Hello everyone, I have been using this aours since January, especially for FPS games like CS2 and Valorant. For a long time I have noticed that the processor clocks do not keep the same level, but jump from time to time, which prompted me to install ThrottleStop. I set everything as in the screenshot below, with SpeedShift set to 50, the clocks run up to a maximum of 3.9Ghz, but it is not a constant value. Sometimes there may be various jumps to 3.7-3.4Ghz, which causes sudden frame drops. Is it possible to force a constant value without these jumps? By lowering the power? In CS2 I noticed that even if I have 4.2Ghz, I have a higher frame rate.
I will also add that the temperatures are ok because with the current setting in the game I usually do not exceed 75 degrees. The screenshot shows the highest temperature recorded when running the benchmark in Throttlestop.
Thank you for any help and suggestions, I'm new in this and I also looked for other threads of this type on the forum, but each case is different.
Regards!
Regards!
