Are internal BD drives better than external ones?
82 (1.46/day)
Earth, The Sol System, The Milky Way, The Universe
System Name Alienware Aurora R13
Processor i9-12900kf
Motherboard Alienware 0C92D0
Cooling Alienware CPU water block AIO thing
Memory 32gbs of DDR5-4400 (slow, I know)
Video Card(s) Dell/Alienware RTX 3080ti
Storage NVMe KIOXIA KXG70ZNV1T02 1024GB
Display(s) ViewSonic VA2456-MHD (yes totally underspec)
Case Alienware Aurora R13
Audio Device(s) Soundcore Life Q20
Power Supply Dell-Something-Or-Other 1000? watt
Mouse Logitech M325S
Keyboard Logitech K540
VR HMD None
Software Ubuntu Linux 24.10
So, I had a LG external trayloading BD drive completely break. When I build my new PC, it will have 5 1/4 inch bays. Would an internal tray-loader be more reliable?
7,048 (4.82/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Keyboard IBM Model M type 1391405 (distribución española)
Anecdotal, I reckon internal drives are probably built sturdier, although the laser and mechanism should have about the same reliability. Problem is finding a quality computer case with 5.25-inch bays nowadays. There are very few if any left.
82 (1.46/day)
VR HMD None
Fractal Pop Air XL is my pick, two 5.25 bays
370 (2.87/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
I like the Pioneer brand rom drives. They can really take a beating.
82 (1.46/day)
VR HMD None
1,857 (0.75/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
LG WH16NS40 can be modified to read UHD Blu-ray discs (if you care about that).
That's the one I have.
ir_cow
4,577 (0.77/day)
USA
I have two. Really easy to do. You can grab the FW and tool in a single zip. Probably can't share the link here. Google is your friend.
42,684 (6.68/day)
That's what I use, Samsung dropped out of them and I had a Sony unit fail causing slow post issues
82 (1.46/day)
VR HMD None
Mine is stock set up for uhd
82 (1.46/day)
VR HMD None
For that particular drive it needs to be FW 1.2 or UHD doesn't work properly. Factory now is 1.5 so it must be downgraded.
Never mentioned a specific drive?
42,684 (6.68/day)
The internal drives should technically be less in cost , perform better due to not having a wallwart as a psu, don't suffer from cable wear.
ir_cow
4,577 (0.77/day)
USA
The other person said LG WH16NS40, figured that is what you where referring to when you said it was stock.
370 (2.87/day)
Texas, USA
Pioneer BDR-2213
I have two of these. One in an external enclosure, and one in a comp. They've served me well so far. I don't burn near as much as i used to, but they work every time for any media I've used. Had them for at least 4 years.
Ruru
S.T.A.R.S.
13,013 (2.96/day)
Jyväskylä, Finland
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
Storage 3.3TB of SSDs / several small SSDs
VR HMD Oculus Rift CV1
Aren't most external optical drives just standard drives in an enclosure with an USB to SATA converter?
105 (0.03/day)
Only three 5.25" bays, but it's better than nothing.
