ASUS AIO Coolers Will Be Fully Compatible With AMD AM5 Motherboards
47,499 (7.49/day)
ASUS today announced that a selection of its all-in-one (AIO) liquid coolers will be fully compatible with the AM5 (LGA 1718) socket designed for next-gen AMD CPUs. ROG Ryujin, Ryuo and Strix LC coolers will fit via an AM5 mounting kit, while TUF Gaming LC coolers will fit using the existing kits. A list of compatible ASUS coolers is provided in the table below.
445 (0.10/day)
Lithuania
Would be surprising if they weren't wouldn't it? Strange that they even need a new mounting kit.
131 (0.03/day)
Processor 5900x
Motherboard Crosshair 8 Impact
Cooling Air
Memory Hynix C-Die 3200MHz @CL14
Video Card(s) 3080 FTW3 Ultra
Storage Lots
Display(s) Many
Case Something that protects my innards
Power Supply Seasonic 850FX gen2
Some using the AM4 kit, some getting new. Given that AMD officially stated cooler cross compatibility I'd presume the new kits from Asus are alike Arctic's offset kits so that the coolers have better contact with the new and changed hot spots on the CPU
8,229 (2.13/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Not so strange really. Speculation had AM5 mount holes in the same location, but that doesnt mean the mounting bracket is the same.
445 (0.10/day)
Lithuania
What do you mean speculation, AM4 cooler compatibility was one of the things AMD specifically mentioned in the reveal.
382 (0.25/day)
System Name Incomplete thing 1.0
Processor Ryzen 2600
Motherboard B450 Aorus Elite
Cooling Gelid Phantom Black
Memory HyperX Fury RGB 3200 CL16 16GB
Video Card(s) Gigabyte 2060 Gaming OC PRO
Storage Dual 1TB 970evo
Display(s) AOC G2U 1440p 144hz, HP e232
Case CM mb511 RGB
Audio Device(s) Reloop ADM-4
Power Supply Sharkoon WPM-600
Mouse G502 Hero
Keyboard Sharkoon SGK3 Blue
Software W10 Pro
Benchmark Scores 2-5% over stock scores
I think AM4 compatibility is only for the coolers using the standard AM4/5 backplate, but not too sure.
8,229 (2.13/day)
SE Michigan
System Name Dumbass
Yes but at the time they said it, that was not 100% guaranteed.
9,340 (5.12/day)
Louisiana
Keyboard G710+x3
Way to go
Corsairs been doing it for years :laugh:
Ruru
S.T.A.R.S.
13,351 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Way to go
Noctua's practically done it since they stepped in the cooling game. I wouldn't be surprised if their NH-U12 from 2005 would still be compatible with modern sockets with the right mounting hardware.
8,229 (2.13/day)
SE Michigan
System Name Dumbass
The same could be said of most coolers since that time, if the plate is flat and large enough to cover the IHS, yea, mounting hardware would need to be adapted.
It still happens, I had to modify the AM3 brackets for my LF2 because Artic didnt do such a good job measuring every socket it claimed to work on. Mounting hardware... yea.
