ASRock Showcases ATX 3.1 & PCIe 5.1 Power Supply Units at CES 2025
Nomad76
790 (3.39/day)
ASRock is presenting its complete range of power supply units at CES 2025, featuring the Taichi, Phantom Gaming, Steel Legend, and Challenger PSU series. Fully compliant with Intel ATX 3.1 and PCIe 5.1 standards, these PSUs can handle peak power loads ranging from 200% to 235%. They are equipped with 12 V 2x6 cables, capable of delivering up to 600 W through a single cable. Additional highlights include a 5 V BOOST function for improved stability, 100% Japanese capacitors, Infineon CoolMOS, and SiC SBD technology.
The ASRock Taichi series power supply unit is certified for 80 Plus and Cybenetics Titanium efficiency and also received Cybenetics LAMBDA A+ ultra-quiet certification. These PSUs are available in 1650 W and 1300 W models, feature fully modular cables, two native PCIe 12 V 2x6 cables, all-Japanese capacitors, Infineon CoolMOS, SiC SBD, NTC sensor to monitors connector temperatures in real-time and are backed by a 10-year warranty.
Addressing to the needs of gaming enthusiasts, the Phantom Gaming series PSUs offers a wide range of wattage options such as 1600 W, 1300 W, 1000 W, 850 W, and 750 W models. The PSU series have 80 Plus Gold efficiency certification and Cybenetics Platinum & Gold ratings, along with LAMBDA A acoustic certification. ASRock Phantom Gaming features a fully modular design, native 12V-2x6 connectors, premium all-Japanese capacitors, NTC sensor to monitors connector temperatures in real-time and a 10-year warranty.
The Steel Legend series power supply units are available in "Steel Black" and "Steel White" variants, housed in a compact 150 mm casing with a fully modular flat cable design. They come in 1000 W, 850 W, 750 W, and 650 W models. The series is certified for 80 Plus Gold efficiency and Cybenetics Platinum and Gold ratings, along with LAMBDA A+/A/A- acoustic certifications. Each unit is backed by a 10-year warranty.
64 (0.21/day)
System Name SOCIETY
Processor AMD Ryzen 9 7800x3D
Motherboard MSI MAG X670E TOMAHAWK
Memory 64GB 6000mhz
Video Card(s) Nvidia RTX 3090
Storage WD SN850X 4TB, Micron 1100 2TB, ZFS NAS over 10gbe network
Display(s) 27" Dell S2721DGF, 24" ASUS IPS, 24" Dell IPS
Case Corsair 750D
Power Supply Cooler Master 1200W Gold
Mouse Razer Deathadder
Keyboard ROG Falchion
VR HMD Pimax 8KX
Software Windows 10 with Debian VM
1650w holy...
I was going to ask how people manage to use that much power with SLI being dead, but right... it's probably still for multi-GPU but instead in the AI realm.
77 (0.08/day)
UK
System Name JustGaming
Processor Ryzen 9 7950x3D
Motherboard Asus ProArt X670E-CREATOR WIFI
Cooling Thermalright Peerless Assassin 140 Black
Memory G.Skill Trident Z5 DDR5-6000 CL32
Video Card(s) Inno3D RTX 4090 24Gb
Storage Crucial T500 2TB x 3
Display(s) Asus ROG Swift OLED PG32UCDM
Case Asus ProArt PA602
Audio Device(s) SSL 2+
Power Supply SuperFlower 1200 Platinum
Mouse Razer Deathadder v2
Keyboard Montech Mkey TKL
Keeps the 5v from drooping too low, if you have a lot of storage devices etc.
501 (0.13/day)
Let's hope they send TPU a unit to test. ASRock has never let me down as far as quality goes, would love to use their PSU's assuming they've built them right.
6 (0.11/day)
Samara, Russia
Processor AMD Ryzen 5 5600
Motherboard ASRock B450M Pro4-F
Cooling Cooler 6 heatpipe double tower "SnowMan"
Memory G.Skill Ripjaws V 16GB DDR4 16GVRB Kit (2x8GB) 3200MHz CL16
Video Card(s) Gainward GeForce GTX 1660 SUPER Ghost 6GB GDDR6
Storage M.2(1Tb+512Gb SSD)
Display(s) Iiyama 24" XUB2493HS-B1 С1
Case DEEPCOOL Smarter LED [DP-MATX-SMTRLED]
Power Supply Seasonic Focus GX-650 80+ Gold 650 Watt
Mouse A4TECH X-755FS
what is another 2-pin connector for?
471 (0.96/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
I wonder who the OEM is. The only other supply I could find with that voltage sense with the 12V2x6 connectors is an ASUS.
It's probably for voltage sense on the other end of the cable. If you have a high-impedance pair of wires going to a sense circuit, those don't allow any current flow, so there's no voltage drop on those wires and the power supply can get an accurate reading of the voltage at the GPU connector. This can then be used to improve stability of the 12V rail.
Edit: this guess turned out to be incorrect, but was based on what others (ASUS) were doing and a fairly common power supply technique in other industries/applications.
77 (0.08/day)
UK
@Ser_g11
Some temperature protection sensor I think.
Edit: yes.
2,190 (2.62/day)
Brazil
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
4,724 (0.95/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
1,000 (0.16/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 970PRO 500GB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
I have fully modular PSUs for some time, and I failed to see the point the Mainboard and recently the first12VHPWR being detachable, especially with the 12VHPWR's reputation.
That two will be used in the 99.9% of the cases.
izy
1,044 (1.13/day)
I guess its "why not" for the price / psu class :) i have a semi-modular PSU , the MB cables are not detachable and its super fine.
