[Case Gallery] Antec P180
265 (0.04/day)
Anaheim, California
Processor i9 9900k
Motherboard MSI MPG Z390 Gaming Plus
Cooling Corsair H105
Memory G Skil Trident Z DDR4 4266
Video Card(s) RTX 3090Ti
Storage WD Black 500gb nvme, Sabrent 2tb nvme
Display(s) Viotek GNV34DBE2, Viotek SUW49DA
Case Hyte Y60
Power Supply EVGA Supernova G3 750w
Mouse Glorious Model O
Keyboard KBDFans Odin V2
Software W10 x64
Specs:
C2D E6750 w/ lapped TRUE120
8800GTS 640mb w/ HR03+
x1 74GB Raptor HDD
x2 300GB Seagate HDD
PC P&C Silencer 750w PSU
Mods:
Well first I used a 1 inch hole saw to cut several holes out behind the motherboard and throughout the case, to allow for better cable management. Then I put rubber grommets on the walls of those holes that I cut out, that way the cables I run through there wont get snagged or damaged on the rough edges. I also had to pull out the dremel to cut into the case a little to ease the cable management. I took a close up of where I cut out. After some heavy planning I went through and routed the cables anywhere could where they would be the least visible. I dont thing anyont notice but I fit a 120mm fan down in front of the lower hard disk drive cage. In order to do that I had to remove a piece that was held down by rivets, but they easily popped out with a flat head screw driver. I will make another log of my earlier cable management pics too so others can see how that was done. I have lots of pics and several revisions of cable management on the Antec P180.
To top it off I painted my case in mid-February to give it some added luster, lol. I used Dupli-Color bumper black and also the Sandable Primer. I included some pics of the primer process and a few pics of the painting.
PM with question, comments, suggestions, etc.
1,554 (0.25/day)
Annapolis, MD
System Name n.audBl
Processor E8500 @ 3.80GHz
Motherboard ASUS Striker Extreme
Cooling Full liquid (everything except power supply)
Memory 4Gb OCZ DDR2 PC9600
Video Card(s) Dual EVGA GTX 280 SSC Edition
Storage Dual WD Raptor in RAID 0 (300Gb), Dual WD 1Tb Cavair in RAID 1
Display(s) Dell 2407 24" HD+ Widescreen
Case Theraltake Tai-Chi
Audio Device(s) X-Fi Fata1ty (bleh!)
Power Supply Ultra X3 1000W
Software Win 7 64bit
Nice job, I like the black. Good work on cable managment as well. The yellow SATA cables are a nice contrast to the black paint. Keep it up and get some more pictures posted for better scores.
7/10 from me for now.
FlipIt
63 (0.01/day)
ohhh the good a lil old P180 i dreamed of one (before) now snaching a PC1000
10/10 :D
265 (0.04/day)
Anaheim, California
Processor i9 9900k
Case Hyte Y60
Software W10 x64
thanks guys. soon i plan on painting the side panels and the front panel too. still, not sure what color though. any suggestions?
265 (0.04/day)
Anaheim, California
Processor i9 9900k
Case Hyte Y60
Software W10 x64
new pics added
I posted some additional pics and added a little more explanation to what I did. Is there any way to post the mod details directly underneath each pic? Also, is there any way to get more than 16 pics up? I have maybe a hundred pics I could post on how I modded my case.
MKmods
Case Mod Guru
5,697 (0.93/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
Very clean. That case sure has a bunch of compartments. I bet its a really solid(quiet) case.
E
evertigox
very nice job....the black paint makes that case look much better. Great cable management. What about lighting? need a pic with side panel on. 8\10
265 (0.04/day)
Anaheim, California
Processor i9 9900k
Case Hyte Y60
Software W10 x64
the side panels are still silver and all beat up. i havent painted them yet. i will soon though. as for lights, i dont have a window so why bother with them? i know performance-pcs.com has a p180 side panel with a window but its $90. way overpriced. the whole case is cheaper than that right now at fry's ($70 after rebate.)
265 (0.04/day)
Anaheim, California
Processor i9 9900k
Case Hyte Y60
Software W10 x64
T
TechnicalFreak
I like the black color. It looks "clean".
No need for neon lights or similar.
An 8 from me.
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
