Any problem mixing 2*32 & 2*48GB DDR5 modules?
1,039 (0.61/day)
System Name Dirt Sheep | Silent Sheep
Processor i5-2400 | 13900K (-0.02mV offset)
Motherboard Asus P8H67-M LE | Gigabyte AERO Z690-G, bios F29e Intel baseline
Cooling Scythe Katana Type 1 | Noctua NH-U12A chromax.black
Memory G-skill 2*8GB DDR3 | Corsair Vengeance 4*32GB DDR5 5200Mhz C40 @4000MHz
Video Card(s) Gigabyte 970GTX Mini | NV 1080TI FE (cap at 50%, 800mV)
Storage 2*SN850 1TB, 230S 4TB, 840EVO 128GB, WD green 2TB HDD, IronWolf 6TB, 2*HC550 18TB in RAID1
Display(s) LG 21` FHD W2261VP | Lenovo 27` 4K Qreator 27
Case Thermaltake V3 Black|Define 7 Solid, stock 3*14 fans+ 2*12 front&buttom+ out 1*8 (on expansion slot)
Audio Device(s) Beyerdynamic DT 990 (or the screen speakers when I'm too lazy)
Power Supply Enermax Pro82+ 525W | Corsair RM650x (2021)
Mouse Logitech Master 3
Keyboard Roccat Isku FX
VR HMD Nop.
Software WIN 10 | WIN 11
Benchmark Scores CB23 SC: i5-2400=641 | i9-13900k=2325-2281 MC: i5-2400=i9 13900k SC | i9-13900k=37240-35500
I now have Corsair Vengeance 2*32GB DDR5 5200Mhz C40 (CMK64GX5M2B5200C40) and in need of more (heavy projects and many Adobe prog running at the same time). I want to get 2*48GB 5200 C38 (CMK96GX5M2B5200C38) to max my slot capacity. 160GB total.
Any reason to have problems with those mix modules?
43,982 (6.81/day)
You will need to run the slower timings for compatibility, so possibly no AMP/XMP/DOCP
1,039 (0.61/day)
VR HMD Nop.
So a drop to JEDEC memory spec (4800MHz) because of C40 vs C38?
ir_cow
4,823 (0.80/day)
USA
Mixing is never a good idea. Even worse is 48GB and 16GB DIMMs together. They have different primary and sub-timings.
Depending on the platform (AMD or Intel), you may not be able to reach the desired XMP/EXPO frequency. Just don't do it.
Edit: it will probably work at DDR5-3600 without issues.
780 (0.57/day)
System Name Red Devil
Processor AMD 5950x - Vermeer - B0
Motherboard Gigabyte X570 AORUS MASTER
Cooling NZXT Kraken Z73 360mm; 14 x Corsair QL 120mm RGB Case Fans
Memory G.SKill Trident Z Neo 32GB Kit DDR4-3600 CL14 (F4-3600C14Q-32GTZNB)
Video Card(s) PowerColor's Red Devil Radeon RX 6900 XT (Navi 21 XTX)
Storage 1 x Western Digital SN850 1GB; 1 x WD Black SN850X 4TB; 1 x Samsung SSD 870EVO 2TB
Display(s) 1 x MSI MPG 321URX QD-OLED 4K; 2 x Asus VG27AQL1A
Case Corsair Obsidian 1000D
Audio Device(s) Raz3r Nommo V2 Pro ; Steel Series Arctis Nova Pro X Wireless (XBox Version)
Power Supply AX1500i Digital ATX - 1500w - 80 Plus Titanium
Mouse Razer Basilisk V3
Keyboard Razer Huntsman V2 - Optical Gaming Keyboard
If they didn't come in the same kit, it ain't a hit. I do not mix as you can introduce stability issues.
1,039 (0.61/day)
VR HMD Nop.
Ok, thanks all.
I will go with the exact same kit and 128GB will need to be enough.
bug
14,187 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Ok, thanks all.
What people meant to say, is RAM has a huge number of timing parameters. They won't match for non-matching kits and motherboards are rather unlikely to detect and apply the proper settings by themselves. But if you have the time, you can find the least common denominator on your own. Failing that, they're supposed to work at standard JEDEC timings (I believe JEDEC goes all the way to 6400 these days, but don't quote me on that).
6,322 (2.86/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Worth a watch.
1,656 (2.15/day)
France
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
VR HMD Steam Deck OLED
Software EMDB
Benchmark Scores 0>1000
I you mix different RAM, music will be... MiXeD
:peace:
ir_cow
4,823 (0.80/day)
USA
4x dual-rank on 12/13th Intel is better vs AMD Ryzen 7000. Going by your specs you have a 13th gen CPU. Just understand that it will be hard to reach DDR5-5600. Probably be around 4800 or 5200.
1,039 (0.61/day)
VR HMD Nop.
Yes, I knew about that speed "limitation" with 4x dual rank. Hance I choose 5200 in the first place, plus the work I do doesn't really gain from fast RAM. I also go with z690 as it enough for that RAM speed.
I didn't think I will need to add ram so quickly but even so, price come down nicely in the past 6 month so I'll get another identical set and be done with it.
7,868 (5.12/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
If you can afford the downtime, why not sell your existing kit and pick up a full 128 or 192 GB kit? You can probably get $150 for your kit, Corsair's 5200 192 GB kit goes for $550 or so but you should be set for a very long time if you need so much RAM. That would turn out to like $300 or so to spend.
3,922 (2.57/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
Did AMD (or Intel) ever clearly state that mixing 24/48 GB modules with 16/32 GB ones is even possible? If not, I'd lean towards "no". I mean, these combination might be completely incompatible with existing bioses or even existing memory controllers, regardless of speed and timings.
168 (0.16/day)
System Name lawooder
Processor 5800x3D
Motherboard B550M Aorus Elite
Cooling Arctic Freezer 34 DUO
Memory 32GB 4000Mhz CL16 (2x16GB)
Video Card(s) RTX 3070 Ti
Storage SN770 250GB/SN750 500GB/SA510 1TB
Display(s) VG279QM 1080P 280hz + VG27AQ 1440P 165HZ
Case MSI MAG Something
Audio Device(s) fiiO EK10 + HD 599
Power Supply Focus GX 750 Watts
Mouse XM1r
Keyboard Xtrfy K4
If you know what you're doing, 0 problems.
if you don't, it can be an headache.
If you are familiar with timmings and sub timmings and how memory works you can make anything work.
nonsense. theres no such thing as "incompatible combinations with bioses"
bug
14,187 (3.96/day)
Well, up until recently, BIOSes did not support 24MB RAM sticks... So there can be such thing.
168 (0.16/day)
Processor 5800x3D
Mouse XM1r
Keyboard Xtrfy K4
Thats just something they do to protect them from liability
What they did was add the ram to the qlc list, that doesn't mean that said ram didnt work before..
If it's ram and fits the slot, it WILL work, it might run with crap timmings, sub and frequency, but it'll run.
ir_cow
4,823 (0.80/day)
USA
Sorry, but I disagree here. First off you need the newest BIOS for 24/38GB DIMm support, secondly your mixing dual and single rank with different types of ICs. Different voltage requirements and timings (plus sub-timings). Just asking for stability issues if you are mixing.
bug
14,187 (3.96/day)
Since I haven't tried those modules with a BIOS that didn't support them, I wouldn't know. Have you?
That's what I said, also. But not everybody will have patience/time to fiddle with all the timings some mobos expose. It should work using JEDEC timings, but even that might not be a guarantee, if the modules aren't properly QAed.
1,039 (0.61/day)
VR HMD Nop.
Selling is too much hassle for me right now and 192gb from go at 700$+ if I'm not mistaken. 128gb will be enough I guess.
Maybe in the future 4x64GB will be available. This setup is here for the long 10 years+ run.
I know about, but don't understand, all the RAM timing shenanigans.
This is an editing PC, not a test setup and I need stability above all. Best practices is to keep it simple and stay on the yellow brick road.
3,922 (2.57/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
When 32 Gb dies become available. I haven't seen any news recently about plans to introduce them. Looks like the 24 Gb dies are here to stay for quite a long time.
168 (0.16/day)
Processor 5800x3D
Mouse XM1r
Keyboard Xtrfy K4
i'm dumb, for some reason though this was talking about ddr4.
And you're right, mixing dual rank with single rank is asking for problems but it is possible, in the past i managed to stabilize 4 sticks from different ic's and single and dual rank.
It took me a long time and a LOT of headache but I managed to do it.
Can't really recommend if the word fun is not associated with memory oc. :laugh:
1,039 (0.61/day)
VR HMD Nop.
ir_cow
4,823 (0.80/day)
USA
Did you update the BIOS or anything you can think of?
1,039 (0.61/day)
VR HMD Nop.
No, but it POST with JEDAC 4800MHz and recognized all 128GB. I detailed it all in the new thread. Please continue over there.
