- Oct 19, 2007
- 1,143 (0.18/day)
- Lancs,UK
System Name | Mr_average ( hoping 1 day to upgrade to Mr_above_average ) |
Processor | AMD Ryzen 7 7700x |
Motherboard | Asrock B650 Steel Legend Wi-fi |
Cooling | Deepcool AS-500 Plus - White | 6 Lian Li ST120mm case fans - White |
Memory | 32gb Corsair Vengeance RGB 2x16gb 6000mhz DDR5 - White |
Video Card(s) | Asus Dual GeForce RTX 4070 12GB OC |
Storage | 512gb Sabrent Nvme | 4tb Samsung SSD | 2tb WD Blue SSD| 1tb Crucial P3 Nvme| 1tb WD Blue HDD = 8.5tb |
Display(s) | D1: LG Ultragear GL850-B 27" 1440p 144hz | D2: Asus Tuf - VG249 24" 1080p 144hz |
Case | Lian Li Lancool 2 Mesh RGB - White |
Audio Device(s) | Creative Gigaworks T20 Series II | Steelseries Arctis 3 Headset - White |
Power Supply | Corsair TX650M Semi Modular 80+ Gold |
Mouse | Razer Basilisk V3 |
Keyboard | Razer Huntsman V2 |
Software | Windows 11 Pro |
hi all, got a prob i cant fix and was hoping someone might know how to fix it.
problem being on my Asrock B650 Steel Legend wifi , the rgb is lit up at bottom of the board, and whether i enable or disable it in the bios , nothing changes.
have tried updating bios to latest version 3.16, and no change.
at the start it did initially work, but foolishly i installed Asrocks RGB software program (which doesnt even work btw , it just says nothing detected)
since using that software, now uninstalled, im left with the rgb at bottom of board a totally diff colour to the rest of my system.
nothing major, but it sure is annoying seeing an awful brown/gold glow at the bottom, when the rest of the rgb is white.
worst part is it stays lit even when pc is shutdown
id anyone can help, either to turn it off or change its colour to white , ive tried openrgb and signal rgb as well, they dont detect it.
