ASUS Intros TUF Gaming VG279Q1R 27-inch Monitor
47,315 (7.52/day)
ASUS today rolled out the TUF Gaming VG279Q1R, a fast 27-inch gaming monitor. If you're willing to overlook its Full HD (1920 x 1080 pixels) resolution, on offer is an IPS panel with 144 Hz refresh-rate, 1 ms MPRT response time, ELMB (extreme low motion blur), and AMD FreeSync Premium support. ASUS offers most of its gamer-specific innovations such as GamePlus (hardware crosshairs, FPS counter, timer, multi-display alignment); and GameVisual (game genre-specific display presets). Display inputs include a DisplayPort 1.2a, and two HDMI 1.4a. The stand offers basic tilt adjustments, and can be detached to reveal a VESA wall mount. We expect a $250 price.
Regeneration
NGOHQ.COM
3,134 (0.45/day)
Let me guess...
Asus figured out how ridiculous their previous announcement was:
So they came up with this. :laugh:
1ms MPRT, ELMBB, BSBA, OTAP, GAGR, and so on = anything but GTG = fake spec.
8,373 (3.91/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Let me guess...
Indeed! GTG response times are omitted from specs about as often as panel type when it's budget TN;
"Call it anything else - Easyview, Readybrite, Clearpicture, Turboview - but you're fired if I see TN listed anywhere"
- PHB at MonitorCorp
I also wonder if there's scope for a class-action lawsuit against any monitor manufacturers claiming 1ms because when tested by reputable reviewers with the right testing hardware, they never even get close to 1ms.
1ms? No. Actually 3-7ms - and even then, the overshoot error is almost 30% for those 3ms transitions, which is so wrong, you can't really call that a valid pixel response in the first place.
22,757 (6.05/day)
With displays its actually very simple. You can just assume by rule of thumb that its utter shit, and maybe, just maybe you might be surprised here and there.
If this IPS actually has low ghosting and a decent peak brightness it looks pretty good. ELMB is a nice feature. But for 250 bucks... doubtful.
2,719 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
They need to get that on sale for close to 200 (€/$) in order to be competitive.
468 (0.10/day)
Lithuania
Processor Intel Core i5 4670K @ 4.8 GHz
Motherboard AsRock Z87 Extreme 4
Cooling Lepa NeoIllusion RGB CPU cooler
Memory 2*4GB Patriot G2 Series RAM
Video Card(s) MSI Radeon R9 380 4GB
Storage Transcend SSD 740 256GB + WD Caviar Blue 1TB
Display(s) Samsung SA 300 24" Full HD
Case NZXT Phantom 530 + Bitfenix Recon fan controller
Audio Device(s) Creative SB0770 X-Fi Xtreme Gamer
Power Supply PC Power and Cooling Silencer MkIII 750W 80+ Gold
Keyboard Steelseries Apex RAW
Benchmark Scores IT WORKS
OK, so TUF motherboards series all the time was labeled as "highest reliability" series, while ROG series was marked as "maximum performance series"
It is clear that all motherboards has +/- same reliability. I had ability to play with Sabertooth Z97 Mark 1 and I can say that it is regular motherboard with "Thermoshield" on it ant two additional fans which can blow air inside that plastic... And actually it is the only one motherboard which was broken out of the box. Two RAM slots were dead :D So basically they are regular motherboards, which use certified components (but doesn't mean that better components):
To prove that realibility is not the case:
1. https://www.hardware.fr/articles/862-2/cartes-meres.html
-Average the most reliable manufacturer (AsRock) fault ratio: 1,75%
-Average Asus motherboard fault ratio: 3,71%
-ASUS Sabertooth X58 fault ratio: 6,69% (5th worst rank that year, 4th worst motherboard among Asus products)
2. https://www.hardware.fr/articles/920-2/cartes-meres.html
-Average the most reliable manufacturer (Gigabyte) fault ratio: 2,02%
-Average Asus motherboard fault ratio: 2,31%
-ASUS SABERTOOTH Z77 fault ratio: 4,95% (4th worst rank that year, 2nd worst motherboard among Asus products)
3. https://www.hardware.fr/articles/934-2/cartes-meres.html
-Average Asus motherboard fault ratio: 2,31% . This time Asus had the best score in reliability
-ASUS SABERTOOTH 990FX R2.0 fault ratio: 5,31% (8th worst rank that year, 2nd worst motherboard among Asus products)
So I believe that we can conclude: Asus TUF motherboards are not better and not not worse than others in terms of reliability. But OK, lets forget it now. Lets talk about monitors again
TUF monitor? Seriously? What it does mean? What it should stand for? More reliable monitor? What differences are among TUF monitors and regular monitors? Looks like the regular monitor with expensive badge which even doesn't fit for this market...
1,990 (0.53/day)
Calabash, NC
System Name The Captain (2.0)
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-A
Memory 32GB (2x16) Kingston Fury Beast CL30 6000MT/s
Keyboard Varies based on mood; currently Razer Blackwidow V4 75% and Hyper X Alloy 65
I've said this before to describe the clusterf^$k that continues to be the Asus TUF series GPUs, most notably being the RX 5700 XT, but I'll say it again. TUF stands for The Ultimate Flop :D
In all seriousness though, I'm not even sure what makes Asus' earlier TUF branded mobos necessarily "better" than other boards at the time. A board can be built with high quality components, but that doesn't necessarily make it any less fragile than a board built with meh components. Motherboards are just delicate any way you slice it.
