ASUS GeForce GTX 970 STRIX 4GB
Ultramix
6 (0.00/day)
Hey Guys,
So I got a ASUS GeForce GTX 970 STRIX 4GB, when I go to boot up my system, there is no post on boot up. When, I plug in the DVI cable into the motherboard input, the display turns on fine. I have Antec 650W, so I don't think it's a PSU supply issue. I thought my motherboard PCI-E slots were bad, so I tested out my other slots no luck. When I ran my brothers GPU, it ran fine. I don't know what to do next with it, I read this on an old thread, but am curious at the validity of it actually being 100% accurate as I feel I might mess something up. Does someone know how can I go about this ?
PC Specs:
i7 4790K Stock Settings
16 GB G.Skill DDR3 1867 Mhz
Asus Z87-A Motherboard
Antec NeoECO-Modular 650W V2
Thanks,
Ultramix
Old Thread Link: https://www.techpowerup.com/forums/...en-no-signal-after-gaming-for-a-while.262982/
14,275 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Boot into the Bios and turn on CSM.
Ultramix
6 (0.00/day)
Thanks alot Bro, but the CSM option is already enabled. I was thinking of maybe reheating the surroundings on the gpu chip, incase of reballing (or resoldering) the chip back onto to the motherboard. What do you think ?
315 (0.15/day)
Italy
System Name The Worker/ Laptop
Processor Ryzen 5 3600/ i5 1035g1
Motherboard MSI b450 Tomahawk Max / Lenovo proprietary
Cooling Arctic Freezer 33 eSport One
Memory 16Gb DDR4 3200 Mhz Corsair vengeance LPX / 12gb ddr4 3200Mhz (4gb are soldered :( )
Video Card(s) Gigabyte gtx 1660 Ti OC @2030Mhz core and 7400Mhz memory / Intel G1 UHD
Storage 1 970Evo plus 500gb, 2x250Gb Samsung 850 Evo,3 TB HDD / 250gb WD SN530
Display(s) Asus mx259h / 15.6 FHD TN
Audio Device(s) Onboard / Onboard
Power Supply CoolerMaster G750M
Software W10 64bit
I think, it's not the case atm, try first with the software side. Have you tried to use Display Driver Uninstaller to do a clean and reinstall drivers?
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Card is dead. Period. Return it if you can. If you can't, sucks to be out that money.
5,293 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
I don't recommend the heat gun method even though I have had successes with this approach; a lot of people seem to try without flux and I am not surprised the fix is then short lived.
Ultramix
6 (0.00/day)
Yes, but it ended up doing nothing.
What do you recommend ? I've read people baking (putting it in their oven), I think heat gun is a better approach than that. lol
5,293 (3.73/day)
Colorado, U.S.A.
On that I agree, it is madness to heat up the whole board as the electrolytic capacitors can't take it.
Video Card Reflow | Electronics Repair And Technology News Video Card Reflow (jestineyong.com)
In the end I used an ultrasonic cleaner with isopropyl alcohol to clean the flux out from under the GPU even though it was no clean flux so could be left, but I worked on cards that were worth maybe $10 each, so I didn't have much to lose.
You might want to send it to a professional and not after having tried yourself.
Ultramix
6 (0.00/day)
Guys, I found this when I opened this. One IC chips looks burnt, is it replaceable ? Do you think this is fixable ?
543 (0.35/day)
Not Chicago, Illinois
System Name Desktop-TJ84TBK
Motherboard Asus ROG Strix B350-F Gaming
Cooling ARCTIC Liquid Freezer II 120mm, Noctua NF-F12
Memory B-Die 2x8GB 3200 CL14, Vengeance LPX 2x8GB 3200 CL16, OC'd to 3333 MT/s C16-16-16-32 tRC 48
Video Card(s) PNY GTX 690
Storage Crucial MX500 1TB, MX500 500GB, WD Blue 1TB, WD Black 2TB, WD Caviar Green 3TB, Intel Optane 16GB
Display(s) Sceptre M25 1080p200, ASUS 1080p74, Apple Studio Display M7649 17"
Case Rosewill CRUISER Black Gaming
Audio Device(s) SupremeFX S1220A
Power Supply Seasonic FOCUS GM-750
Mouse Kensington K72369
Keyboard Razer BlackWidow Ultimate 2013
Software Windows 10 Home 64-bit, macOS 11.7.8
Benchmark Scores are good
Nope. That card dead.
Forever.
543 (0.35/day)
Like no chance at all. Damn, someone sold me this and said it worked and my dumbass bought it without checking. I have a MSI GTX 960 2GB, do you think it's possible to change the gpu chip, as it's fine.
No. The GTX 960 is based on the GM206 GPU, while the GTX 970 is based on the GM204 GPU. They're not compatible with one another.
14,275 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Bring it to someone that specializes in the repair of GPUs, if it's soldered on, they can be replaced, finding the correct part might not be easy.
Ultramix
6 (0.00/day)
Would anyone know where I might be able to find it ? The code on the chips seems to be IOR 3598 5W1LP. Thank you so much, everyone !
I got someone to put it on, but how would I go about finding the part ? I live in Canada, so it might not be the best place to find such chips. If, you guys know and can get one on hand, I'm willing to pay for it with shipping as well, as long as it doesn't get too expensive. Thanks
14,275 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
You might not be able to find them new, but another old GPU from the same era might help if it has the same parts.
