Anti-salty Case
89 (0.03/day)
Hello, I need a case that is anti-salty, because I live 500 meters from the beach. Some people recommended the Sharkoon PURE STEEL to me. That's because it is almost sealed.
Do you guys know another case that is anti-salty or maybe it is suitable for this problem?
Already lost 2 MOBOs in 4 years...
Thanks.
2,207 (0.84/day)
I'm not an expert on this but could you not treat the case with something. ie dip in something.
833 (0.51/day)
Maryland, USA
Processor Ryzen 5 5600X
Motherboard MSI MPG X570S Carbon Max Wifi
Cooling CPU: bequiet! Dark Rock 4. Case fans: 2x bequiet Silent Wings 3 140s, 2x Silent Wings 3 120s
Memory 2 x 8 GB Patriot Viper Steel DDR4-4400 C19
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage 2TB Mushkin Pilot-E M.2, 1 TB SK Hynix P31 M.2, 1 TB Inland Professional, 500 GB Samsung 860 Evo
Display(s) MSI Optix MAG271CQR 1440p 144Hz, MSI Optix MAG241C 1080p 144Hz
Case Lian Li Lancool III
Audio Device(s) Philips SHP9500, V-Moda BoomPro, Sybasonic Better Connectivity USB DAC/Amp
Power Supply EVGA SuperNOVA G3 80+ Gold 750W
Mouse Glorious Model D Wireless
Keyboard Custom Qwertykeys Navy QK80: Sarokeys Strawberry Wine switches, GMK CYL DMG3 keycaps
Maybe build in an aquarium and submerge in mineral oil?
2,205 (1.08/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
just get some clear spay paint, check on a part that carnt be seen that it dont react with the og paintwork. it will do the job mate.
9,169 (3.35/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I mean air will still get inside the case no matter what you do, if that's what you mean. I don't think there is a solution to your problem sadly.
2,373 (0.60/day)
Audio Device(s) A LOT
The only way you can keep salt out is with a hermetically sealed box or a HEPA filter. Silverstone makes the MM01, but it’s hard to come by (at least in North America). You could look into industrial cases for marine environments, but you’ll still want a HEPA filter.
Thought this was an interesting problem so down the google hole...
You can clean the salt off with >90% isopropyl alcohol. If you do that regularly your components should last a lot longer. It might even help the corrosion on your current board’s, so might give cleaning a shot.
They also sell spray-on solutions for these situations. You’ll have to take everything with a PCB completely apart and mask everything off before spraying, but seems like the best solution.
You can also submerge the build in mineral lil as @milewski1015 suggested. Some people apparently watercool in a solid box and run the rads externally.
Lots of suggestions here:
