Arctic Cooling Launches Alpine 7 Pro and Alpine 7 GT
malware
5,422 (0.74/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
Swiss cooling solution provider Arctic Cooling has launched a new series of value Intel CPU coolers - the Alpine 7 Pro and Alpine 7 GT. Due to their highly efficient thermal design and PWM function, with which the BIOS controls the fan speed of the Alpines, both coolers perform significantly quieter than the standard boxed cooler. Moreover, the 92mm fan of the Alpine 7 series features a patented vibration absorption, which gives the coolers the bestnoise/performance ratio in its price class. The Alpine 7 series feature Intel's push pin mounting for instant and easy installation. As with other Arctic Cooling products, the Alpine 7 Pro and Alpine 7 GT have a very long service life and are covered by a 6 year limited warranty. Alpine 7 Pro and Alpine 7 GT will be available by the end of Dec 2007. The MSRP of the Alpine 7 Pro is USD 15.95/Euro 10,95 (excl VAT). The MSRP of the Alpine 7 GT is USD 12.45/Euro 8,45(excl VAT).
1,042 (0.16/day)
CT, USA
Processor q6700 @ 3.2ghz
Motherboard Asus p5w DH Deluxe
Cooling Scythe Andy Samurai, 4x80mm silenx, 2x120mm silenx fans
Memory 2x2gb G.Skill 4-4-4-12
Video Card(s) xfx black edition 6870
Storage 250gb seagate sata, 2x250gb seagate perp (raid0)
Display(s) dell 24"
Case Coolermaster atc s4000 sx-1
Audio Device(s) Creative Audigy2 Platinum
Power Supply Antec True Power Trio 650w
Software winXP pro x64
Wish they didn't have those annoying clips!
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
the Alpine 7 GT performs worse than the Boxed Cooler, it is just marginally quieter though, and it is only rated up to 70w, which drastically limits what processors you can use it on.
The Alpine 7 Pro doesn't do much better. It performs only marginally better than the boxed cooler, and is only marginally quieter. IMO, it would only really be worth looking at if you got an OEM processor and need a cheap HSF to put on it that is equivelant to stock cooling. Of course it only handles 90w, so quad-core cooling is out of the question, the stock Intel cooler is rated higher than that.
8,253 (1.19/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
yes not for overclocking.. the rubber mountings on the fan seem to work thow noise wise.. not a great deal of point unless u have a space problem or just need something cheap to go on an oem chip..
trog
InnocentCriminal
Resident Grammar Amender
6,477 (0.89/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
2nd that! Those clips really piss me off. They're horrible to work so I think AC are trying to cut corners 'ere. Silly buggers, should be innovating not being lazy & going backwards.
bcracer220
426 (0.06/day)
Processor Core 2 E8400 @ 3.825 with 1.27 volts
Motherboard ABIT IP35-E
Cooling af7 pro, 2 Case Fans (af12 + af8)
Memory 2x1GB G.Skill HZ 4.4.4.12 ddr2 900
Video Card(s) EVGA G92 8800GTS 512, 745/1860/1050 daily
Storage Western Digital Caviar 250GB
Display(s) SAMSUNG 226BW 22" Widescreen
Case X DREAMER II (BLUE) with window
Audio Device(s) X-Fi Xtrememusic OEM Card
Power Supply Corsair HX 520
Software Don't get me started...
Benchmark Scores Super pi 1m @ 4ghz = 12.5 seconds @ 3.6ghz = 13.9 seconds
at that price wouldnt it be better to spend 10 more and get an af7 pro?
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
I don't see what the problem with the stock style mounting system. I had problems with it the first time I had to do it, but after that I don't have a problem with it. I actually prefer them over some of the others that require taking the motherboard out to put a cooler on, which is essentially every other mounting system.
cdawall
where the hell are my stars
27,680 (4.10/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
its cheaper to get a Tt jungle 512 i got one of those with an oem cpu things near silent and works better than the intel oem HSF
panchoman
Sold my stars!
9,595 (1.50/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
+3, ac7's are notorious for bad mounting mechanisms, they can actually fall off and stab your video card, etc.
error_f0rce
938 (0.14/day)
Wisconsin, USA
Processor Intel Core i7-930 (D0) @ 4.0GHz (1.28v)
Motherboard GIGABYTE GA-X58A-UD3R
Cooling CoolIT ECO-R120 Advanced Liquid Cooling w/ x2 Scythe ULTRA-KAZE 3000rpm | Scythe Master controller
Memory Mushkin Enhanced Redline - 6GB DDR3 @ 1910MHz 8-10-8-29
Video Card(s) MSI N460GTX Twin Frozr II SOC GeForce GTX 460 768MB 192-bit GDDR5
Storage RAID-0 w/ 2x OCZ Agility 2 SSD 90GB SATA II 3.5" (r4.6Gb/s w4.2Gb/s)
Display(s) ASUS VW266H - 26" LCD
Case COOLER MASTER Storm Scout | x2 120mm Scythe ULTRA-KAZE | 140mm Scythe Slipstream KAZE Maru2
Power Supply Thermaltake Black Widow TR2 RX - 850w
I can't stand the mounting hardware either, but would recommend an AF7 (performance wise) to anyone. It might cost a litte more than these, but they are amazing little HSF's; lots of people here have used them to achieve significant OC's on just air. Haven't heard anyone who hated theirs for the way it cooled.... but frustrating to install for sure.
