Are my ssd temps high ?
246 (0.64/day)
System Name SYSTEM
Processor RYZEN 7 5700X
Motherboard TUF B550M GAMING PLUS
Cooling AG620 CPU COOLER
Memory 16GB RAM DUAL CHANNEL 3200MHZ STOCK
Video Card(s) RTX 4070 GIGABYTE 12GB WINDFORCE
Storage 1TB HDD 256GB SSD
Display(s) LG ULTRAGEAR 144HZ
Case AIGO DARK FLASH
Audio Device(s) MOTHERBOARD AUDIO
Power Supply XPG ADATA PYLON 650W
Mouse REDRAGON COBRA M711 V2
Software WINDOWS 11
Hello
I have a crucial 256 sata for a good time and it never reached that much of high temps ( 30 idling and 40 ish with usage )
However , i´ve recently bought a wd green sata 1tb and it idles at 40 ish and can get up to 47 when downloading / installing games on it
They ´re both in the ssd tray (pattern case position )
they´re not in contact with each other ( the wd has some psu cable above it but that is it , it is not being subjected to excessive cable force either)
I have one fan to the drives as well
Could something be causing it maybe ? like sata cable ? Does i matter the psu sata cable i use ? My psu is xpg adata pylon 650w
I have both new sata cables that came with my msi board and my PSU doesn´t have any problem and the cables are all OK
Thanks
1,348 (3.72/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
I have a couple WD drives green ones that both have large cache and seem to run about the same temperature.
The good news is they are rated up to 70c operating temps, so I think you're doing just fine.
246 (0.64/day)
System Name SYSTEM
Software WINDOWS 11
ah i see
i thought it was something wrong at first since my crucial is about 10 degrees lower
127 (0.12/day)
Processor Intel i5 9400f
Motherboard MSI Z390 Gaming Plus
Cooling SilentiumPC Fera 3
Memory 2x 8GB Corsair Vengeance LPX 3200 16-18-18-36
Video Card(s) MSI GTX 1660 Super Ventus XS OC
Storage 500 GB Kingston A2000; 1 TB Kingston A2000; 1 TB HGST Travelstar
Display(s) AOC 24G2U
Case SilentiumPC Signum SG1
Audio Device(s) Creative Pebble Plus; Logitech G533
Power Supply beQuiet Systempower 9 500W
Mouse Logitech G403 Hero
Keyboard HyperX Alloy Origins (Red)
They most likely just have their temperature sensor in different positions.
1,348 (3.72/day)
Nowhere
Processor 14700K
Storage 980 Pro
Case Open bench
VR HMD Quest 2
Software Windows
ah i see
Mine have 16mb of cache, I think this is why they might be a little warmer running. A lot of drives seem to come only equipped with like 8mb.
Great storage drives though. I like that they sleep, but it takes a few seconds for them to wake up.
No worries, they'll last a very long time. I have 2 640gb models. And have had them for at least 10 years now. Never once an issue with them.
3,556 (1.68/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Have a look in hwinfo, I wonder if the crucial has 2 sensors.
But either way even the higher temps are fine.
246 (0.64/day)
System Name SYSTEM
Software WINDOWS 11
thanks everybody for the input
i thought i got some bad unit or something but if it is fine then ok
gaming on the ssd has lower peaks as well than constantly downloading / installing on it (47c)
While gaming it stays like 35 38 degrees ( wd 1tb )
the crucial has lower average temps though
499 (0.23/day)
I have a WD Green SN350 2TB in my Lenovo T14 and it is 35C all day every day. The 15W CPU heat seems to be the main source heat.
