Are there HDMI -> Displayport cables?
2,698 (0.42/day)
Oulu, Finland
System Name Enslaver :)
Processor Ryzen 7 7800X3D
Motherboard ASUS TUF Gaming B650-Plus
Cooling CPU: Noctua D15 G2, Case: 2 front in, 1 rear out
Memory 2x16GB Kingston Fury Beast RGB 6000MHz
Video Card(s) ASUS TUF RTX 4070Ti OC
Storage Samsung Evo Plus 1TB NVMe , internal WD Red 4TB for storage, WD Book 8TB
Display(s) LG CX OLED 65"
Case Lian Li LANCOOL II Mesh C Performance
Audio Device(s) HDMI audio powering Dolby Digital audio on 5.1 Z960 speaker system
Mouse Logitech G700
Keyboard ASUS Strix Tactic Pro
Software Windows 11 Pro x64
Hello,
I got a PC with 1x displayport and 1x hdmi connector at work and need a hdmi->displayport cable to connect the second monitor to PC. Monitors are displayport, DVI and VGA only. Problem is that with a cable that has displayport on one side and hdmi on the other there is no picture. College said it technically not possible to get signal with that cable from hdmi on pc to displayport on monitor. College also said it would work the other way displayport on PC and hdmi on monitor?
4,573 (0.93/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
2,698 (0.42/day)
Oulu, Finland
Mouse Logitech G700
17,563 (2.40/day)
Yes, but they're all active cables that needs to be plugged into a USB port as well.
Something along the lines of this.
However, HDMI to DVI doesn't need an active cable. You're limited to lower resolution on those though, unless it's dual-link DVI.
2,698 (0.42/day)
Oulu, Finland
Mouse Logitech G700
1,286 (1.64/day)
Processor 7950X3D
Motherboard AsRock X670E Pro RS
Cooling Arctic LF III 360
Memory 64GB 6000 CL30
Video Card(s) RTX 4070 Ti Super
Display(s) MSI MAG401QR
Case Phanteks P600s
Power Supply Vertex GX-1000
What's the screen resolution and do you need audio? If 1200p or under, and no audio, use an HDMI to DVI cable or adapter.
2,698 (0.42/day)
Oulu, Finland
Mouse Logitech G700
Hey thanks alot, had a HDMI to DVI at home. Just didnt notice it before you suggested that. :)
1,547 (0.73/day)
London, UK
Software ❶ Win 11 ❷ 10 ❸ 10
HDMI can't output a DP signal but DP can output a HDMI signal.
To make HDMI>DP possible you will need some type of adapter. Maybe check on Amazon or something for a HDMI to DP adaptor.
EDIT: theLostSwede dropped a link above. Something like that.
566 (0.11/day)
mississauga, on, Canada
System Name YACS amd
Processor 5800x,
Motherboard gigabyte x570 aorus gaming elite.
Cooling bykski GPU, and CPU, syscooling p93x pump
Memory corsair vengeance pro rgb, 3600 ddr4 stock timings.
Video Card(s) xfx merc 310 7900xtx
Storage kingston kc3000 2TB, amongst others. Fanxiang s770 2TB
Display(s) benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H,
Case lian li LANCOOL III
Audio Device(s) obs,
Power Supply FSP Hydro Ti pro 1000w
Mouse logitech g703
Keyboard durogod keyboard. (cherry brown switches)
Software win 11, win10pro.
there are none, you need an active adapter… and then you need to make sure you get one that will do 4k60, not 4k30…
(DP is packetized data, HDMI is just a data stream)
