I've had Disable Turbo checked since I started undervolting and it seemed to keep temps below 80c (iirc without any turbo ratio changes it'd run at 90c+ causing it to overheat), I'll disable it then do some tests with it, I'm going to lower the turbo ratios to 32 and see how hot it'll run underload.
And yes, I've been able to run a 960M TS Bench test with no errors so -80mV seems to be a stable undervoltage, I'll also apply max value to IccMax, the PL4 values to 0 and change the Intel GPU and iGPU Unslice to normal.
BD PROCHOT doesn't seem to pop up on the limits window so I'll leave that as it is for now, Final question I have is should I be applying / enabling stuff in the TPL window such as Power Limit Controls, Speed Shift and TDP Levels?
Thanks for giving some recommended settings too!
