System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Its an ICHello
I'm looking for the schematic of the asus dual gtx1650 board I'm looking for the U507 component
Thank you so muchView attachment 255912View attachment 255912
there is no way to find out what kind of IC it is?Its an IC
Processor | AMD R7 5800X3D |
Motherboard | Asus Crosshair VIII Dark Hero |
Cooling | Thermalright Frozen Edge 360, 3x TL-B12 V2, 2x TL-B12 V1 |
Memory | 2x8 G.Skill Trident Z Royal 3200C14, 2x8GB G.Skill Trident Z Black and White 3200 C14 |
Video Card(s) | Zotac 4070 Ti Trinity OC |
Storage | WD SN850 1TB, SN850X 2TB, SN770 1TB |
Display(s) | LG 50UP7100 |
Case | Fractal Torrent Compact |
Audio Device(s) | JBL Bar 700 |
Power Supply | Seasonic Vertex GX-1000, Monster HDP1800 |
Mouse | Logitech G502 Hero |
Keyboard | Logitech G213 |
VR HMD | Oculus 3 |
Software | Yes |
Benchmark Scores | Yes |
We are an English speaking forum, please use a translator in the futuretengo asus gtx 1650, enciende ventiladores, pero no da video, observo que falta el componente que dice PML1, alguien esquema o foto de la tarjeta para verificar cual es el componente faltante, se le realizo limpieza y al parecer se desoldo.
I have asus gtx 1650, it turns on fans, but does not give video, I observe that the component that says PML1 is missing, someone schematic or photo of the card to verify which is the missing component, it was cleaned and apparently it was desoldered.
Tengo asus gtx 1650, enciende ventiladores, pero no da video, observo que falta el componente que dice PML1, alguien esquemático o foto de la tarjeta para verificar cual es el componente que falta, se limpió y al parecer se desoldó.
