Arctic Freezer 34 esports DUO(air) vs Arctic Liquid Freezer 2(liquid)
162 (0.16/day)
System Name Mypc
Processor AMD Ryzen 5 5600x
Motherboard MSI MAG B550M BAZOOKA
Cooling Coolermaster Hyper 212 Rgb
Memory Corsair 3600 mhz Cl16 ddr4 8x2
Video Card(s) Asus RX 6750 XT Rog Strix OC Edition
Storage Samsung 990 PRO 1TB + Samsung 980 Evo 50gb
Case Coolermaster TD500 Mesh White
Power Supply Corsair CX-650F RGB
Which one to go with for overclocking my 5600x, ?
I will be upgrading from hyper 212 argb, would the air cooled one be enough to see improvement or should i go for the liquid cooled one to see an improvement ?
18,270 (2.71/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
I would go with Noctua.
1,683 (0.52/day)
North Dakota
System Name Office
Processor Ryzen 5600G
Motherboard ASUS B450M-A II
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
That wasn't the question, though.
Either one should handle the heat output of a 5600X in most scenario. The LF has more thermal capacity, so will hypothetically be more effective on a sustained load. Zen 3 doesn't OC particularly effectively, though, partially due to built-in boost algorithms, and partially due to fairly high power density. Z3 dice are small.
Full disclosure, this is based on info I've gleaned from articles and forum discussions; I haven't even OC'ed my 5600G. @tabascosauz knows their way around Zen, though. Hope they don't mind I've tagged them in here. :oops:
1,316 (1.66/day)
G-City, UK
System Name My first new build
Processor Ryzen 7 5700X
Motherboard MSI B450M mortar max
Cooling Deepcool AK620
Memory 32gb Corsair Vengeance LPX 3200@XMP3200
Video Card(s) Sapphire 6900XT Toxic Air Cooled
Storage Samsung 870 QVO 1TB x 2, Lexar 256 GB, Western Digital SN550 500 GB nvme
Display(s) 32" LG GN600-B
Case Aerocool Eclipse
Audio Device(s) Corsair HS70 wireless
Mouse Glorious Model D l Pad GameSir G7 SE
Keyboard Redragon Vara K551P
From what I've seen on Gamers Nexus, they're both respected coolers, but the Arctic would win that fight. Isn't the Arctic a lot more expensive though?
20 (0.02/day)
Gamers Nexus - Lian Li Galahad 360 Elite Review (I linked this one because it is their most recent and has the most water coolers to compare)
You can skip to 12:34 to see the noise-normalized performance bar chart. A 5600x will never pull anywhere near 198w, so just about every cooler on that chart is over kill. You can see though, that every water cooler beats the best air cooler on their chart, which is the Noctua NH-D15. The Arctic Liquid Freezer II 280 performs 6c cooler on average than the NH-D15, which is a significant amount. This advantage could either be used to run the system at quieter noise levels since your cooler doesn't have to work as hard or to give you more potential headroom when overclocking. Air cooling has benefits over water cooling too though like simplicity of set up, reliability, and longevity.
Gamers Nexus - Arctic Freezer 34 Esports Duo Review you can skip to 13:19 for the noise normalized performance at a 68w heat load. This the same heat load that a 5600x will produce and you can see that even the Vetroo V5 is providing enough cooling for an overclocked 3600. So again, water cooling a 5600x is probably overkill and all you really need is a $50-$60 air cooler to get a good overclock. That being said, I plan to put an Arctic Liquid Freezer II 280 in the 5600x system I'm building. If you're willing to spend the extra money, an aio will simply give you better performance. Lower temps = lower power draw = higher clock speeds. The Liquid Freezer II 280 will likely have enough cooling power for whatever CPU you might want to upgrade to in the future. Once you get into the range of 100w+ CPUs, water cooling becomes a lot more important for overclocking.
Edit: Just a little extra info. I currently use a Liquid Freezer II 280 on a 12600k and I can run it at 5.4-5.2ghz @1.400V (5.4 for single core boost, 5.2 for all-core boost) and loop cinebench r23 for at least an hour with temps under 90C. The 12600k will pull 200w+ when running like this. The Liquid Freezer II 280 is a beast of a cooler.
tabascosauz
7,860 (2.38/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Big AIOs are honestly a waste of money on a 5600X. At stock or PBO tenps are comparable to about a 5700G, which is trivially easy to cool. It's hard limited to I think 4850MHz in +200 PBO, single thread boost.
If you are really, really pushing it on an all-core OC, I can see a bit of merit in a larger AIO. Since the 5600X is the only chip that potentially doesn't lose that much clockspeed with all-core due to its low boost cap. But then again, it's a 6-core, you didn't buy it for insane prkductivity performance.
And all-core is more dependent on your CPU than anything, I wouldn't have too much confidence in anything manufactured pre-Q3 2021. Since 3000, Ryzen has always started out complete dogshit silicon quality, and improved significantly roughly 6+ months after release. Check your IHS batch code.
In any case, the Freezer 34 works just fine. But @freeagent is more familiar with 5600X cooling needs under hard OC
Bottom line: if you have a bad chip or just use mild PBO, water = waste of time. If you push a hard all-core, water will start pulling in the lead over air.
43,593 (6.65/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Get the AIO. Cools better, will give you more headroom for overclocking if you decide to do so.
freeagent
7,896 (3.73/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
To be fair, if you ever decide to manually push the 5600X, it can put out hella thermals. I have seen OTP kick in under 75c with manual clocks lol.. I don't mess with temp stuff in the bios, so that was an act of self preservation I do believe. Any more than 155w PPT and it will take you to the boot screen pretty quick. Not bad for a "65w" CPU.
Out of those two I don't know what I would get. I am a Thermalright fanboy. Now that part is out of the way, if you are shopping on Amazon I would look up the Thermalright PA120, but preferably FC140.. I can max out 5600X with FC140..
2,094 (1.29/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
Thermalright Peerless Assassin's on sale for $40ish on Amazon. By far the best bang for your buck you'll find. You won't need to buy another hsf again.
Unless you have the sickness that is hahaha.
8,150 (2.24/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
What it boils down too is airflow. An air cooler in a closed case will need to move more air thru and out of the case at higher volumes so the internal case doesnt retain the heat. On the other hand, an AIO 'normally' mounted with its fans exhausting has the advantage of already wicking heat out of the case letting the internal ccase remain cooler longer. I'm in the camp that air coolers demand higher fan speeds than an AIO.
One advantage, some may disagree, an air cooler draws VRM heat better than most AIOs, Arctic LF2s have a tiny fan on the block just to move air ( I didnt say cool) across the VRMs.
I seem to recall the Esports having around a 75w rating.
2,763 (2.22/day)
Germany
System Name Sunk Cost Fallacy
Cooling Arctic Liquid Freezer II 360 Rev. 7
Video Card(s) Sapphire Nitro+ RX 7900 XTX Vapor-X
Storage WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo.
Display(s) Alienware AW2723DF, LG 27GR93U, LG 27GN950-B
Case Lian Li O11 Air Mini
VR HMD Oculus Rift S
The air cooler will never leak or have a pump failure.
40,435 (6.51/day)
The 34, Alternatives.
Deepcool, Scythe, ThermalRight
20 (0.02/day)
I have since installed the LF II 280 w/ liquid metal on my 5600x. I'm new to AMD overclocking, so I don't think I've really pushed the chip to its limit, but I've seen it pull 135w+ doing loops of cinebench r23 multithread. It will thermal throttle if I set the voltage over 1.35v, so a 5600x can definitely put out some heat if you try to manually overclock it.
5,476 (0.77/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Logitech G613
The Hyper 212 is good enough for a 5600X, probably even overclocked.
2,790 (2.90/day)
Knoxville, TN, USA
You are aware that the Ryzen APU's are monolithic, right?
40,435 (6.51/day)
1,683 (0.52/day)
North Dakota
System Name Office
Yes. I wasn't talking directly about the 5600G, only mentioning it as an aside to highlight my lack of direct experience with the Z3 arch. The point was supposed to be that Vermeer CCXs are 81mm^2, which isn't a lot of area to to dissipate 70 or more watts of heat.
