Rogue666
- Apr 20, 2009
- 8 (0.00/day)
Processor | i7-3930k |
Motherboard | ASUS Rampage IV Extreme |
Cooling | Asetek 570LC |
Memory | G. Skill Ripjaws 8GB 1866MHz (x4) |
Video Card(s) | nVidia GTX 680 (x2) SLI |
Storage | Crucial M4 512GB SSD |
Display(s) | Dell U2412M (x3) |
Case | SilverStone custom |
Audio Device(s) | Creative SB Zx |
Power Supply | Silverstone Strider Gold 1200W |
Software | Win 7 64-bit |
I was lazy this time around and had a system built for me with an i7-3930k conservatively overclocked to 4000MHz. I've been testing my temps with real temp and prime and they seem very hot to me. The system is water cooled with an Asetek 570LC, which is a closed system with two 120mm fans running push/pull at a fixed(3-pin connectors) 1400rpm. See below for the temps. The manufacturer is telling me the temps are fine, but 86'C o/c and 77'C stock seems very hot for water cooling. At idle the hottest core is around 39'C. The ambient room temp is around 23'C.
Are these temps ok? If not, what do you suggest? Remount the heatsink with new thermal paste? Faster 4-pin fans with controllable speeds? Recommendations for paste and fans would be welcome if that's what you think I need.
The system is built on an ASUS Rampage IV Extreme with Win7 64 Pro.
Thanks for any advice.
Here is Real Temp calibration with Prime run at small FFT and my 3930 overclocked to 4000MHz:
Here is the same with the 3930 run at stock for comparison:
