- Oct 9, 2007
- 47,279 (7.53/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
FunkyIT scored an ASRock Arc B580 Steel Legend 12 GB "Battlemage" graphics card that they previewed on their channel. The card appears fairly large, considering that Intel is positioning the B580 to be an upper-mid range GPU, if we go by the naming convention of the previous "Alchemist" generation, and the A580. The ASRock Steel Legend product features a large, aluminium dual fin-stack cooler featuring a trio of fans, and what looks like a metallic, dual-tone cooler shroud and backplate combo. The PCB underneath is a little over half the length of the card, which means nearly half the heatsink's airflow passes through the card and out large cutouts in the backplate.
The card draws power from a pair of 8-pin PCIe power connectors, a combination rated for up to 375 W power delivery. Previous leaks suggest that the ASRock B580 Steel Legend features RGB lighting in the form of a large Steel Legend ornament on top of the card, and the three fans each feature RGB LED lighting. FunkyIT also showed off the retail box of the card. There's no change in the Intel Arc main branding, but attention is given to the Intel XeSS technology logo, which mentions "AI Upscaling." The XMX cores, which are the main AI acceleration hardware on discrete Arc GPUs, get their own separate branding on the box. Intel isn't just going after gamers, but also creators, and AI acceleration markets. "Play, Create, Generate," reads the box.
