- Oct 9, 2007
- 47,067 (7.59/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Arctic announces the Accelero Hybrid III-140 graphics card cooling solution. The highly efficient Accelero Hybrid III-140 is the all-in-one package for real performance junkies. It combines Water Cooling Solution for the GPU with a 140 mm radiator and a special VRM and RAM cooling for outstanding power.
With a cooling capacity of 300 watts this powerhouse lowers the temperature of even the most powerful GPU. A particularly large water contact surface ensures that the heat can be dissipated quickly. Special attention is given to the voltage regulator module: Individually made VRM heatsinks for NVIDIA and AMD graphic boards and an 80 mm fan provide not only a long service life but especially a better VRM cooling than ever before. And the random access memory also receives a special treatment: A smaller, specially adapted back plate cools the RAM separately to guarantee best efficiency. A gluing of heatsinks on the graphic card is not necessary.
Extreme performance that does not need loud tones: Through software, the temperature-fan speed curve can be adjusted, whereby you get the temperature and noise level exactly where you want it to be. An improved fan controller and the use of additional filters guarantee a smooth operation with both NVIDIA and AMD graphics cards. The combination of a low noise impeller and the patented fan holder additionally enables a virtually silent operation - even under full load.
QUICK FACTS Accelero Hybrid III-140 Graphics Card Cooler for Enthusiasts
- Back-side cooler for lower RAM temperatures
- Optimal VRM cooling through dedicated VRM heatsinks and a 80 mm fan for all NVIDIA and AMD grahic boards
- Unparalleled performance with liquid cooling unit
- Virtually silent thanks to low noise fan
- Improved fan controller for NVIDIA graphics cards
- No thermal glue necessary
