ASRock Z370/Z390 Taichi (and some others, actively modding!) Firmware with Intel Management Engine Disabled, new method
14,376 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Resurrecting an old thread (sorry! o_O) to ask a question about people's experience with disabling ME. I'm on z390 with BIOS v4.30. Got IME disabled - showing as version 0.0.0.0.
And now Windows 10 does not shut down. It hangs on Shutting Down screen with no events in event log indicating any issues. I uninstalled IME from Device Manager and Apps.
Any suggestions?
Start your own thread asking for help, this thread isn't relevant to your issue.
UnsortedReality954
2 (0.00/day)
I respectfully disagree. This issue is a direct result of disabling IME using the firmware mentioned in this thread. The reason for posting is two-fold: 1. A person who goes through with the above method may find themselves in a similar situation. 2. A person who posted the method has the greatest chance of answering it.
21,824 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000(Running 1:1:1 w/ FCLK)
Case Thermaltake Core X31
Software Gentoo Linux x64
It appears he has a new board variant. I do believe his problem is real, but as I use the same board and don't share the issue, I can only assume it's some change beyond my control.
As I no longer offer non-commercial support, my first stop would be to check cmos to make sure we aren't using any ME-features. Things like trusted execution, tpm features, trusted enclaves, none of these features work with the ME disabled and all of them can cause issues. If those are all off, you have done all you can for the moment.
I thought same at first, but he's done his diagnostic homework with me and proved it via PM. It does appear to be my mod in his instance.
21,824 (3.41/day)
Olympia, WA
System Name Pioneer
I can no longer edit the OP, but I've been informed that the links in it are http, which my server no longer supports. Since these links are still useful to some people who like to get the ME cleaned out, could a mod kindly switch my links to https?
I don't know the section mods, so I don't know who to ping. Maybe @Kursah or someone? Lol get me pointed somewhere, I'm clueless.
techyphantom
6 (0.01/day)
@R-T-B
Hi, I'm trying to build a desktop PC with IME removed and I came across this thread, which seems to use the latest parts that would allow me to have a desktop with IME removed/disabled.
The only other way I've found to have a modern desktop pc with IME removed is to use Talos OpenPower CPU, but that's way too expensive.
I had a couple questions if you don't mind:
1. Is the Asrock Z390 Taichi still the newest motherboard that I can disable/remove IME on?
2. Can I put it an Intel i9-9900K into the above motherboard and still disable/remove IME?
3. Will there be any problems running linux or putting in an AMD 6800 XT GPU?
4. I'm trying to build the PC from the ground up, is there anything else I should do or look into before I begin buying all the parts?
21,824 (3.41/day)
Olympia, WA
System Name Pioneer
Sorry for the late reply. Yes, the z390 is the latest I personally did research on. I personally am employed elsewhere now and no longer doing ME research so a bit out of date on the latest, but I do still keep the binaries for the z390/z370 taichi going.
techyphantom
6 (0.01/day)
Ok thank you I appreciate the reply.
I just had 1 last question, will an i9-9900K work or do I need a specific 9th gen intel cpu in order to disable ime?
21,824 (3.41/day)
Olympia, WA
System Name Pioneer
i9 9900k is fine. Good cpu, I'd advise it if going with that board, they are a good pairing and can still do most anything.
techyphantom
6 (0.01/day)
I'm building the PC on pcpartpicker and I got this message when using the Z390 Taichi and 9900K:
The ASRock Z390 Taichi ATX LGA1151 Motherboard supports the Intel Core i9-9900K 3.6 GHz 8-Core Processor with BIOS version P4.00. If the motherboard is using an older BIOS version, upgrading the BIOS will be necessary to support the CPU.
-- will this be a problem?
1,019 (0.55/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
Apart from increasing security/privacy, what extend does the editing of firmware affect the overall performance?
Count von Schwalbe
Nocturnus Moderatus
3,341 (2.78/day)
Knoxville, TN, USA
No, you can flash a new BIOS if you don't already have P4.00 or higher installed already. Really, being as old as it is, it should have at least that one pre-installed. Especially if you are purchasing new.
21,824 (3.41/day)
Olympia, WA
System Name Pioneer
It should ship with that bios on any build you find still floating around.
So the basic steps would be to first flash stock bios 4.30
then flash Z39TC430_NOME.zip?
Yes. Follow instructions in zipfile.
There should be no performance difference. Some ME functions may be unavailable (fTPM etc) but that's expected.
trailerparkjob
2 (0.00/day)
I followed all the steps but I can't find a "PCH-FW Configuration" option in the BIOS settings or anywhere to disable or enable Intel ME.
It does however say "ME Firmware Version 0.0.0.0" at the top left of this image.
Did I do it right or did it not work?
21,824 (3.41/day)
Olympia, WA
System Name Pioneer
That step is somewhat outdated. If it says 0.0.0.0 it is disabled and you are good to go.
thread
1 (0.00/day)
Now I have one Asrock Z390pro4 motherboard,I want to try G3900T on it,but I don't know how to disable ME?
the54thvoid
Super Intoxicated Moderator
13,364 (2.41/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
@R-T-B edit time unlocked
