Asrock RX7700 XT Challenger & PSU
86 (0.12/day)
Processor Ryzen 5 5600
Motherboard ASRock B450M Steel Legend
Cooling bequiet! Pure Rock Slim (BK008)
Memory 16GB DDR4 GoodRAM
Video Card(s) ASUS Expedition RX570 4GB
Storage WD Blue 500GB SSD
Display(s) iiyama ProLite T2252MTS
Case CoolerMaster Silencio 352
Power Supply bequiet! Pure Power 11 CM 400W
Mouse Logitech M590
Keyboard Logitech K270
Software Linux Mint
I'm thinking about buying the mentioned GPU and a new PSU, since my old one is only 450W. I read a suggested PSU is 750W for this card, but I want to buy a 550W bequiet! Pure Power 12M.
I know I should follow the suggested specs, but I'm playing only at 1080p and limit all games to 60Hz and according to TPU review this GPU uses up to 100W with these limitations. My monitor is 60Hz 1080p and there's really no reason for me to change it (iiyama T2252MTS, touchscreen :) ).
Do you thing I'll be fine with the PSU/GPU setup playing the way I mentioned?
355 (2.96/day)
In my point of view only the efficiency from 0% to 100% is important for a power supply. therefore too low wattage can cause over 100% on the output for some case scenarios. I saw in the past that many got rid of low wattage power supplies, especially those in the range of 450-550W
efficiency vs Wattage (I hope you get my point why a high watt number does not really matter - assuming the watt number is high enough for your use case!)
Also consider buying a power supply where you can find a very good efficiency in the range from 0-50 Watt on the output. (It has a reason why this range is hardly measured or specified!)
Some better power supplies have a zero fan mode, which is usually half of the specified Wattage. In my case 50 percent of 750Watt is usually less what my computer needs with an entry Ryzen 7600X, a large X670 mainboard, several case fans and a Radeon 7800XT.
Usually you want to keep a mainboard, a case and a power supply for a very long time. E.g. 10 years.
3,515 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3667MT/s 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (375W current) PowerLimit, 1060mV, Adrenalin v24.10.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2161), upgraded from Win10 to Win11 on Jan 2024
Definitely you don’t need a 750W PSU for a 7700XT.
Card specs
550W is the bear minimum and that depends on the rest of the system too, which you do not state.
You can fill your system specs in detail on your TPU profile page.
7700XT is a 240-250W card, maybe up to 300W in some AIB OC models.
1080p, 60FPS is not that demanding and in most games the card should be powered well below 200W. Some games though can push the power.
A nice quality Gold 550-600W should be ok.
1,650 (1.08/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
The AsRock Challenger wasn't reviewed here, but with a boost clock the same as the two reviewed Sapphire models, I would expect it to have similar power requirements. These models use up to 240 W in games and show momentary spikes of up to 300 W.
550 W should be enough for this card provided that you have a typical setup with a CPU which uses less than 200 W fully stressed. Putting your complete system specification in the TPU user profile would help us make better estimates. Please note that your PSU wattage should cover a worst case scenario plus some reserve, possibly enabling a future upgrade.
86 (0.12/day)
Mouse Logitech M590
Software Linux Mint
I forgot I have my PC specs as signature on another site.
I have:
Ryzen 5 5600 - bequiet! Pure Rock Slim cooler
Asrock B450m Steel Legend
16GB DDR4 RAM - set to 3200MHz atm.
500GB SSD - no plans to add other drives for now
RX570 ASUS
3x 80mm case fans
3,515 (1.84/day)
I have:
RX570 ASUS
3x 80mm case fans
By experience I’d say that this system with a 7700XT should draw around 300-350W avg with spikes up to 400-450W assuming that the GPU is on full ~250W power.
Again, a 550W should be enough if no CPU upgrade is on the map. Something like 5800X, 5900X, 5950X would require a 600W PSU.
The 5600X is low power CPU and even if a 5700X3D is in your thoughts it’s on the same level of power.
FreedomEclipse
~Technological Technocrat~
24,063 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Benchmark Scores ლ(ಠ益ಠ)ლ
A RX7700 XT is overkill for 1080@60fps. You can get away with an older RX6800 or 6700XT. The added benefit of the older cards is 1. it SHOULD be cheaper if you can find them and 2. The 6800 has more V-Ram (16GB vs 12GB)
Both the 6800 and 6700XT have enough grunt for 1440p (I currently have an 6700XT and game at 1440p. easily 70-165fps in a LOT of games.) if you do upgrade to a better monitor.
The 6800 is still a very very capable card despite what others may say.
Before you make any sort of decision though. RDNA4 is literally over a month away (should be hitting us in the face January next year) and I highly suggest waiting and seeing what RDNA4 has to offer before hunting for an upgrade to your RX570. If RDNA4 doesnt appeal to you. Then at least the other GPUs should be cheaper.
(if you want a cost effective upgrade that is)
Holding Mel Gibson GIF by KiwiGo (KGO)
86 (0.12/day)
Mouse Logitech M590
Software Linux Mint
Thank you guys. I have a better picture of what to do.
Do I mark the thread as solved?
78 (0.21/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative P580 boxes, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
3,515 (1.84/day)
The 7700XT sure is overkill for 1080p/60FPS, today… How about in 2-3 years?
OP has RX570 meaning not frequent upgrades.
And the 6800 is exactly on the same performance level, so overkill too… 6700XT has also 12GB as 7700XT so…
Unless OP can find it 6000series significantly cheaper, I don’t see the point going with older.
BTW, where I am 6000series is more expensive (10-15%) than 7000 for the same level of performance.
FreedomEclipse
24,063 (3.74/day)
London,UK
If its an issue in 2-3 years then the OP can ask again what would be better than the 6000 series. He has 2-3 years to save some money.
OP has RX570 meaning not frequent upgrades which also means that the OP probably doesnt play games that require an extremely beefy CPU and the 6800 and 6700XT have already proved they have enough grunt at 1440p so what is the point you are trying to make? Should I be recommending the OP a 4070Ti? A 4090? Because "how about in 2-3 years??"
Nobody knows what games will be like in 2-3 years but Id say the 6800 and 6700XT will still have enough power for 1080p gaming.
For example How long did it take for the 1080Ti to be relegated to an 1080p card? The 1080Ti is 7 years old and can still do 1080p@60FPS and more if you dont want things like ray tracing which is obviously going to kill it.
Not really. the 6800 is slower than the 7700XT by some 10-20fps here and there. But its because its slower and older, (possibly) cheaper with more V-RAM that I recommended it. if the OP only wants 1080P@60FPS and the cards I mentioned are perfect and still have enough power for 1440p - it would be the most cost effective solution if available.
If you dont believe me about the 7700XT vs 6800 - you can check out the most recent Intel ARC A770 review. Both cards are there. And where the 7700XT doesnt do well. Neither does the 6800. So both of them will suck at the same time
The higher memory bus of the 6800 should also be better when it comes to running higher resolutions so that may fair better in the long term. My money would be on the 6800 unless I was penny pinching then it would be the 6700XT or 6750XT
Finding those cards is the key issue here. I can still find them in the UK. £350 for an XFX Speedster SWFT319 6800. An 7700XT is the same price.
y2faulty
21 (0.53/day)
well I wouldn't buy a new card right now anyway, honestly.
that being said, I wouldn't skimp on the PSU either. You definetly don't need 750w, but spending money for more powerful and especially, better quality, psu it's not a cost, it's an investment for the future.
86 (0.12/day)
Mouse Logitech M590
Software Linux Mint
This is precisely why I chose RX7700 XT over RX6800. It's cheaper where I live. With current black week sales it can be around $50~$80 less. RX7700 is more efficient as well, and with the electricity prices in Poland, it matters a lot.
You ppl are right I play casual games. The most demanding would be No Man's Sky. RX570 can deal with 1080p and low settings to some degree, but its age shows.
Why RX7700 XT? Future proof. I have a cooler with 120W TDP rating for a 65W CPU, RAM with 3600MHz XMP, running at 3200 (not interested in overclocking). You see the tendency? Buy stronger it will last longer . I considered RX7600, but that's changing RX570 for a slightly newer one.
Oh, and I bought my RX570 after crypto craze. Lots of GPU's for sale at that time hehe. It was in a mining rig (asked the seller) and needed BIOS change (TPU database was a life saver). Had it over 2 years.
