AS SSD Very Low Score - 14
scawthon
2 (0.00/day)
Hello;
I am looking for recommendations on other actions I should try. I am stumped on what to try next. I have applied all that I know. Here is where I am at:
AHCI confirmed - Intel 100 Series/C230 Chipset Family SATA AHCI Controller
realigned 4k segments
compression off
indexes off
trim enabled: fsutil behavior query DisableDeleteNotify; DisableDeleteNotify=0
Windows 7 Resource and Performance Monitor - Physical Disk Counters Section: Avg. Disk Queue Length = 1
Windows 7 Computer Performance: Processor: 7.8, Memory(RAM): 7.9, Graphics: 7.9, Gaming Graphics: 7.9, Primary Hard Disk: 5.9
9,781 (2.17/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Are you certain that's a solid-state drive? It doesnt look like one in the assd description. Do you happen to have a Seagate drive as well installed on your computer.
Never mind I was assuming you were testing a solid-state drive because you're using a solid-state drive application. i dont know what those scores mean, but i wouldnt worry about what the windows user index rates anything. just trnasfer some files from & to your drive in question, and judge by that. AHCI would be better than SCSI btw.
AsRock
TPU addict
19,176 (2.98/day)
UK\USA
Cooling D15
Yeah looks like a Seagate HDD, but they do SSD's too if i remember right.
In fact
https://www.newegg.com/Product/Product.aspx?Item=N82E16822178340
OOps :p, maybe i will read your full comment next time jboydgolfer :p.
Anyways they look a little low even for a HDD maybe try HDTach would yeld better results. Never mind the red BAD text warning
2,900 (0.65/day)
Fort Worth, TX
System Name LGA775 | BoX-Server
Processor Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ
Motherboard ASUS PQ5-EM | ASRock
Cooling 120MM Heatsink (2-FANs) | Custom HSK 90mm
Memory DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB
Video Card(s) NVIDIA Quadro K2200 4GB | Intel
Storage 500\500/240/240GB SSDs 120GB Laptop IDE
Display(s) Asus 24"
Case DIYPC N1e-SPORT | CoolerMaster 110
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Rosewill RGB
Keyboard Rosewill RGB
Software WiN10ET/WiN11ET
Dear lord that is awful speed. You sure it is a SSD and not a custom SSD (by buying a pci-e adapter and a msata card) that's just a non brand one. Out of all I've bought I've never seen that.
scawthon
2 (0.00/day)
This is embarrassing. I thought I replaced HDD with SSD a while ago. And all along the information showing an HDD was right there in front of me and I did not see it. If it were a snake, I would be writing you a dead man today. Somehow, it got marked as done and it did not occur to me that I still had an HDD so, I was looking at everything else. I need to put this on my task list and replace it soon. That in itself will really help performance and I will run the test again.
Thank you all for your reply.
