any one has a bios for xfx radeon rx 570 8gb (micron) will pay
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Apparently you can get the original bios here at the following link. It's some sort of mining forum, you need to sign up, cant say if its original legit tho, as im not a member.
https://anorak.tech/t/xfx-rx-570-8gb-samsung/38637
https://anorak.tech/uploads/default/original/1X/03386773b3f1e6554ea465f054df0916e6daba96.rom
dont know if you tried these either, dont know if theyre micron
https://www.techpowerup.com/vgabios...X+570&interface=&memType=&memSize=8192&since=
just be careful, and back up
43,479 (6.76/day)
Why do you need it?
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
this GPU has dual Bios' doesnt it?
if yes, save it before you jack it, or do anything else.
This is the Bio as far as i can tell , its sapphire, but itll work , & its micron....just PM me with the payment, or even a thanks:D
https://www.techpowerup.com/vgabios/197769/197769
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
cdawall
where the hell are my stars
27,683 (4.09/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
Give this a try, you can possibly push the memory clocks to 2175mhz from what I am reading, but I have not got your card to test that. I have left it at a safe 2100. I can tweak that further depending on what you get on your end. This BIOS has zero power mods done to it as of yet. Please update me on how it works and I can tweak those.
  • xfx 570micron8gbrev1.zip
cdawall
27,683 (4.09/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
What driver are you using?
If that didn't change hashrate at all you either aren't using the correct driver at all, or you are not in compute mode.
felipon21
10 (0.00/day)
Driver
Its jumped from 23 hashrate to 70 is that possible
cdawall
27,683 (4.09/day)
Houston
Processor 7940HS
Cooling HP trash
Memory 2x8GB
I pm'd you a couple drivers to see if it fixes this for you. That isn't normal and might be a sign of instability. If it is I can iron it out in the BIOS.
