jmnielsen7
- Jun 22, 2023
- 11 (0.02/day)
I bought a new HP Envy laptop (17t-cr0000) and want to run Pro Tools on it for audio projects with varying sample rates. The problem is, the Realtek card is locked into 48kHz, and all my Pro Tools projects at 44.1kHz will not open because the chip "is not capable" of that sample rate -- at least according to what Windows shows me. But I'm not 100% convinced (yet) its actually a hardware limitation as much as it is a driver limitation of the HP provided RealTek Driver + whatever "Bang & Olufsen" throws into the mix.
I shared screenshots and a problem description on the HP forums here (*please view for OS specific details*). See there for screenshots from Device Manager, the Advanced Sound settings in Control Panel, and my Pro Tools error.
If I decoded the ID correctly (using this reference) for my Realtek chip here, based on 0245 it is using the ALC245 codec. Googling "ALC245" consistently brings up HP Envy search results, so seems to be barking up the right tree.
What I would hope to see is more PCM audio sample rates than 48000 Hz, like this example output from GitHub for an ALC256 codec shows:
I honestly don't know how those codec codes work, and if other codecs could be applied to the same chip, but I figured I would ask if there are non-HP versions of Realtek drivers I could use so I don't have to return this laptop that I just purchased (with only 7 days left on my return policy). (Is the ALC numbered codec independent of the actual hardware capabilities, meaning can more than one codec be used with the same chip?)
TL;DR Is there an alternate driver for the Realtek chip that my HP Envy has which might give me more Audio Sample Rates, or is it the hardware and I'm just stuck?
