- Aug 29, 2009
- 113 (0.02/day)
- southern ontario
System Name | AboutTime |
Processor | AMD 9800X3d |
Motherboard | AS Rock Taiichi Lite X870E |
Cooling | Be Quiet 360mm Light Loop. |
Memory | TeamGroup T-FORCE DELTA RGB 32GB (2x16GB) DDR5 6400MHz |
Video Card(s) | PNY GeForce RTX 4070 Ti Super 16GB OC TF GDDR6X |
Storage | Crucial T700 NvMe 4 TB |
Display(s) | 24" Benq FP241W |
Case | Be Quiet Shadow Base 800 FX |
Audio Device(s) | On board audio. Speakers Edifier R200DB |
Power Supply | FSP Hydro Ti pro 1000 watt |
Mouse | Corsair M65 pro |
Keyboard | SteelSeries Apex 3 |
Software | W11 64 bit Pro |
I am using a gen 5 NVMe drive a crucial T700 and noticed that the thing was running a bit warmer then I'd like considering the ambient room temperature so I finally took out a Thermalright HR-09 2280 Pro heatsink I had here and installed it. Nice temp drop of 10C at idle. The only thing i can find to criticise about this board is for a Gen 5 slot that drive heatsink is a little on the thin size. Other then that I,m very happy with this board . Everything has worked perfectly. Anyone else have this board and like it ?
