Are 6-pin to 8-pin adapters safe for GPUs?
dexgo10
10 (0.01/day)
Hi, I wonder if I could use a 6-pin to 8-pin adapter and if it safe. I found differents arguments about this subject. For example, the XFX rx570 incluides this adapter, but some people say that the adapters are dangerous. I want to buy a MSI rx570 armor but my psu just have 6 pin.
Thanks!
996 (0.29/day)
System Name The Banshee
Cooling Asus ROG Strix LC 240
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) Nvidia RTX 3060 6GB Laptop GPU + AMD WX 9100 16GB
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
Both 6-pin and 6+2-pin PCIE power connectors have the same number of power and ground wires so there's no issue with using an adapter.
Ruru
S.T.A.R.S.
12,518 (2.89/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X @ PBO +200 -20CO
Cooling Arctic Freezer 50, EKWB Vector TUF
Memory 32GB Kingston HyperX Fury DDR4-3200
Storage A pack of SSDs totaling 3.2TB + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
VR HMD Oculus Rift CV1
No problems, the +2 pins are just grounds IIRC. Hell, I've ran a HD 3870 X2 with an old 300W PSU back in the day with a lot of adapters. :laugh:
dexgo10
10 (0.01/day)
In my case I want to use it with a Seasonic 400w (ss400es). Do you think it´s fine? My cpu is i5 3550 (77w)
Aquinus
Resident Wat-man
13,161 (2.83/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
You are a very brave soul.
I would be reluctant with a 400w PSU. It *might* work but you have absolutely no headroom for additional draw or overclocking if you do. I'd be worried about it if I were you.
Ruru
S.T.A.R.S.
12,518 (2.89/day)
Jyväskylä, Finland
There shouldn't be problems with RX 570.
I had an E6400 @ 3.4GHz back then with that HD 3870 X2, I can't even understand how that old HEC 300W ran it without problems. I later upgraded the GPU to a HD 4890 @ 1040/1145, also ran flawlessly.
I don't recommend doing anything similar though. :D
E: I also had a Pentium G3258 @ 4.7 @ R9 290 with a XFX 430W PSU, no problems also with that.
Aquinus
Resident Wat-man
13,161 (2.83/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
Just because it didn't explode for you, doesn't mean it won't explode for someone else. The bottom line is that it might not be safe to do that, which is my point. We're not talking about a maxed out quality PSU here, we're talking about maxing out a cheap PSU. The results could be catastrophic. Why tempt fate?
8-pin has the same number of power pins, but it has two more ground pins than a 6-pin PCIe power connector. The adapter works because the extra two pins can be grounded, but your current carrying capacity is reduced in comparison. If a connection is loose, you could start a fire under heavy load. The point of the extra two ground pins is to distribute the current against ground.
dexgo10
10 (0.01/day)
Yours psu´s rocks! :rockout: Well now I think that I can try with the adapter. What´s the worst scenario, if something goes wrong?
Aquinus
Resident Wat-man
13,161 (2.83/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
Worst case scenario is that you could destroy hardware or start a fire. It's your risk.
8,084 (1.36/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Well, no, you're both wrong. 6 pin PCIE power cables are rated for 75 watts. 8 pin PCIE power cables are rated for 150 watts!
Sometimes, we should listen to what our hardware is trying to tell us.
It looks like it has 17 amps (204 watts) available for the GPU. Rather disappointed that they didn't use a 6+2 cable for this PSU. The PSU should supply you with the power that you need to run your system, (at least what you've told us of it) (hint, hint, fill out your system specs) but Seasonic may have limited your ability to do so with the connectors provided. W1zzard tested a RX-570 4GB and it maxed out at 180 watts. If you subtract the 75 watts that the card can pull through the PCI-e slot, that still leaves 105 watts to come through that 75 watt rated 6 pin. I have no idea if Seasonic has over current protection on those connectors.
Possible solution: Get a 4 Pin Molex to 6 Pin PCI-Express PCIE and a dual 6 pin to 8 pin PCIE so you can pull some from the molex connector as well.
dexgo10
10 (0.01/day)
I´m a rookie in oc, so I won´t do that. I calculate the load wattage of my pc with the rx570 and it gave me between 332w and 345w. It´s safe?
996 (0.29/day)
Mouse Evga Torq X3
Electrically they are the same, Three +12V & Two Ground + One Sense wire. The extra pins on the 6+2 are a second sense and a third ground. 6pin = one sense shorted to ground, 8pin = both sense pins shorted to ground.
Basically 6 & 8pins are one and the same and can of course carry the same amount of power.
dexgo10
10 (0.01/day)
Oh, I think it could be work only with the 6 pin to 8 pin, but I don´t know nothing about psu´s.
This is my full system specs: https://pcpartpicker.com/list/
I found that the power consumption is 330w and I worry about it, these are real watts?
What do you think?
AlienIsGOD
Vanguard Beta Tester
5,111 (0.86/day)
Kingston, Ontario Canada
System Name Aliens Ryzen Rig | 2nd Hand Omen
Processor Ryzen R5 5600 | Ryzen R5 3600
Motherboard Gigabyte B450 Aorus Elite (F61 BIOS) | B450 matx
Cooling DeepCool Castle EX V2 240mm AIO| stock for now
Memory 8GB X 2 DDR4 3000mhz Team Group Vulcan | 16GB DDR4
Video Card(s) Sapphire Pulse RX 5700 8GB | GTX 1650 4GB
Storage Adata XPG 8200 PRO 512GB SSD OS / 240 SSD + 2TB M.2 SSD Games / 1000 GB Data | SSD + HDD
Display(s) Acer ED273 27" VA 144hz Freesync |TCL 32" 1080P w/ HDR
Case NZXT H500 Black | HP Omen Obelisk
Audio Device(s) Onboard Realtek | Onboard Realtek
Power Supply EVGA SuperNOVA G3 650w 80+ Gold | 500w
Mouse Steelseries Rival 500 15 button mouse w/ Razor Goliathus Chroma XL mousemat | Logitech G502
Keyboard Logitech G910 Orion Spark RGB w/ Romer G tactile keys | Logitech G513 Carbon w/ Romer G tactile keys
Software Windows 10 Pro | Windows 10 Pro
i would just save some $ and get a proper wattage psu so u dont have to worry about this again in the future. 550-650w will do fine and last a cpl of builds if you upgrade down the road.
dexgo10
10 (0.01/day)
That is the best option, I know, but the prices in my country are too high. For example, only the 6 pin to 8 pin adapter cost me 14 dollars.
AlienIsGOD
5,111 (0.86/day)
Save imo, Canadian prices are crap for hardware too. Better a long term investment rather than a quick fix
277 (0.14/day)
System Name Cheapskate Maximus
Processor Xeon W3680 @ 3.99Ghz [133x30] [1.375v]
Motherboard HP Z400 Rev 2
Cooling Alpenfohn Brocken v1
Memory 3 x 4GB DDR3-1600
Video Card(s) Sapphire RX570 Nitro+
Storage 240GB WD SSD, 6 x 2TB HDD
Display(s) 27" iiyama XB2783HSU AMVA+
Case AeroCool
Power Supply HP 600w Bronze (Delta)
Keyboard Gots keys
Software W10 x64
I use an adapter myself but my 12v rail can supply enough to allow me to use the 6+2 pin adapter - been using it for 8 months with no issue but it is a quality OEM supply. Some supplies, particularly cheap ones won't be safe supplying 150w through that single rail with an adapter on it.
A good example of a supply that can use the adapter is the Seasonic one posted above.
12,312 (2.28/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
The issue is "some" adapters are crap. But if it can be avoided, do not use one. Its just one more connection that can degrade over time. I have used them with 90 degree in a tight case but I try to avoid them.
Now you see power supply companies that split two to make 8 out of six. In that case the manufacture has done it, not some sweat shop in china
27,283 (6.60/day)
Thanks!
There's a lot of info to go around, but the short answer, as many have said already: You'll be fine as long as your power supply has the wattage your system+GPU needs.
With this PSU and the CPU/GPU combo you've stated you'll be ok. I would recommend a 550w or 600w to give yourself room to upgrade, if you have not already bought the PSU.
dexgo10
10 (0.01/day)
I trust in the brand, but the only thing risky is that my psu has seven years
yes, that´s a big issue, because a crappy cable could ruin some component of the pc
I don´t buy the psu yet, I was looking for information today and I read that the efficiency of the psu could change over time. Mine has seven years
8,084 (1.36/day)
Hillsboro, OR
System Name Main/DC
I think you should start with a PSU upgrade first.
622 (0.09/day)
Oak Ridge, TN
System Name BorgX79
Processor i7-3930k 6/12cores@4.4GHz
Motherboard Sabertoothx79
Cooling Capitan 360
Memory Muhskin DDR3-1866
Video Card(s) Sapphire R480 8GB
Storage Chronos SSD
Display(s) 3x VW266H
Case Ching Mien 600
Audio Device(s) Realtek
Power Supply Cooler Master 1000W Silent Pro
Mouse Logitech G900
Keyboard Rosewill RK-1000
Software Win7x64
The wires are not the issue in that cable; the contact rating is.
Those contacts are good for7A; 3 contact to 4 contact is significant; 21 to 28A.
2,207 (0.81/day)
I use dual 6 pin input to single 8 pin output for years now, no issues. I did find one adaptor that was not fully wired.
