ASRock B560 Steel Legend Motherboard stops at VGA error light any advice?
110 (0.07/day)
System Name Pre-10 year plan
Processor FX 8350
Motherboard Asus M5A97 v2
Cooling Cooler Master Hyper 410
Memory 4 x Hyper X 4gb DDR3 1600
Video Card(s) Sapphire R9 390 8gb
Storage 128gb SSD boot drive 512gb SSD
Display(s) 1 x Benq 27" 4k 60Hz, 1 x AoC 27" 1080 165Hz
Case Thermaltake Level 10 Combat edition
Audio Device(s) On board
Power Supply AX1200i
Keyboard Logitech G512
Hi all you helpful people.
I have recently started building a new pc but have hit a snag. The ASRock B560 motherboard (new old stock, ebay) VGA post light comes on during POST and it goes no further. It passes the CPU and RAM test lights no problem.
Intel i5 10400F cpu so I cannot try onboard graphics
2 x 8GB DDR4 3200
Some no-name 512Gb M.2 hard drive in the first slot
Game Max 700w Rampage PSU - which Ive used in previous builds and has always been ok
Ive tried a GTX 1060 that is used in another build (this very build im using to type this) so I know thats ok, Ive also tried a spare GTX 970 and GTX 770.
Ive tried graphics cards in the second PCiE slot same result.
In each case the graphics cards are getting power - fans spin and where applicable RGB lights up.
I see no damage to either PCiE slot and the motherboard appears unused in so far as it came sealed with back plate still in its sealed wrapper.
Tomorrow I will fit a different PSU but i genuinely dont believe its that. Any suggestions? Board has cost me £100 and I cannot afford to replace it unfortunately.
51 (0.04/day)
System Name Tiny Tim
Processor i5-8500
Motherboard HP Elitedesk 800 G4 65w
Cooling Stock copper 65w rated
Memory 2x8gb HMA81GS6DJR8N-XN SK HYNIX 3200MHZ DDR4
Video Card(s) Intel UHD 630
Storage Samsung SSD 970 EVO Plus 500GB + SAMSUNG MZVLB512HAJQ-000H1 500GB
Display(s) NEC EA224WMi
Case Stock 1L case
Audio Device(s) Synaptics HD Audio
Power Supply 130W external PSU
Mouse Corsair Katar Wireless
Keyboard Generic Dell Wireless
2 x 8GB DDR4 3200
I *think* those boards should be able to boot without a graphics card (i've done headless on other asrock boards of older generation) though I can't say with certainty as I don't own that particular board and haven't worked with it. Consier checking the manual for this, but either way worth trying to boot without any gpu at all. to see if it behaves differently further without a video card at all.
Also, might recommend removing everything but a single stick of ram and cpu / cpu cooler to make sure there's nothing else going on and resetting the bios (pull battery, cmos jumper if there is one, etc.)
446 (0.83/day)
System Name No.1
Processor Ryzen 9 9900X with custom PBO + 2200 FCLK fully stable
Motherboard B650 Gigabyte Aorus Elite v1.0
Cooling Thermaltake toughair 710 + Thermal Grizzly Kryonaut extreme
Memory Patriot Viper PVV532G740C36K @ 6200MT/s 30-36-36-63 1:1
Video Card(s) Asus TUF gaming RX 7900 XTX OC edition
Storage 1TB T-Force Z44A7 + 2TB T-Force A440 Pro
Display(s) 34 " Asus TUF Gaming VG3A series
Case Antec C8 constellation white edition
Audio Device(s) Asus Xonar AE 7.1 + Logitech Z906
Power Supply Corsair RM1000x V2
Mouse MSI Clutch GM20 Elite
Keyboard Logitech G512 Carbon
OP, this thread from reddit raises concerns about the quality of those Game Max PSUs
110 (0.07/day)
Processor FX 8350
Im aware of the GameMax somewhat dubious reputation but this is the second one ive used (previous one is still running I believe) and not had any issues to date. Not that thats an endorsement, its just me speaking as I find. This is not planned to be the `final` psu for this build, I am planning to purchase a Corsair RM series psu for this build when I can afford it.
Good ideas there, just tried them this this morning but alas none worked.
Ive tried with single stick of DDR4 from a previous build that I know is good, Ive also tried with no graphics card (i wouldnt have thought of that), Ive reset the bios, Ive unplugged all other peripherals, in all cases the pc fires up - lights and fans going. POST light cycle through and stop at VGA.
Im at a loss what to try next. Ive reached out to the seller and hes suggested the usual - check cables, check RAM, try different card etc.
I have found a solution by accidents, and what a peculiar solution it is.
disconnected the display port and just plugged in the hdmi cable. And lo! It works! Isn’t that the weirdest thing?
51 (0.04/day)
Processor i5-8500
Case Stock 1L case
Bizzare! Do you have to plug in hdmi for the igpu or are you talking about your added graphics card? I'd be cautious here. If that's the case, sounds to me like there's might be some kind problem with this board. Maybe make sure the bios is up to date but i'd be cautious with that board (i've had strange video out issues on gigabyte nucs in the past that were fixed with bios flash). great troubleshooting and good luck!
367 (0.40/day)
The VGA light can mean a loose or incompatible cable. As it was a display port cable a monitor is involved, there might be an issue between the monitor input and the display port output from the card or it might just be the cable. It could be that the display port cable cannot be fully inserted into the video card output even though it seems to be.
14,238 (6.42/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
OP has a 10400F, which means, there's no iGPU to rely on.
Bad graphics card, perhaps? Do you have another one to test it?
110 (0.07/day)
Processor FX 8350
Ive tried the follwing graphics cards; GTX 1060, GTX 770 and GTX980Ti. All these cards I know work on other pcs. Looking online someone else had a similar problem and it turned out to be the DP cable. This really threw me as I have used that same DP cable for several builds without issue, and once the pc booted up it was happy to have the DP cable connected, but boot up with cable connected? not a chance!
I dont have a spare DP cable so cant sort that at the mo but I do have a DP tyo HDMI adapter and im now using that without issue.
But all in all, what a peculiar issue eh?
