Asus Anti Surge Problems
brololol
3 (0.00/day)
Hi I'm currently experiencing problems with the Asus anti surge
when i am using the computer normally to browse the web it works fine
but when i try to play a game (Far Cry 3, Hitman Absolution), after about 30~40 mins of gameplay, the computer just shuts down, and turns back on with the message
"Power Supply Surges detected during the previous power on. ASUS Anti-Surge was triggered to protect system from unstable power supply unit"
My current specs are
OS : Windows 7 Ultimate K 64-bit SP1
CPU: Intel core 15 3579K @ 3.40GHz Ivybridge 22nm Technology
Ram : 8.00 GB Dual Channel DDR3 @ 800MHz
Motherboard : ASUSTeK COMPUTER INC. P8H77-V (LGA1155)
GPU : 2048MB NVIDIA GeForce GTX 670 (Palit Microsystems)
Hard Drives : 112GB Samsung SSD 840 Series ATA Device (SSD) 37 °C
932GB Hitachi HDS721010CLA630 ATA Device (SATA)
PSU : Cooler Master 750 W
I've checked with this http://support.asus.com/PowerSupply.aspx?SLanguage=en
and it tells me i need 500W to run the computer, so the PSU should be more than enough
I've also read up somewhere that the Asus anti surge was overly sensitive and acts up randomly
I dont know if it is something to do with the PSU or the motherboard
I've thought of disabling the anti surge but im not sure what will happen to the motherboard if it actually is a faulty PSU
It worked perfectly fine when playing Dishonored on the highest settings, but not with Far Cry 3 and Hitman Absolution
Please Help!
newtekie1
Semi-Retired Folder
28,473 (4.02/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Sounds to me like the PSU is acting up, probably something somewhere going out of spec under heavly load and the motherboard detecting that and shutting down.
I'd get a quality power supply, assuming you have the GX 750w, I can tell you that unit is junk.
brololol
3 (0.00/day)
What are some better brands and models you would recommend in this case?
newtekie1
Semi-Retired Folder
28,473 (4.02/day)
Indiana, USA
Corsair and Seasonic.
69 (0.02/day)
Wolves, England
Processor i5-4670k
Motherboard ASUS Sabertooth Z87
Cooling Super Quiet 22dBA Titan Triple Copper Heatpipe
Memory 8gb (2x4gb kit) Kingston HyperX Genesis Dual-DDR3 1600MHz
Video Card(s) Palit 3gb GTX 780
Storage 240GB Intel 550 Series SSD, 2TB WD Caviar Black x2, 2TB Caviar Green
Display(s) Samsung SyncMaster S24B300
Case CoolerMaster Silencio 650
Audio Device(s) Onboard Realtek 5.1
Power Supply Corsair Pro Series HX850-80 Gold Modular
Software Windows 7 Pro x64 / Windows 8.1 Pro x64
Benchmark Scores 3DMark - 7893
I'd go for a Corsair HX750-80.
brololol
3 (0.00/day)
If i were to get the Corsair HX750-80 and this issue still keeps happening
will it be safe to just disable the anti surge?
1,237 (0.28/day)
California, unfortunately.
System Name Sierra
Processor Core i5-11600K
Motherboard Asus Prime B560M-A AC
Cooling CM 212 Black RGB Edition
Memory 64GB (2x 32GB) DDR4-3600
Video Card(s) MSI GeForce RTX 3080 10GB
Storage 4TB Samsung 990 Pro with Heatsink NVMe SSD
Display(s) 2x Dell S2721QS 4K 60Hz
Case Asus Prime AP201
Power Supply Thermaltake GF1 850W
Yeah, probably.
2,132 (0.37/day)
Chicago burbs
System Name Halloween Boo!
Processor Intel Core i7 3770K
Motherboard Gigabyte Z77-Up7
Cooling Custom Water/ Thermalchill TA 120.3/ Swiftech Apogeee XT/ MCP655/ Swiftech M icrores/ XSPC RX 240
Memory 16G G.Skill trident 2400MHz
Video Card(s) 3 x Radeon 7970
Storage OCZ Revo Drive 240G
Display(s) 24 inch Viewsonic
Case Phobia WayCoolIt Test Bench
Power Supply Nexus 1100 watt
Before you jump to a new PSU, test yours with a multimeter. They are inexpensive and make sure the rails are drawing he amps to ensure that is the problem. Buying a new PSU and having the same problem can be a bummer.
6,139 (1.13/day)
System Name RemixedBeast-NX
Cooling Dell Standard
Memory 24GB ECC
Mouse Logitech G700s/G502
Keyboard Logitech K740
VR HMD Linktr.ee/remixedcat // for my music ♡♡
Software Linux Mint 20
Benchmark Scores Network: APs: Ubiquiti Unifi AP-AC-LR and Lite Router/Sw:Meraki MX64 MS220-8P
Are you running the system on a surge strip, power strip, or ups???
