Asus 4890 Super ML Cap can't run Furmark.Help.
6 (0.00/day)
hi,
my system will "Black Screen" then hang every time after runing Furmark few second.(1.7.0 or 1.6.5, Benchmarking or Stability Test also same problem.)
when the "black screen" happen, the 2nd LED at the back of the card light up! ( total 4 diagnostic Leds at the back)
and the VDDC Current increase to 82.6A ( i use GPU-Z to monitor.) what is VDDC ?? is it a problem?
reset botton cant help to restart the system, need to power off the system and restart again!
i found this on amd forums :
Diagnostic LED meanings for the HD4890 card
D601: VDDC_FAULT
D1601: critical temperature fault
D1602: AUX Hot Plug/Unplug Fault (upper connector)
D1603: AUX Hot Plug/Unplug Fault (lower connector)
but i not sure the 2nd led is which one, because no any indication near the Led.
GPU core temp is 53C /68C (idle/Gameing) but the PCB is very hot (can't put my finger on it more that 2 sec!)
but no problem playing game ...(Crysis, UT3, FEAR2,3DMArk06...)
My system :
Athlon X2 5400+
Asus 4890 1GB DDR5 Super ML Cap (Twin Fan)
Asus M3A78-EMH-HDMI Bios 1107
CORSIAR MS2 6400C5DHX D2 1GB*2
WD 1TB Black
SILVERSTONE STRIDER 560W (12V1 and 12V2 is 20A 20A) should be enough!
XP SP3 English version.
Dell 2407WFP-HC
i try to put back my old card - ASUS 3850 256mb , the 3850 can run Furmark without any problem. so i try to test this 4890 at another system, and the black screen happen again!
the second system is :
AMD X2 5400+
ACBEL IPOWER 460W,(12V1 and 12V2 is 21A 20A)
Abit NF-M2S,
Seagate 500GB SATA
Kingston DDR2 KINGSTON PC 800 2GB.
any 4890 user got this problem?? is it the card problem? because i only brought it 5 days ago...
Thanks.
Mussels
Freshwater Moderator
58,413 (8.00/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
furmark is bad on ATI 48x0 cards.
Dont worry about it, its the program not the cards.
6 (0.00/day)
thanks ..
but why other 4890 can run it without any problem??
and OCCT Perestroïka 3.1.0 GPU test also cause the SAME problem like Furmark... so OCCT Perestroïka 3.1.0 bad also ??? :banghead::banghead:
aquax
141 (0.02/day)
System Name aquax
Processor i7 920 4GHz HT ON
Motherboard Gigabyte EX58-UD4P
Cooling TRUE120
Memory 6GB TR3X6G1600C7
Video Card(s) ASUS TOP HD4770
Storage WD1001FALS / WD6400AAKS
Display(s) Samsung 2333SW soon
Audio Device(s) ALC889A
Power Supply Antec TPQ-850w
Software Vista Ultimate X64
I found some other guy having same problem with his Sapphire Vapor-X 4890, I think it is normal for this cards as I read they are maxed @ 86A VDDC
The PC shuts down after a few seconds when I run Furmark. There are no unusual GPU temps according to RivaTuner before that happens (Max temp I saw was 81C but it also happened at 76C). CPU and MB temps are around 48-50 during CPU Stress test, no crushes there. Also I have run numerous benchmarks like 3D Mark 06, 3D Mark Vantage, Crysis, Devil May Cry 4 and played games for hours without a crash or pc shutting down occurring. The problem only occurs with Furmark.
When I repeatedly run the test after each shutdown the PC wouldn’t start when I pushed the power switch and would eventually start after like 30secs have passed. I tried different combos with the cables giving power to the video card, same result always. So I would say it is more likely a PS issue but since I’m an average user I would really welcome some ideas from you guys, thank you in advance.
System Spec:
CPU: AMD Athlon 64 X2 5200+ 2.71GHz
CPU Cooler: Scythe Mugen
RAM: 4GB (2xDDR2 2GB Mushkin 800Mhz Dual Channel)
MB: Asus M3A78 Pro
VGA: Sapphire Vapor-X 4890
PCI-E: Asus Xonar DX
2xHDD, 1xDVD RW
Case: Thermaltake Armor Jr (2x120mm Fans)
Power Supply: Thermaltake ToughPower 550W
DC OUTPUT
+3.3V____+5V____+12V1____+12V2____-12V____+5VSB
__32A____40A_____19A______19A_____1.0A_____2.0A
+12V1, +12V2 Max Load: 36A
All in stock speeds on Vista 64
2,486 (0.44/day)
System Name Always changing
Processor Always changing
Motherboard Always changing
Cooling Always changing
Memory Always changing
Video Card(s) Always changing
Storage Always changing
Display(s) Always changing
Case Always changing
Audio Device(s) Always changing
Power Supply Always changing
Mouse Always changing
Keyboard Always changing
There is one of those ASUS's 4890's openbox for 150 on newegg
AsRock
TPU addict
19,010 (3.01/day)
UK\USA
Furmark is BS.. It stresses way to much for whats actually required. It be the VRMs that are getting too hot.
GPUTool is MUCH MUCH better to use and safer. It stresses the cards a little extra than games do but not to much like furmark..
As i said in other threads that program needs banning or making it so there there is a big ass warning for 4890 users..
aquax
141 (0.02/day)
System Name aquax
Cooling TRUE120
Yea I like the new TPU GPUTool and I hope the next version will have "detect errors" feature so it will be easy to know if the card isn't stable
Mussels
58,413 (8.00/day)
Oystralia
and 4870... and 4850.... and 4830...
it overheats the VRM's on all of them.
AsRock
TPU addict
19,010 (3.01/day)
UK\USA
And at least a warning for those users to :)..
I think TPU should have a BIG ASS warning to if you plan to use it on any of these cards too..
3,471 (0.59/day)
System Name Acer Aspire V3-771G-53218G75Maii
Processor Core i5 3210M (2,5-3,1Ghz)
Memory 8GB DDR3 SODIMM
Video Card(s) Geforce GT650M
Storage Samsung 830 256GB - 750GB Toshiba drive
Software Windows 7 x64 Home Premium (non-acer-bloatware)
thanks ..
Try and see if this also happens running 3DMark 06/Vantage or playing/benching with intensive games to make sure it's not the benching programs.
809 (0.13/day)
Tampa FL
Processor AMD Ryzen 3800x
Motherboard Asus TUF Gaming X-570-Plus (WiFi)
Cooling Corsair Hydro Series H110i
Memory 32 GB Corsair Dominator RGB DDR4 3200 Mhz @3600
Video Card(s) Asus AREZ RX Vega 64 Strix OC 8GB
Storage Samsung 970 EVO Plus 1 TB
Display(s) Asus PB258Q 25" 2560x1440
Case Cooler Master Master Case 5 Pro
Power Supply Corsair RMx 1000
Software Windows 10 Pro 64
Take it from someone who had a similar problem with his 4870, furmark will overload 20A per rail easily. Try a psu with a single rail. I got a corsair TX750W and haven't had a problem since. The reason is the card tries to draw all power from one rail, which is OK for most things but furmark draws too much power.
