Hi everyone!
I was building my system now and got this problem. no post on the display, gpu and cooler fans and ram rgb are spinning, yellow DRAM light is blinking every 2 seconds and by the sound of the fans it seems like the whole system is turning off and on, like the noise created by fans is going down and then goes back to normal, like a car that that can't start up. I hope I was able to express the problem![Smile :) :)](https://tpucdn.com/forums/data/assets/smilies/smile-v1.gif)
switched ram sticks (borrowed from a friend)
tried single ram stick on different slots (XPG DDR4 D50)
swapped psu
updated BIOS via usb flashback (although the box said mobo is 5000 series ready) (usb 2.0 flash formatted in FAT32 via ms dos)
installed older BIOS via usb flashback
cleared CMOS by taking out the battery and shorting the pins
monitor cable connected to GPU, not mobo (gpu works on another PC)
Anybody had similar problem? Any help is appreciated.
swapped psu
