- Jan 6, 2020
- 8 (0.00/day)
- Slovakia
System Name | I have quite old computer, built in 2010, from components from ~2008 |
Processor | Q6600 @ 3 ghz (can go up to 3.6ghz with 1.4v , but don't want to stress so old computer) |
Motherboard | Asus P5Q Deluxe (one of the best socket 775 p45 chipset DDR2 motherboard). Still going after 10 y |
Cooling | Thermalright True Black, with Enermax Magma 12cm fan |
Memory | 4x 2 GB DDR2 A-data 1066 Mhz 5-5-5-18 2.1v |
Video Card(s) | Gigabyte 8800 GTS (G92) 512MB , with Accelero S1 rev.2 Passive heatsink |
Storage | WD Velociraptor 250GB (1-platter disk, 2012 version). I just love them, they are undestructible. |
Display(s) | CRT (yep, I am CRT and low-res lover), Samsung Syncmaster 797mb flatscreen 17'' (searching for 19'') |
Case | LianLi p7n |
Audio Device(s) | Onboard 8 channel (I have external Audio-gd NFB 11.32, but don't have it plugged in) |
Power Supply | Seasonic S12 500W (from 2006, still going, but I dont stress it too much (usually 130-230W range) |
Mouse | A4tech Bloody 7N |
Keyboard | Overclock.net Ducky Shine I (mechanical keyboard, MX red switches, White LED) |
Software | Windows 7 (don't like Windows 10, I'll try to resist at least to 2023 on it) |
Benchmark Scores | I have old computer, so benchmarks don't have sense, Q6600@3ghz have 47 single core Userbenchmark |
Hello, I have older socket 775 motherboard, Asus p5q deluxe, but promoted EPU-6 is not working. After installing, while trying run, it just puts some error message. Probably is made for windows XP.
Will Asus AI suite 3 work instead? On such old chipset, motherboard? I have windows 7 64 bit. I need anything, that can do this: While still overclocked, in idle, I can set low voltage, and speedstep still works, so it decrease CPU multiplier to 6x. I have wattmeter, differance is 20W, and I'm lot in idle, or watching video, reading something. I dont have money for upgrade unfortunately, maybe next year. It really piss me off, that when I overclock, auto-decreasing voltage stops funcioning, and it draws +20 W in idle.
My questions are:
Will Asus Suite 3 work with that MB and p45 chipset? If not, is there earlier version that work? Is there any program, that can set voltages, while overclock etc?
The most important : where can I find download link for AI asus Suite? I cannot find any. Ive tried several times to find it, but without success.
I apprietiate any help, how to make computer using low power states, low voltage in idle, while in load, be able to overclock, so rise FSB up etc...
My questions are:
