ASUS Announces TUF Gaming GT302 ARGB Chassis for High-Performance PCs
17,616 (2.41/day)
ASUS today announced the TUF Gaming GT302 ARGB chassis, a case that makes it easy to build a high-performance PC with great cooling. Prepped and ready for great out-of-the-box cooling, equipped for wide compatibility with high-performance parts, and thoughtfully constructed inside and out for an easy PC DIY experience, the GT302 ARGB resets expectations for a mainstream case.
Great cooling - right out of the box
Most PC builders go big on cooling to ensure an excellent balance of performance and quiet operation. From the moment it is pulled out of the packaging, the TUF Gaming GT302 ARGB gives users a superb foundation for high-end cooling. This starts with a front panel designed first and foremost to maximize airflow efficiency. It is constructed of a wide-open, high-porosity square-type mesh that leaves ample room for fresh air to enter a PC. Four pre-installed 140 mm ARGB case fans move cool air through the chassis. These fans are exceptionally thick, measuring 28 mm in depth. These fans deliver up to 3 mmH2O static pressure and 115 CFM airflow for excellent cooling with quiet operation.
The TUF Gaming GT302 ARGB also has enough elbow room to install a large liquid-cooling radiator of up to 360 mm. The top panel is fully detachable, so it's easy to install and clean the radiator.
Wide compatibility
Not all mid-tower chassis are designed with the space to accommodate larger components, which can be a problem for builders with a taste for high-end GPUs.
With the TUF Gaming GT302 ARGB, the options are wide open. Its two-way PCIe mount can be used to install a graphics card in a horizontal orientation - up to 407 mm long. That is long enough to handle even the mighty ROG Strix GeForce RTX 4090. If a user opts for a vertical orientation, cards up to 125 mm thick can be installed.
Bigger motherboards are on the menu, too. The GT302 ARGB can fit motherboards all the way up to extra-large E-ATX boards (up to 12 x 10.9 inches). Or, for users looking to install a large array of storage drives, the GT302 ARGB's versatile storage drive brackets make it a breeze. With each of these brackets, users can install an HDD and an SSD at the same time, allowing for a mixture of two 2.5-inch SSDs and two 3.5-inch HDDs using only two brackets.
Ready for a BTF build
The new ASUS ecosystem of Back-To-The-Future (BTF) PC components lets users easily build a PC that tucks the cables out of sight for a tidy look—made possible by new motherboards that hide their connectors on the back side rather than the front. For the most part, standard PC DIY components will work with a BTF motherboard, but users will need a compatible chassis. The TUF Gaming GT302 ARGB motherboard tray will work with standard motherboards, but it also includes the cutouts needed to access the connectors on a BTF motherboard.
Even if users are not getting the GT302 ARGB for a BTF build, the extensive cable management options will be appreciated. A roomy 37 mm of space is devoted to routing cables. The cable grommet bar is built with three large straps that make it easy to route two sets of cables. Additionally, three small clips on the rear side panel help to route the 8-pin cable for the CPU.
Easy building experiences
The TUF Gaming GT302 ARGB's detachable top panel, wide component compatibility and cable management options are just a few of many ways that it streamlines the PC building process. Even simply accessing internal components is easy, thanks to the tool-free side panels. The TUF Gaming GT302 ARGB also has a unified front I/O header for plugging in all cables at once.
Convenient connectivity
The TUF Gaming GT302 ARGB case offers conveniences that go far beyond the building process. It is designed for comfortable everyday use as well. A rich selection of ports on the front panel makes it easy to connect a headset and other peripherals. The USB Type-C port on the front is wired for speed—install a motherboard with a USB 20 Gbps Type-C header to put exceptional transfer speeds within arm's reach.
Clean style in two colors
Some chassis options take center stage with bold, brash designs. Others are content to let the other components of a build be the stars of the show. The TUF Gaming GT302 ARGB follows this second path. Its regular geometry and clean lines give it a straightforward style that is easy to match with just about any component on the market.
The GT302 ARGB is available in either black or white. Unlike some competing white models that use the same wires and cables as their black counterparts, the GT302 ARGB uses white cables for the case fans and front I/O so that users can enjoy a harmonious, unified look. With either color option, users will get flexibility with the looks of their PC thanks to the interchangeable side panels. One panel contains a tempered glass window, and the other contains mesh, and users can put them on whichever side of the chassis they wish.
214 (0.07/day)
New Zealand
System Name Katzi
Motherboard Gigabyte Aorus X570S Pro AX 1.1
Cooling Phanteks Glacier 360
Memory G.Skill Trident Z Neo F4-3600C16-16GTZNC (Dual Rank 32Gb)
Video Card(s) MSI Gaming X Trio RTX 3080
Storage Samsung SSD 980 1TB, 970 512GB Evo Plus, 1TB 870 QVO, 960 Pro
Display(s) AOC CQ27G2
Case NZXT H6 Black
Audio Device(s) Creative Soundblaster X3
Power Supply Corsair RMx850
Mouse Logitech G502X Plus & Razer Basilisk V3 Pro
Keyboard Keychron V2 translucent, Gateron Ink Black Silent, lubed & filmed.
Great case, ruined by the Awful TUF branding tramp-stamp on the PSU shroud.
They're really upping their game on their cases, just wish they wouldn't ruin them with hideous branding.
8,198 (2.17/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
My only gripe about this case, no room for a 420.
824 (0.22/day)
Poland
System Name Proper
Processor 5900X + OC
Motherboard GB X570s Elite AX
Cooling WC Heatkiller 3.0 LT
Memory G.Skill 3600 CL16
Display(s) GB M32Q
Case Fractal Define R6 USB C
Mouse Log G502 X LS
Software Win10 Pro
Junkies gonna hate...
It's good that more cases try to be "backside MB connectors"-compatible, but unless motherboard manufacturers start adding 90° cable adapters, we're gonna end up with thiccc PCs.
6,063 (2.88/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
...unless motherboard manufacturers start adding 90° cable adapters, we're gonna end up with thiccc PCs.
I mean, we already had thicc boys like O11 for few years and extra cm or so in the back will help with cable management.
This, "high performance" with no 420 support isn't really high performance oriented. Maybe they want to reserve that to more expensive ROG branded case.
4,550 (0.91/day)
This, "high performance" with no 420 support isn't really high performance oriented. Maybe they want to reserve castrate that for more expensive ROG branded case.
corrected that for you.
Also its odd that front takes 3x140mm/120mm Fans but radiator support for front is castrated to 240 and 280mm sized radiators.
158 (0.32/day)
System Name Spacewhale I (replacement of GR-1) (GR-1 = Game Rig 1 was oprational from dec 2012 until aug 2024)
Processor i7 12700K , grizzly lt contact frame, NT-H1 paste (i7 3770)
Motherboard Rog Strix B760-I (Alienware X51 Stock 2012 R1)
Cooling Noctua NH-D15S (Alienware X51 Stock 2012 R1)
Memory Kingston FURY Beast 2x16GB 6000MT/s DDR5 CL30 (Alienware X51 Stock 2012 R1)
Video Card(s) Zotac 4070 Super Twin Edge PL 70% light OC (1st GTX660 2ND 1050TI 3RD 1660 Zotac)
Storage Samsung 990 EVO 2TB (1 TB Samsung SSD Sata 1 TB Alienware stock non SSD)
Display(s) 32'' LG QHD 180Hz VA Panel (mostly runs on 60Hz perfectly)
Case Meshify 2 Nano (Alienware X51 Stock 2012 R1)
Audio Device(s) Bose Companion 20 (Since 2016)
Power Supply Ion+ 2 Platinum 560W (Alienware X51 Stock external PSU)
Mouse Razer Abyssus
Keyboard Cherry KC 6000 Slim
Software Windows 11 Pro (Windows 10)
Benchmark Scores Runs on energy saving mode, desktop idle power consumption 31 Watt
can anyone explain why it's so explicit mentioned the fan thickness? Why does this decrease noise, why not 2 times 180 front 1 time 140 back for even lower noise, possibly bit poorer air flow coverage
6,186 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Well, even though it appears to be yet anutha 80's boxenclonercopy, at least they added the flip-up/removable top panel, which shows a tad of design thought....AND the BTF compatibility too, which appears to be catching on rather quickly...thankfully... :)
And the fact that the white model is actually WHITE, including the fan & I/O cabling, just adds to the nice aesthetic.
I'm not usually a big fan of AsSus's stuff, but will give them credit when it is due :D
6,063 (2.88/day)
Poland
Wait, what, why?! They have the cutout specifically made for AIOs:
How is it that they don't support 360 in the front?
158 (0.32/day)
Mouse Razer Abyssus
Ruru
S.T.A.R.S.
12,742 (2.92/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X @ PBO +200 -20CO
Cooling Arctic Freezer 50, Arctic & Corsair fans
Memory 32GB Kingston HyperX Fury DDR4-3466
Storage 3.3TB of SSDs + 3TB USB3.0 HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
Mouse Logitech MX518 + Asus ROG Strix Edge Nordic
VR HMD Oculus Rift CV1
They look actually hella nice, but having traditional screws instead of thumbscrews for card slots?
824 (0.22/day)
Poland
System Name Proper
Display(s) GB M32Q
Mouse Log G502 X LS
Software Win10 Pro
[pic]
Having 3 fans is one thing, but You need some more vertical space for the end chambers. Maybe that's what blocks 360 radiators' usage.
