
Display(s) 2 Acer S231HL 23" LED backlit LCD's on a Dual LCD stand
Case Corsair iCUE 220T RGB Airflow
Audio Device(s) Onboard - Corsair Void Pro Wireless
Power Supply Corsair 850HXi 850W
Mouse Corsair Sabre RGB
Keyboard Corsair K70 LUX RGB
Software Microsoft Windows 10 Pro 64 Bit
Simple, clean, straight to the point. Looks good. I'm not a fan of the Antec line of cases, but you made it look good.
746 (0.12/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
Gotta love the 902 case!
Really nice work. I only have one suggestion. You should consider running the video card power wires around the back of the motherboard tray. I know it may see like they won't fit, but I have three video cards with two wire bundles a piece, and surprisingly they fit back there. You may need an extension on your video card power wires though. You may also consider getting an extension on your motherboard power wire too so that you can also run that behind the motherboard tray.
MelodiousUltra
86 (0.02/day)
Southern California
Processor Intel Core i5 750 Lynnfield 2.66 GHz LGA 1156 95W (B1) @ 2.66 GHz
Motherboard Asus P7P55D Pro (Intel P55 Chipset) LGA 1156 ATX Motherboard
Cooling 1x 120 mm Back Case Fan; 1x 140 mm Top Case Fan; Intel Stock Fan
Memory OCZ Platinum OCZ3P1333LV4GK 4 GB (2 x 2GB) DDR3-1333 PC3-10666 @ 7-7-7-20
Video Card(s) XFX Radeon HD 5850 1 GB GDDR5 256-bit PCI-E 2.0 HD-585A-ZNFC
Storage Western Digital Caviar Green 750 GB WD7500AADS
Display(s) Samsung 2494SW 24" LCD Monitor (1920 x 1080)
Case Antec Three Hundred Mid-ATX Case
Audio Device(s) VIA VT1828S Onboard Audio
Power Supply Cooler Master Extreme Power Plus 600 Watt (RS-600-PCAR-E3)
Software Microsoft Windows 7 Ultimate x64 (Build 7600)
How long did it take you to get your cable management that way?
I wish I could do the same thing with my Antec 300.
20 (0.00/day)
System Name Eskwy
Cable management
Take your time do to the job end use a lot of ty-wrap :)
20 (0.00/day)
System Name Eskwy
Love the wallpapper. Nice case.
Thx dude its a little beast :D play games with this computer is awesome on my 40'' samsung 1080p :D
