ASRock Readies USB 3.0 and SATA 6 Gb/s Equipped P55-Deluxe3 Motherboard
46,780 (7.64/day)
ASRock is developing a new upper-mainstream socket LGA-1156 motherboard based on the Intel P55 Express chipset: the P55-Deluxe3. This motherboard builds on the chipset's feature-set, and offers USB 3.0 and SATA 6 Gb/s connectivity. It further borrows from a design ASUS innovated with its P7P55D Premium, which makes use of a PCI-Express 2.0 bridge chip, which connects to the P55 chipset over its PCI-Express 1.1 x4 link, and gives out PCI-Express 2.0 x1 connections to the USB 3.0 and SATA 6 Gb/s controllers. The SATA 6 Gb/s controller gives out two SATA ports (color-coded white), and an IDE connector. The NEC USB 3.0 controller gives out two external ports color-coded blue.
Expansion slots include two PCI-Express 2.0 x16 (electrical x8 when both are populated), a PCI-Express x1, and two PCI slots. Both NVIDIA SLI and ATI CrossFire, are supported. Other connectivity options include 8+2 channel audio with SPDIF connectivity, gigabit Ethernet, eSATA, FireWire, and a number of USB 2.0 ports. The ASRock P55 Deluxe3 should be priced somewhere in the $180~$200 range.
16,718 (2.33/day)
Is it just me, or are ASRock boards starting to look more and more like Asus boards? The chipset cooling is arse though...
I
InTeL-iNsIdE
They are a sub division of Asus, though they are getting better and moving into a space of their own, on the same note, I see they are now using the "Delux" brand that Asus has done before
theorw
770 (0.12/day)
Athens GREECE
Processor C2D 8400@ 4,05GHz(currently)1,36v
Motherboard DFI LP x48 DK T2RS
Cooling XIGMATEK 1283 w/ bolt-thru kit/SCYTHE Mushashi x2
Memory Crucial BALLISTIX 6400 @900MHz 2,00v
Video Card(s) HD 5770 1040/1400 unlocked/musashi
Storage SG 120GB+WD 160GB
Display(s) 24" FLATRON W2442PA Full HD
Case COOLERMASTER HAF 932
Power Supply Thermaltake PUREPOWER RX 600
Software Vista ultimate SP1
Benchmark Scores VANTAGE:11700 3DMARKO06:18600 FURMARK:9K
I d get that board for sure if it costs 50EUR less than the regular boards!
16,718 (2.33/day)
Uhm, no, they're not a sub division, they're made by Pegatron and as soon as Pegatron is spun off from Asus, ASRock is going to go after Asus' market. It'll happen sooner rather than later, just watch this space...
7,662 (1.22/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
why aim for second place though? (asus)
151 (0.03/day)
Fremont, CA
Processor Intel Core 2 Quad Q9550 @ 2.83 GHz
Motherboard ASUS P5Q Pro
Cooling Thermalright Venemous-X
Memory OCZ Reaper HPC 4GB DDR2 1066
Video Card(s) XFX HD-587A-ZNF9 Radeon HD 5870
Storage Western Digital Caviar Black WD6401AALS
Display(s) ASUS VH242H
Case Lian Li PC-A05NB
Power Supply CORSAIR HX Series CMPSU-620HX
Software Windows Vista Ultimate 64-bit
Wow an ASRock board that isn't hideous! Liking the pci-e layout and great color scheme. I was hoping it would be cheaper though, not too happy with the price when EVGA or ASUS also have amazing offerings at that segment. Nice step in the right direction though, ASRock.
Wile E
Power User
24,318 (3.74/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
Pegatron is owned by Asus. Asus created them in 2007 under their restructuring. So, until the time that Pegatron splits (if they ever do), ASRock is still an ASUS brand.
Kitkat
768 (0.14/day)
at this rate its waaaaaaayyyyy later lol :roll:
Mussels
Freshwater Moderator
58,413 (8.09/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
bad placement for the USB 3.0 ports - guaranteed to be the most cluttered area behind the mobo. network cable will definitely be in the way, as well as audio cables.
OnBoard
3,033 (0.47/day)
Finland
Processor Core i5-750 @ 3.6GHz 1.136V 24/7
Motherboard Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby!
Cooling Alpenföhn Brocken HeatpipeDirectTouch
Memory Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24
Video Card(s) Gigabyte GTX 460 1GB OC (mostly stock speeds)
Storage OS: Samsung F3 500GB Games: Samsung F1 640GB
Display(s) new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD
Case new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans
Audio Device(s) new! ASUS Xonar DG & JVC HA-RX700 headphones
Power Supply Cougar CM 700W Modular
Benchmark Scores Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging
It's in that spot for all (at least on gigabyte and MSI boards). Would think that it comes from same place and everyone uses that piece of metal.
Better placing next year with P65 with USB3 integrated.
Mussels
58,413 (8.09/day)
Oystralia
oh yes, its going to be a standard location. its just damned annoying.
We need front ports on cases to support USB 3.0 already.
OnBoard
3,033 (0.47/day)
Finland
But there is no USB 3.0 headers in motherboards yet :)
Agree it's an annoying location for the used it would be getting as in not constantly plugged in. Haven't got any usb3 devices, so it doesn't annoy me yet :p
146 (0.03/day)
System Name Uhh WTF
Processor A10-5800K
Motherboard ASrock FM2A85X-Extreme4-M
Cooling Coolermaster Vortex PLUS
Memory 8GB Samsung 1600MHZ 1.35v
Storage 120GB Agility3
Display(s) ASUS 23" TN Panel
Case Silverstone SST-PS07
Power Supply 550W Antec Modular "Basiq" 80PLUS
Software Windows 8 x64
I love ASrock, I've owned 2 ASrock boards and work w/ one in my tech class and they have disappointed me. Also, knowing ASrock this board will have more features than most boards that cost $30 more than it.
p_o_s_pc
F@H&WCG addict
13,006 (2.07/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
the placement of the USB ports are like that on my Asus board and on my gigabyte granted there all USB 2.0 on those boards(i think the X58 is 2.0) but still never has been a problem for me
Mussels
58,413 (8.09/day)
Oystralia
my point is simply this: if they want USB 3.0 to tale off, put the ports in the easiest to reach location! they're backwards compatible to 2.0, so they should be in the most prominent, easy to reach location. Try fitting a flash drive in there, between the LAN and audio cables... not gunna happen.
Wile E
Power User
24,318 (3.74/day)
My flash drives work just fine there, even my Xporter XT. Yeah, up top would be better, but unless you have really huge flash drives, it isn't a problem.
Mussels
58,413 (8.09/day)
Oystralia
not saying its impossible, just saying its irritating. for the most important USB ports on the system, they gave them the worst placement.
Wile E
Power User
24,318 (3.74/day)
Meh. Mountain out of a molehill. Any port under the LAN ports are irritating, but they are just a fact of life.
T
TAViX
You guys are all right here about some bad positioning and stuff. But I've noticed nobody realized the true flaw of those type of design, which is the ATX. ATX it's an old format now, we need another one soon. I think this is one of the last components of the PC which wasn't updated over the years. I agree, you will need a new case for your PC, but this will be nothing in the era of double and triple XCrossfire/SLI setups and stuff. We need a new format and fast, otherwise will just continue having this problems over and over again...
Brewster0101
34 (0.01/day)
UK
Processor AMD X720 BE @ 3.4GHz
Motherboard MSI G65
Cooling Akasa
Memory 2 x 2GB OCZ Platinum @ 1600mhz
Video Card(s) Saphire 4870
Storage Samsung F1 - 750gb
Case Lian Li PC-A70b
Power Supply Zalman ZH 850
Software Vista Pro 64bit
Its got a FDD socket .. Waste of money.
Would even say the IDE socket can be got rid of too now. High end boards should not have a FDD or IDE plugs anymore. Lets get them phased out please.
Also ram slots should be spaced apart more. Ram coolers are getting bigger and bulkier.
The tops on the heatsinks around the CPU are silly too, restricts airflow.
Two PCI slots? again an old piece of hardware that needs phasing out, think 1 would have been enough.
Mussels
58,413 (8.09/day)
Oystralia
what the hell is IDD?
Brewster0101
34 (0.01/day)
UK
Motherboard MSI G65
Cooling Akasa
